hi, i have had my '03 spec v for about 6 months and the engine just broke down. I've done a bit of research and now know that the factory header can cause some problems, but is there anything else i can do to make sure this does not happen again?![]()
lets see, aftermarket header, BSR Kit from JWT, regular scheduled maintenance and i believe you might be golden on keeping the QR healthy and strong![]()
locktite butterflies
^^^ i knew i was forgetting something![]()
Other things to look out for are the fuel pump going out and your car will run extra rich with headers.
tune
BSR kit?
i wasnt aware bsr kit would be good for the health of the qr
What I do, and my SpecV doesn't burn a drop of oil, has perfect compression and perfect vacuum:
-Change header
-loctite butterfly screws
-cut balance shaft chain
-Run 0w20 for the first 120k miles.. and always drive the car really easy for the first 10 minutes... after that you can switch to 0w30 but always drive it very easy with a cold engine.
-Don't run synthetic past 7000 miles, 5000 miles if you are really hard on it, these engines like to destroy the oil ...and the bearings and timing chain don't like that.
-Change your coolant once a year with silicate-free coolant and make sure to use distilled water
-Every 6 months put 1/3 of a can of seafoam in the gas tank
-Change your PCV valve every 100k miles MAX, preferably 60k miles
An important tip, if you can... don't turn your heater on during the winter until the car is warmed up, it will take the car a lot longer to warm up.
14.4 @ 97.9mph just bolted
I have seen at least 3 QR's that have seized because the balance shaft broke while the car was revving high. The BS rotates at double the RPM's, and I believe isn't made to handle more than 12,800rpms (that's 6400RPM on the tach).
In your owners manual there is a guide for maintenance, in addition the the BSR removal, Aftermarket header, and locktit butterfly screws, follow this schedule even if it sounds absurd, even earlier if you're like me. Lol. The only thing I don't do by the book is oil changes every 5-7k miles, but I pay for quality stuff every time.
I do header and butterfully.. take care of my spec since. No problems it all. Unless drive as grandpa lol...
thanks guys you have all been a big help![]()
