After tearing apart a factory Spec V fuel canister/filter assembly, and seeing how horribly inadequate it was for high HP duty, (Thread here- Serious fuel system issues w/stock canister..) I've decided to put together a no nonsense, 100% complete, plug and play, drop-in fuel system for the Spec V. This will cover everything that you need, from the fuel tank, all the way up to the engine, with every nut, bolt, zip tie, etc.. Simply add your injectors, and you're done.
This setup will completely replace the Spec V's horrible factory canister, with a return style canister, that has a 255lph pump, already loaded in. Everything electronically, from the fuel pump feed, to the gauge feed/return is covered, and will plug right into your Spec V's harness at the fuel tank. Your OEM fuel feed line to the front will also plug right in.
In addition, this setup will convert your non-return system into a return style system, with a billet aluminum fuel pressure regulator (with gauge). It has a boost reference, if you want to use it with a standalone, however, you can leave it unhooked and just leave it at 50psi, base pressure, if you wish to use it with the factory ECU. In addition, if you wish to adjust your pressure, for any reason, you have that option. The regulator is adjustable from 25-75psi.
Lastly, I will be offering this kit with and without a billet fuel rail.. This will be a bolt-on, anodized blue billet rail, with shims to account for different height fuel injectors, from stock, all the way up to the tall Mototron injectors. The kit with billet rail will include all hoses, fittings, and clamps. The 400whp kit is rated at 400whp, ONLY because of the fuel rail. If you wish to add the rail, later on, to increase the capacity to 550whp, that will be an option.
Pricing for each kit is as follows:
Spec V: 400whp, plug/play Spec V, return style fuel system (W/O billet fuel rail)- 595.00
-New Plastic fuel canister assembly
-New fuel guage sending unit
-Walbro 255lph pump
-New Filter
-FI-R Billet fuel pressure regulator
-Fuel pressure gauge
-3ft fuel injection hose
-All fittings
-Clamps
-Brass T
-13ft fuel return hose
-Zip ties
Spec V: 550whp, plug/play Spec V, return style fuel system (With billet fuel rail)- 695.00
-Walbro 255lph pump
-New Filter
-FI-R Billet fuel rail
-7ft fuel injection hose
-All fittings
-Clamps
-Zip ties
-Nuts/bolts
-Shims for fuel rail
Remember, this is a complete fuel system, from front to back.. It includes a replacement fuel canister with pump installed, that drops right in, and replaces the crappy Spec V canister.
In case you missed my last thread about why the Spec V canister is inadequate, here's a link with pics..
These are available as of next week..
Thanks!
BTW, if you have a VQ swap.. the first option will work for you, as well. If you wish to add billet rails to your setup, I can do that for you, too. PM me for a price..
question, this sounds really good but i have an 01 se, what would be the difference?
not a bad price...what pump and fpr are you using?
That's wassup cause I'm going qr.
nice setup def interested, can you snap some pics of setup?
can we get a diff color fuel rail? red or BLACK?, id take a gold even
B15 - 04 - Panda - QR25 - S/C to Turbo
The white rims are Rotas... 17x9 +25, yes they fit brembos and yes my fenders are rolled with 235s, DONT PM ME (read threads)
and no they are NOT for sale and No i do not know where to find them.
# of PMS about my rims in one day record 6 as of 2/12/2012
If you want the rims you can buy the whole car
B15 - 03 - Beater - QR25 - Stock
B15 - 02 - Red - QR25 - Parting out.. PM me for parts!
B13 - 92 - FlatBlack - SR20 - Restored, DD'ed, Sold
red fuel rail?![]()
Bookmarked ., This sounds awesome Travis . thanks for the sweet Mod offer![]()
2003 Silver Spec VQ - Dyno'd @ 260whp 263ft/lbs * 4 now *
Bolted n tuned via Emanage Ultimate.
No pictures?
yo man im very interested....p.m. me when u get this plz
im guessing it uses the se canister?
im very happy i found this post,, cause i was about to do a whole new fuel settup for my car... eventually goin for 450 to 500 whp on my spec.... and this sounds like a pretty good settup.. def post up some pics of the whole kit.. thanx
I'm putting a setup together for a customer's car.. I'll take a few pics of the entire setup.
Yes, it uses a modified SE canister..
sounds sweet, deffently i nice set up for return style fuel system.
Fully Bolted.stock clutch and flywheel, stock bottom end. 04 SPECV
Thanks to TDM Imports, Midatlanticsentras and 2J Racing.
12.44 107.33MPH 1.6 60 FOOT
02 ser auto my dd
05 altima 2.5s wifes dd
post pics please when u can
Do those prices include shipping??
Maybe interested in this, I'll let you know. Also would like a black or red fuel rail instead of blue if possible.
black! LOL
