Thanks for giving me the credit![]()
Thanks b15sentraspec
You need the Nissan Fuel Pump repair kit.
Product SKU: NTB05-052A
For Service Bulletin # NTB05-052A
Get it here:
Nissan Fuel Pump Repair Kit - 2002-2006 Sentra (B15U) QR25, 2003-2006 Sentra (B1 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
In the Nissan universe, this part is known as .
The 2002-2006 Sentra QR25, 2003-2006 Sentra QG18 engine TSB# NTB05-052A uses a quantity of 1 of this part in this location.
Genuine Nissan Fuel Pump Repair Kit.
Installation instructions are not included.
- Application:
- 2002 Sentra (B15) with QR25 engine only.
- 2003-2006 Sentra (B15) with QR25 or QGI8 engine
- Applied VIN:
- 2002 Sentra with QR25 engine; all VINs
- 2003-2006 Sentra; all VINs
Nissan TSB #NTBO5-052a
Applied Vehicles: 2002 Sentra (B15) with QR25 engine, 2003-2006 Sentra (B15) with QR25 or QGI8 engine
Applied VIN: 2002 with QR25 engine; all VINs, 2003- 2006; all VINs
- IF YOU CONFIRM:
- When starting the engine, it cranks longer than 3 seconds before it starts.
- ACTION:
- Install the Fuel Pump Repair Kit
_____MY MODS_____
xtune cai w/ AEM dryflow filter
xtune 4-2-1 header
apexi ws2 exhaust
bronze nismos with 235/40 tires, BLOX black lug nuts
tein s tech springs
ddm tuning hid kit (6k headlight 3k fogs)
Pioneer head unit, 3ways (back), componets (front)
custom trunk bar
300zx caliper 26mm swap w/ stock 11" rotor
_____FOR SALE____
oem 1.8 headlights
megan racing midpipe
damn, i need this, no cheaper places to get it ay?
2004 SpecV . Nismo Cold Air Intake, Kenwood Touch Stereo . HP Header, Nismo cat-back, Stillen Crank. STS.
South Side Chicago
dealer hookup![]()
_____MY MODS_____
xtune 4-2-1 header
apexi ws2 exhaust
tein s tech springs
custom trunk bar
_____FOR SALE____
oem 1.8 headlights
found it for 2dollars cheaper lol
The Nismo Shop : West Covina Nissan : B15 Sentra Fuel Pump Repair Kit
_____MY MODS_____
xtune 4-2-1 header
apexi ws2 exhaust
tein s tech springs
custom trunk bar
_____FOR SALE____
oem 1.8 headlights
Ive had this issue since about 3 months after first getting my car more than 5 years ago and I dealt with it for a while then my best fiend did and then me now again.
Now that the car is back in my hands, i plan on fixing this because this shit annoys the shit out of me(not to mention its embarrassing) i know im kind of opening a dead thread but was there ever a recall on this? not just because im a cheap ass but because its a known issue and i havent been able to find anything about a recall anywhere online
Thats funny Courtsey is actually higher then me. my price would be $4.60 cheaper...shipped.
Thanks
Jeff
Houston, Texas
my ride is a 2006 Sentra SE-R SpecV
Mods to date: Nismo Cold Air Intake, Tein springs
Wishlist items: Cat-Back Exhaust and Turbo
would replacing the fuel pump eliminate the problem as well?
No, the problem is the fuel sending unit inside the fuel tank. When you drive the car for awhile and then park it,
fuel leaks out of the injectors back into the gas tank because the fuel sending unit has expanded due to heat
from the car running. One suggestion is to turn the key just enough to let the fuel pump prime and send
fuel back into the injectors before you crank it. This doesn't always work though so this fuel pump repair kit is the only permanent fix.
How common of a problem is this? I had my first 06 brand new and drove it for about 40K and never had this problem. Now I'm on my second 06 and this one has hard start issues. Car had 56K when I got it.
PARTS INFORMATION
DESCRIPTION PART #
Fuel Pump Repair Kit 22670-8U70C
Fuel Tank Gasket (O-ring) 17342-01A00
With your verbiage, I can finally explain what his happening to my passenger whenever they notice the hard start and shoot me a quizzical look. Furthermore; I knew the problem was fuel related but was completely wrong as to why. DOUBLE THANKS.
Although, for $250+, I can deal with the problem, as it only happens every so often.
Had about 4 cars with a qr and hard start issues...altima and sentra, installing a new fuel sender unit fixes the issue. No way around it. Unless it's a crank sensor issue. Then there is a tsb for cam and crank sensor kit.
Is there an install post?
If youre car was as fast as youre mouth you would be the King of the streets!!
I love Hella Flush and if you dont go kick rocks!!!!
Has anyone had this fix work for a short period of time (a month or so) and then start acting up again? Nissan installed the repair kit, under warranty. The problem returned a month later. Then they replaced the crank sensor. The problem returned a few months later. Long story short, the fuel pump was replaced three times after this, each time the problem returned within a month or so. The dealer finally refused to do anything else about the issue. I was told that this was the only vehicle they have ever worked on that the fuel pump repair kit failed on, in addition to the three fuel pumps and the crank sensor.
2004 Nissan Sentra SE-R Spec V
2007 Toyota Camry Hybrid
I had my fuel pump repair kit installed under warranty back in 2006. I am just now having the hard start problem again, 6 years later.. LOL.. I remember there being a "how to" on this repair kit. I think it was on the first myspecv, I'm not sure if there is one on here or not.
