So we all know the widely accepted way of fixing hard starting costs over $200. For me, being short on cash and experiencing this issue, this was not an option. I opted for a cheaper way.
Supplies:
~2 feet (I used 20") of 1/4" fuel tubing (bought from my local Advance Auto) - ~$3
-1/4" check valve (I used this one *edit* I need to find another check valve that can actually stand the high fuel pressure, I'll post it up when I find another one. ) - ~$18
- A tube of black silicone (optional, however it makes it easier to slide the hoses on, bought from my local Advance Auto) - ~$6
-4 hose clamps ( I used 1/4"-5/8" hose clamps bought from my local Lowes) - ~$2
You'll also need a utility knife and a flat head screw driver.
I took all my pictures after I installed it, sorry if I am not clear with my explainations.
First, you're going to need to remove the fuel hose connector that connects the hard fuel line (from the gas tank) to the soft fuel line (closest to the firewall). Remove the green cover that is over it (just pulls off). Then, squeeze the green tabs that are just below the connector and pull up on it. Some fuel may spill.
Next, remove the hose from the fuel rail connector. I did not remove the connector, it's a lot easier than figuring out how the damn thing comes off.You can remove the hose by just slicing it length wise where the connector is. You need to cut through two layers, as the fuel hose that comes with the QR has a plastic core and a rubber outer later. The picture is after the hose has been removed (sorry for the blurriness, but you get the point).
Next, remove the other end of the hose from the other connector by doing the same thing.
Now you can make the new hose. Take the 20" of new fuel hose and cut it in half. Dab some black silicone on the ends of the check valve as shown in the picture (careful, this stuff doesn't come off your hands easily so wipe it off ASAP). Then slide one hose on each end of the check valve and clamp them down nice and tight with two hose clamps on each side.
Now do the same with the connector on the fuel rail and the connector on the hard fuel line. Make sure the arrow that depicts the flow (on the valve) points towards the fuel rail, otherwise your car isn't going anywhere.
And when you have done that it should look like these
And the finished product
Hook it all back up and test for leaks. And there you have it, no more hard starting and it cost under $20. Sure beats paying a lot for something else that (or so I have heard) will eventually do the same thing again.![]()
2003 SE-R Spec V - Nismo SRI with K&N cone filter, Enkei 5+, washer wheel hop mod, BS chain cut, Hurst pistol grip shift knob, CX Racing radiator, Hawk HPS pads - hopefully more to come
Fix hard starting for about $20 http://www.b15u.com/sentra-specific-installation-guides-technical-info/12861-how-fix-hard-starting-about-%2420.html
What does the check valve do?
Sick!
It lets fuel flow towards the fuel rail, but it doesn't let it flow back.
very interesting approach
How I've Made My Spec "Mine":
* New (Rebuilt) Engine, * OBX Header, 2.5" exhaust piping, Magnaflow high-flow cat, Thrush 18" resonator, Thrush oval exhaust.
~*~Carolina Girls, Best in the World~*~
Thanks![]()
Any way you can direct me to the exact one you bought? i went to the website and there's all sorts of different ones with different psi's and prices i plan on doing this ASAP Ive been dealing with this shit for way too long and its embarrassing as hell![]()
My bad, I should have posted the link lol. Check Valve, Ball Cone, Nylon, 1/4 In, Barb - Check and Foot Valves - Valves - Plumbing : Grainger Industrial Supply
No problem.
good shit...i think im going to do this lol
It works really well, I was able to park on a hill, wait 15 minutes and start my car without a problem.
I went to check out and it estimated shipping and the valve to be $12? that's kind of weird?![]()
That's what I paid too, they ship fast though.
i keep finding these shitz on ebay i didn't know if it would work the same1/4" SAFTY CHECK VALVE HYDROGEN GENERATOR / Browns Gas: eBay Motors (item 260380324698 end time Aug-11-10 15:56:23 PDT)
http://cgi.ebay.com/HHO-Generator-2-1-4-In-Line-Check-Valves-Water4Gas-/260452115054?campid=5336458579&cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3ca427e26e
http://cgi.ebay.com/ebaymotors/One-w...Q5fAccessories
I didn't include shipping since they have stores too. You aren't restricted to that specific check valve either, everything you listed looks fine too me. Dunno how much pressure they can take though.
hey one more q? was that 1/4" ID or OD? on the valve and Hose
ID for the hose.
Thanks for the DIY!!
I just got my ser and was getting hella irritated w/ the hard starting!!!!!
Yep![]()
