Page 1 of 5 12345 LastLast
Results 1 to 20 of 94
Thread: WRX Fuel Pump
    Default WRX Fuel Pump
    Instead of buying a Walbro 255, u have another choice which is the 190 WRX (non sti) fuel pump. you can find them as low as $25. I bought mine for $35 shipped. To do this all u need is the fuel pump, u can reuse all ur stock stuff.
    First locate your Fuel pump fuse. It is behind the coin trey, 15amp fuse. Take it out.
    Crank the car to make sure it doesnt start.
    Open the gas cap and leave it open until u finish the installation to let pressure out.
    Take back seat out and you will see this..
    use a screw driver turning it clockwise to turn the 3 tabs that are circled
    Disconnect the harness clip and push on the sides of the hose clip and pull hose out.
    Use a 8mm socket to get those crews out. you can use a screw driver but those screw heads are pretty weak and will bend on you.
    Now take out whole container. *note it will make a mess so have a towel near you. notice how much gas is in the contaner. Try to empty as much gas as u can in the hole.
    You will see a white wire and a blueish wire, disconnect both wires before u take apart the container. Also disconnect the clip thats connected to the fuel pump
    Take fuel pump out by pushing it. You will see a rubber thingy thats on top of the stock fuel pump. take that out and put it on the WRX fuel pump.
    Also reuse the other rubber thingy and put it on the wrx fuel pump. It will feel kinda loose but it will pop in place when u insert it back into the container
    Now put the WRX fuel pump back in the container
    Once inserted u can now put everything back in place.
    Connect the fuel pump clip
    Connect the white wire
    Connect the blueish wire
    Put container back together
    Drop the container back into the tank and screw everything back in.
    When tring to start the car, it will crank for about 5 seconds then it will start right up.
    THE END.. Time it took was about 30mins
    did u change that top "o-ring" gasket or seal?? once u take out the fuel pump your supposed to change that gasket.
    Quote Originally Posted by TBb15 View Post
    which one? on top of the FP? or the bottom of the FP? i just swapped out the stuff onto the wrx FP
    those 6 10mm bolts pretty much under the seat, theres a gasket between than and the fuel tank.
    OHhh ok, yea that one. it gave me a hard time not knowng it was stretched but yea thats replaced
    Quote Originally Posted by nightrider45 View Post
    yea once u open up those 6 bolts that gasket is trash. just makin sure
    For those that dont know wut me and TB is talking about it's this rubber ring
    Baby Kicker
    I'm on a boat
    soooo...those this solve the hard start up? what else does it do? its probably better then the spec v pump right?
    Mamut Shift_POLSKA
    Thats how I do...
    www.djtunez.net
    www.247nightlife.com
    Quote Originally Posted by mamut View Post
    hard start up could be anything from spark plugs/gapping all the way to a failing fuel pump.
    It's slightly bigger then the stock pump. it's 190 lph and i beleive the stock bump is 90 lph
    Sebastian SpecBEE is offline
    Nov 2006
    Slapped 3 Times in 1 Post
    so the harness is the same?! wheres the floater?! lol..
    would you notice anythign if im running stock injectors?
    ^nope u wont need this for ur car. u wont notice anything
    Nov 2006
    BUT if i had injectors? cuz my afc will be going in shortly
    u can get it if u want but it wont benifit or show any gains or anything. This is used if ur lightly boosting/spraying, heavy built motor to keep the fuel pressure flowing instead of maxing it out.
    If u had the injectors and this FP, u will have to take soo much fuel from the injectors on the SAFC since ur car wont need so much fuel
    Nov 2006
    oh i got ya... yo jay, i may need your help then come spring time.. im just pieceing it all together as for right now
    Jay, you're the man. This setup would be good for 8psi of boost btw...since the walbro is sorta over kill.
    :wink:
    Jan 2007
    massapequa
    yo jay what size is that rubber gasket thats needed to b replaced?
    Quote Originally Posted by silvabullit View Post
    it comes from the dealer.
    Jan 2007
    massapequa
    yehh but what if i buy a used one nd it doesnt come with the gasket...you know jus thinkin ahead
    they dont come with the FP, thats a seprate thing. just go to the dealer and explain them the gasket your talking about or even print out that pic and show them.
  1. Choosing a fuel pump
    Last Post: 01-31-2009, 01:27 PM
  2. fuel pump
    By blackoutspec in forum B15 Sentra (2000 - 2006)
    Last Post: 12-12-2008, 10:49 PM
  3. wtb fuel pump
    By dawhitespecv in forum Parts for Sale
    Last Post: 11-15-2008, 08:09 PM
  4. Fuel Pump
    By 02SilverSpecV in forum B15 Sentra (2000 - 2006)
    Last Post: 07-20-2008, 02:29 AM
