Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    Chris veeeeee is offline
    Coppell
    Quote Originally Posted by shortcut10 View Post
    I did this mod a while ago thinking it wasn't that big a deal and I was the only one it happened to but with the energy suspension universal sway bar bushings in red, looks sick and also very useful, but splash lemme give you a heads up depending on how the fit is the bushings sometimes slip out and get lost, so once in a while take a look under your hood, I've had this done since last year about the time we met and I gave you the part, and since then I've lost almost 5 bushings(fortunately the box comes with 8 for about 10 or 12 bucks
    i used these too if i'm thinking of the same red bushing. but mine fit in there really really tight had to really mash them in there to get them to go in. hopefully mine wont fall out
    Crutchfield referral code:20 dollars off 200 for new customers!
    ppgup-wa3yr-wtbsy
    AdvancedAutoParts Referral code :save 40% off first purchase 50 dollars or more after promotions, before excluding tax,shipping and core charges. Help a guy out and use my link please
    http://advanceautoparts.tellapal.com/a/clk/3fG8Z3
    My Spec VEEEEEE
  2. #22
    5er
    Dave the VQ Killer 5er is offline
    BC - CANADA (GREAT WHITE NORTH EH!)
    I did mine a few years ago with drill rubber backing pads (for sanding), replaced the old bushings 100%
    Not these exact ones, but this is the idea. Mine had a screw though design... just popped that out. Had to take off the rad brackets pop these on, and put the rad brackets back on.... not worn out to this day
    http://www.themotorreport.com.au/wp-content/uploads/2009/10/madmax-pursuitspecial-xbfalcon-02.jpg
  3. #23
    Coppell
    cant you get some small self tapping screws and a washer and screw it into the top of the post ? or would they crack? this is what i have right now.
    but it made me think about the screws/washer. well i tried it to make it flush would need like 2 different sized washers one to take up the gap and another to keep them from coming off.
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
  4. #24
  5. #25
    Coppell
    Quote Originally Posted by beerich671 View Post
    deng i wish i can do this, i just found out the my radiator rubber mounts are totally burnt the hell out.
    buy a bushing kit for the rubber on your lca i think for your sway bar ends or the thing that connects them. i had 2 extra ones after replacing my stock bushings used those 2 extra ones to do my radiator. assuming your outer ring of rubber is still good. 2 for one mod
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
  6. #26
    Coppell
    i posted the pics in a nother thread but this is my anti fallout solution lol
    some left over washers from the sway bar end kit and some small screws and washers
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
  7. #27
    Jared nosliwmj is offline
    Texas
    I just put the sway bar bushings on my radiator and it finally doesn't make noise while idling anymore. Probably the most satisfying cheap mod I've ever done
  8. #28
    Any one here got any part numbers for these bushings?
  9. #29
    It's on the package in the first post.
  10. #30
    Sep 2009
    Queens,NY
    Slapped 5 Times in 3 Posts
    If your radiator rubber piece is all torn as well, you can use electrical tape to wrap the bushings then follow by washer screw.
  11. #31
    Chris skwirl is offline
    North Texas
    I used the poly-urethane skateboard truck bushings. They fit and work perfectly.
  12. #32
    I was inquiring about the energy suspension versions of the track auto bushings. Looking for something stiffer since it is going into a track car.
  13. #33
    Quote Originally Posted by Sigfod View Post
    Part # 9.8105
    Energy Suspension 9.8105 Sway Bar End Link Grommets and Washers - 98105
  14. #34
    Erick ErickB15 is offline
    Nov 2010
    Honduras
    Quote Originally Posted by veeeeee View Post
    i forgot i told i was going to post pics of mine... but they look exactly like this one...
    Yea my English sucks , deal with it!
  15. #35
    Aug 2011
    atlanta, ga
    I bought new brackets and bushings from nissan a few days after I bought my car.
LinkBacks (?)
  1. 01-10-2012, 05:19 PM
  1. 02-06 FI-R shifter bushing kits (22 sets left!)
    By Trav4011 in forum Parts for Sale
    Last Post: 07-10-2011, 01:30 PM
  2. All B15 Models Energy Suspension - URETHANE > RUBBER
    By majormods in forum MajorMods
    Last Post: 02-22-2011, 07:14 PM
  3. Has anyone tried the shifter bushing kit
    By ricwhic414 in forum Transmissions, Clutches, etc.
    Last Post: 11-08-2009, 12:52 PM
  4. bushing problem?
    By tomspecv in forum B15 Sentra (2000 - 2006)
    Last Post: 04-04-2009, 05:30 PM
  5. New rubber.
    By EL STi in forum Naturally Aspirated (NA)
    Last Post: 05-11-2007, 03:25 PM
