Results 1 to 20 of 35
    Default $3 Radiator Rubber Bushing Mod
    Was looking around autozone for some stuff and came across these bushings. It looked like it had the same ID to fit over the radiator nipple thingy and a good enough OD to fit inside the stock rubber bushing. "And it FITS!!"
    You can buy it at any auto parts store that sells HELP products. It's $2.99 a pair.
    1. This is one of your Radiator bushing location, the other one is by the battery.
    2. Pull it out from the top or bottom like this.
    3. This is how it looks like when u pull it out. And you want to stick your finger in it to push it through the otherside so u can rip off that torn section.
    4. Example of how it fits just right.
    5. Install stock rubber back to the radiator
    6. You can use alil oil to make it slip inside to make it easier, rubber+ruber=friction so use lube. Move radiator to a side that you can snug the new rubber bushing inside.
    Thats it your done. Enjoy a non wiggly radiator
    looks great the stock rubber mounts on my 05 are about to give up the ghost,and this should work fine thanks again
    Sacramento
    man, this looks great. my bushings are suck and have way too much play. i'll look for this later this week.
    Gerry GTurner598 is offline
    Clarks Summit, PA
    i did something different to fix my radiator...i bought brand new rubber mounts and it still didnt help so i went to home depot and bought these rubber things that you put on the bottom of chairs so they dont slide and drilled a whole in them and put them in, then put the rubber things on top of them and then tighten down the metal part as much as i could and it keeps it really tight
    2002 Nissan Sentra SER Spec V: Cloud White
    Custom Intake/Hotshot Header/Megan downpipe/Magnaflow Catback/UR crank pulley/BSR/AEM wideband/Apexi SAFC II/+2 timing/4650 RPM secondaries/MMI/tein springs/Knock Sensor Mod/5% tint/HID reverse lights/HID fogs/HID headlights
    Abe Tawil Dishonestabe is offline
    Dec 2010
    Toledo, Ohio
    Just did this mod and love it works great!
    Peter shortcut10 is offline
    Meriden, CT
    I did this mod a while ago thinking it wasn't that big a deal and I was the only one it happened to but with the energy suspension universal sway bar bushings in red, looks sick and also very useful, but splash lemme give you a heads up depending on how the fit is the bushings sometimes slip out and get lost, so once in a while take a look under your hood, I've had this done since last year about the time we met and I gave you the part, and since then I've lost almost 5 bushings(fortunately the box comes with 8 for about 10 or 12 bucks
    Erick ErickB15 is offline
    Nov 2010
    Honduras
    mines are better and i made them, ill post a pic later
    Dec 2010
    Toledo, Ohio
    Quote Originally Posted by ErickSpecV View Post
    Will like to see those pics once you get them posted.
    John Bevill streetracer1 is offline
    vineland, new jersey
    Quote Originally Posted by shortcut10 View Post
    I lost 3 just the past week. I'm going to try glueing the bushings to the hold rubber mount and see if that helps
    What's done to your car? It's easier just to tell you what's not done to it....
    Dec 2010
    Toledo, Ohio
    I'm going to use some molding adhesive and try to glue mine into place hopefully it will do the trick
    Meriden, CT
    what I would suggest, and what makes sense to me is a high temp rubber cement, I'll see if I can try it and report back....
    adam willms81 is offline
    Copperas Cove, Tx
    Slapped 3 Times in 3 Posts
    If you have an aftermarket intake, use the two rubber bushings that the stock airbox was attached to the engine bay with. They are a direct fit and require no modification to work. I have had mine on my radiator for almost a year now.
    Dec 2010
    Toledo, Ohio
    went to go glue mine in today only to realize that they where missing sadly the pack I had only had 2 of them so I guess some reworking is in order
    Andy picabu is offline
    Denville NJ
    Here is my solution for the bushing. You will never loose a bushing again! Don't mind the dirty bracket
    Basically I drilled a hole across the radiator stud and used a 1-1/2" galvanized pneumatic finishing nail and bend it in an "s" pattern to retain the bushing. You could use a cotter pin if you have them laying around....I did not want to make a run for just 2 cotter pins so I made do and it seemed to hold up OK.
    05 V.O. Spec V w/ Brembo
    Meriden, CT
    hmmm very nice I like
    Dec 2010
    Toledo, Ohio
    I like the idea i was actually thinking of using a cotter pin, looks great!
    Sep 2009
    Queens,NY
    Slapped 5 Times in 3 Posts
    I used a water bottle cap yesterday as a backup Lool. It's coming lose so i gotta think fast.
    Dec 2010
    Toledo, Ohio
    Quote Originally Posted by picabu View Post
    What bushings did you use are those energy suspension?
    Denville NJ
    Quote Originally Posted by Dishonestabe View Post
    Not sure ...I bought it from CriciKaze. He said they was misccelaneous aftermarket endlink bushings.
    Dec 2010
    Toledo, Ohio
    Guess I will have to try to see what I could find at the parts store so I could use the cotter pins
LinkBacks (?)
  1. 01-10-2012, 05:19 PM
  1. 02-06 FI-R shifter bushing kits (22 sets left!)
    By Trav4011 in forum Parts for Sale
    Last Post: 07-10-2011, 01:30 PM
  2. All B15 Models Energy Suspension - URETHANE > RUBBER
    By majormods in forum MajorMods
    Last Post: 02-22-2011, 07:14 PM
  3. Has anyone tried the shifter bushing kit
    By ricwhic414 in forum Transmissions, Clutches, etc.
    Last Post: 11-08-2009, 12:52 PM
  4. bushing problem?
    By tomspecv in forum B15 Sentra (2000 - 2006)
    Last Post: 04-04-2009, 05:30 PM
  5. New rubber.
    By EL STi in forum Naturally Aspirated (NA)
    Last Post: 05-11-2007, 03:25 PM
