Thanks Travis (Trav4011 - fi-r.net)
Here's a list of data he's compiled over the years, pertaining to the QR25DE (02-06) engine..
Bore- 89mm (3.504")
Stroke- 100mm (3.937")
Deck Height- 225.5mm (8.878")
Compression Ratio- 9.5:1
Piston dish volume- 10.1cc
Compression Height- 32mm (1.259")
Wrist pin diameter- 19.98mm (.787")
Crevice volume- .3cc
Head gasket squished volume- 4.1cc
Piston below deck volume- 3.7cc (amount of space occupied from the top of the deck, down to the piston's top)
Rod length (center to center)- 143.03mm (5.631")
Small end diameter- 19.98mm (.787")
Big end diameter- 47.8mm (1.887")
Small end width- 22.8mm (.898")
Big end width- 22.8mm (.898")
