does anyone have experience with the tanabe df210 springs? I am thinking about getting either those or the tein s techs but I would like to see which one rides nicer. Im trying to maintain ride quality as close to stock as possible.
I had those on my da integra and loved them. Ride was just fine.does anyone have experience with the tanabe df210 springs? I am thinking about getting either those or the tein s techs but I would like to see which one rides nicer. Im trying to maintain ride quality as close to stock as possible.
Bolt-ons and BC 8's
ALL people fall short of God's expectations. Message me for info, prayer request welcomed!
Ephesians 2:9 NLT: Salvation is not a reward for the good things we have done, so none of us can boast about it.
cool tread. considering coils now.
Anyone ever try Spax Springs? I just picked them up from a local speedshop for a wicked deal that i just couldnt pass up. 1.4" drop in front 1" drop in the rear. They are made in the UK, but i cant really find much information on them. They are however listed specifically for the 02-06 Spec-v.
02 Molten Silver Spec-V - I/H/E , Prothane Mounts, Washer Mod, Brembo Blanks with Hawk HPS Pads, Razo Weighted Shift Knob, Shorty Antenna, Custom "Spec-v" Badged Grill,
To be installed - Brembo Calipers, GR-2's w/ Lowering Springs, Rear Panhard Bar.
Great info on this thread, does any one have TANABE springs installed on your sentra, i was looking at these on ebay TANABE DF210 LOWERING SPRINGS 00-04 05 06 SENTRA B15 | eBay... or what will be better, coilovers? BTW i have a 1.8 sentra..2004
If I had to choose a set of springs it would be the Tanabe GF's. Yes coilovers are recomended, but I really like their spring rates and never heard a complaint from the company
Does anybody know if the Spec V struts and 1.8 struts are interchangeable? I need two new front struts and wanted to get the Spec ones because they apparently hold up better to lowering springs than the XE ones I have now.
All B15 suspension parts are interchangeable.
Damn dude this helped this out a lot thanks
people on megan springs!
did you have to purchase a camber kit? and if you can any pros and cons please?![]()
which springs should i get that i wont be needing a camber kit? something under the $200 mark.
Any of them. Im running the eibach sportlines and my camber is fine. Tires wear pretty descent . Maybe only 1/16th more on the inside
white 03 spec v
Which springs give the most comfortable ride?
Coilovers. Eibach prokit if your looking for cheaper. Honestly my roads are horrendous too, even with my drop it comes down to the shocks on how they handle it. I like my ride. A bit stiffer but not at all rough. All comes down to spring rate, drop, length, density. Everyone will have an oppinion. Just go with your gut
white 03 spec v
Im thinking about getting megan racing springs who thinks i should?
megan=
but yeah just put a gr2 w/ eibach sportline on a spec and its pretty smooth
swift is a good spring choice
