Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 105
    Dec 2008
    Default Suspension time (b13/b14 compatability)
    Well, I finally started work changing my car back from a race car into a street car. Some of the parts I sold/threw away are going to be trouble to find (door panels, dash, sunroof, lol)
    Anyway, I dyed my carpet black this week, and the speaker cover under the rear glass)
    I am waiting for stock injectors (still on 780cc) to get here so I can rip the megasquirt out of the car and get it and all the other stuff out of the floorboard. Then I can put the carpet back in and start pieceing things back together.
    Back to where I was going with this...
    I explained to my wonderful loving wife why I needed to order a full set of struts and springs and a few other parts in order to get the car "safe for the street".
    I ordered:
    KYB AGX B13 front struts. B14's will also fit, but the b13 version has more suspension travel.
    KYB AGX B14 rear struts
    Nissan OEM b13 front pillow ball mount bearings (There are two different versions, one for power steering, and one for not. I ordered both (about $20 ea) and will post which fits.)
    Swift Sport springs (190lb/in & 1.2" drop / 280 & 1.0" drop)
    Also ordered an Innovate DB-Blue AFR gauge to connect to my LC1. It is totally "needed" now that the lc1 won't be fed into the megasquirt.
    I will update this thread with how it goes.
    I'm changing out my last 2 Star-Specs to Toyo Proxies 4 and getting an alignment after the shop installs the suspension. After that I MAY get a RSB as well, but I feel like I could build one myself.
    Then I have to find someone to weld some metal over the big hole in my roof. I think I threw away my sunroof.
    Hopefully at least, I will have a leak-free car. The lexan sunroof conversion was always a pain. The gasket maker always separates and starts leaking. I hate sitting on a wet seat.
    I wish I would have known this a couple months ago. I love my kyb gr2/swift sport combo, but dampening adjustability would be nice.
    Dec 2008
    Quote Originally Posted by Charka View Post
    Me too! Those b15 GR2's are roughly 10% more dampening than stock (which are also made by KYB, as OEM products.)
    Unfortunately, the stock struts are widely considered to be greatly underdampened, and the 10% added by the gr2's got it a lot closer for stock springs, but swift sport springs are way too heavy for gr2s.
    The b13 SE-R only had 123 lb/in springs on the front. The Spec-v is 154, so with swift sport 190's on the front, I'm going to need to set the b13 KYBs to something like 5 to get it even.
    I can't find stock spring rates for the b14 at all. I'm hoping around 190 rear, which would put me around 5-6 as well on the rear struts with swift sport springs.
    I plan to set them on 6 and leave them there unless I *HAVE* to change it for some reason.
    QUESTION: What strut baffles and bump stops should I buy? Koni?
    Karl MisterNuts is online now
    Quote Originally Posted by pimpsmurf View Post
    The B15 gr2's have the same part # for SE-R's and Spec's, so I've heard they are actually UNDERdampened for the Spec V's (since SE-R struts have softer dampers stock).
    Any truth to this?
    Dec 2008
    Any truth to this?
    They list the same for all the b13's which are quite different, but KYB told me they are 10% higher than the stock spec-v. True or not? I don't know. But that is what I was told by my contact who seemed to know a ton more than I did about everything suspension. haha. not saying much.
    Found b15 strut covers w/ bumpers from Advance auto made by Moog. I guess they will be better than nothing.
    I had heard that the gr2s are 15% stiffer, but I doubt that 5% would matter much at all anyways.
    When I was looking for springs I wanted about a 1" drop and a spring rate to match the valving of the gr2 struts/shocks (I thought 15% stiffer than stock). So assuming the stock springs and shocks/struts were matched well to each other (apparently they're not) I was looking for 154x1.15= 177.1 in/lb front, and 247x1.15= 284.05 in/lb rear springs. That pretty much boiled it down to the Swift sport or Eibach Pro-kit. I went with the Swift sports because I couldn't find one bad thing/review about them. And they were only $165 shipped.
    Anyways, point of this post is that I fucking love how my car feels now haha. If they are under-dampened what would be the characteristics of that?
    Jeremy jeremy is offline
    calipornia
    any reason you didn't use koni's? no need to "search" for the right size.
    konis require much more work than the agx..granite they are a better shock than the agx's but as far as what he is doing the agx should work fine. i also have purchased agx shocks myself for the front not sure what way im gonna go yet..either springs or coilover sleeves. cant make up my mind.
    Dec 2008
    Granted, granite confused the shit out of me. Heh
    I am DONE working on car shit for a while. I am certainly capable of doing this work, but I am having my mechanic do it because I am lazy. Konis would have cost more, and required more labor. BC coilovers with custom springs would have been cheaper.
    Konis are indeed awsome, but I don't want to be hacking stock struts for hours. I AM however, saving the stock fronts. For later.
    i hear that man. pimp arent you from NC? i think i saw your name on importsnc forums. i hopefully will have my sleeves in the next few weeks and get the fronts done.
    Dec 2008
    Quote Originally Posted by Red Sled View Post
    Yes, I was on a lot of forums for a while
    I feel off the planet when I decided to stop doing insane things to the spec-v, and start being a dad. I plan to do something crazy again later in life, provided 2012 doesn't pose a threat.
    Dec 2008
    AHHHHHHHHH YEAAHHHH (in my best It's Always Sunny voice)
    I got the KYB AGX's in today! Hurray Hurray! They are SEXY! I am going to run setting 6 in the rear, and setting 3 (of 4) in the front. Hopefully that will feel right on the Springs, although with the Swift Sport springs, I should be able to easily adjust the rears anyway.
    Did I mention they are sexy? Holy crap they make me hot in my car-guy-pants. The color is awesome and will definitely stand out. I believe the swift sport springs are also red, which will be very nice looking IMO. The Moog covers and bumpers seem solid. The rear bumper seems like it would absorb a LOT more than the front, which is somewhat troubling, but I guess they will have to do.
    The SS springs should arrive on Friday, and the injectors and DB-Blue Innovate gauge arrived today as well. Provided the springs arrive on time, and the damned top mount bearings ship from courtesy (still "on order") then I should have a suspension installed next week. I may take it for an alignment and "finish off" the set of dunlop star spec's before taking it to the other shop to have some new front tires installed (finishing a set of Toyo Proxy 4's, bleh)
    This is all providing I succeed in converting from MS back to the stock ECU (fuck ms1-2, ms3 when it comes out will fully support the QR, timing and all, thanks to Gurov. Much respect for him pulling that off. drama-aside)
    Hopefully all is well and I'm back on regular gasoline so I can look cool and buy VP110 at the local gas station finally!
    post pics when you get them..im gonna run sleeves but instead of eibach springs hopefully gonna run JIC coilover springs.
    Ashwin ash is online now
    post up some pics
    Bothell, WA
    Pics or it doesn't count...
    Spec For Life....!!! ( I have an SE-R... Does that mean that I am dead...?)
    SoundEfx up in here causing trouble.....
    "I'm a BAD man... BAD man doh dance..."
    " That bam-bam is MINE..!! "
    VQ35DET for the win... and VQ35DETT for the TiTs..
    Dec 2008
    pics of the AGX not mounted? lol. sure thing... I've got something to prove...
    Dec 2008
    Super high resolution and ulti-high quality 5mp camera phone pic in the dark? good nuff?
    Miguel Cortez mglcrtz is offline
    Sanford, NC
    Cant see sh!t!! xD
    Dec 2008
    Quote Originally Posted by mglcrtz View Post
    Cant see sh!t!! xD
    You can see they are red-orange, and they may look badass. I can't find the cord to my real camera, and the cell phone camera doesn't have a flash. haha. I will get some good pictures once I get them installed next week.
    lmao
  1. b14 section
    By shaun11423 in forum Feedback & Support
    Last Post: 01-01-2010, 04:28 PM
  2. spotted a B14
    By Bolted V in forum Sightings - THIS SECTION IS CLOSED - POST IN YOUR REGIONAL SECTION
    Last Post: 08-05-2009, 06:45 PM
  3. B14 w/ VQ35DE
    By yuri1z in forum Naturally Aspirated (NA)
    Last Post: 12-19-2007, 02:48 AM
  4. B14 With a QR25 !!!!
    By B15NewYork in forum General Automotive News, Discussions and Rumors
    Last Post: 01-25-2007, 06:52 PM
  5. nice b14
    By FuLLah in forum General Automotive News, Discussions and Rumors
    Last Post: 01-13-2006, 11:25 AM
