i have a spec that came with disc brakes instead of brembos....i was thinking of swapping on the brembos. so is it possible to swap the fronts and the rears without many modifications?
Question answered thank you![]()
to swap the fronts you'll need the entire setup..calipers, mounts, pads, rotors
so how do u swap the rears? even without the e-brake? i like the look of the small brembo calipers on the 350z's and such... would just look more uniform to me....
04 Sunburst Spec V Nismo CAI & Cat-Back w/ Brembos + Hawk HPS
Newest addition: 8000k HIDs - Them SHITS CRUNK!
$9 STS Mod / Fog Light Mod / Silvia R33 Side Skirts / Painted Valve Cover / Cut BSR Chain! / Gutted Pre-Cat
The Brembo equipped Sentras only have Brembo calipers on the front if I'm not mistaken. In the rear its just a standard Nissan caliper. However, the rear rotor size is larger, but I don't recall if the caliper is longer or if there is a bracket. Either way, Brembo will bolt right on as long as you get the complete set like Ash said.
Bolt-ons and BC 8's
ALL people fall short of God's expectations. Message me for info, prayer request welcomed!
Ephesians 2:9 NLT: Salvation is not a reward for the good things we have done, so none of us can boast about it.
idk i wouldnt want full brembo's lol. we dont have that big of a car to stop any ways......so whats the point? the fronts would be fine. Sometimes i wonder if even the fronts are to much! lol
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
clutchmasters stage 2 clutch
JWT flywheel
2005 SE-R ALTIMA
ebay intake with K&N filter
racingline sturbar
Racingline y-pipe
NWP block off plate
Yea constant braking will kill poor quality brake components. Rotors will warp, pads will... do whatever they do, lol. I love the Brembos.
Bolt-ons and BC 8's
