Guys,
I installed my Nismo FSB with the stock bushings and clamp that came with the car. Where can I find the actual Nismo bushings?
I can only find the stock ones:
[54613] BUSH-STABILIZER
and the stock clamp:
[54614] BRACKET & BUSHING
are these the only options I have for the Nismo FSB?
2006 Sentra 1.8 SE
K&N CAI/ TBS/ NISMO FSB & RSB/ Spec-V Susp/
300ZX brakes+Brembo rears/ 2JR LW Pulley
ES makes some sway bar bushings, I would check them out.
I have ES ones. Just search their website for FSB bushings, in the correct size. The nismo FSB is 21mm? Or 19mm? I forgot. Lol. Either way, they have some, and they are stiffer.
I already order the 23mm ones from ES, they are 9.5158G. They are BIG and wont fit properly with the sway bar. Where did you find yours?
2006 Sentra 1.8 SE
energysuspension.com | Sway Bar & End Link Bushings
no luck, just has a page for sway bar and end link bushings. Seems like there's not much for 23mm lol
2006 Sentra 1.8 SE
Well if anyone knows where I can find the nismo fsb and/or the es fsb bushings, it would be greatly appreciated
2006 Sentra 1.8 SE
I also have the nismo FSB which i haven't gotten around to install yet. So the bushings that the bar comes with didn't work well for you? how was the fitment on your gxe?
The bracket for the gxe and the SE-R are different. The gxe bracket is a bit more narrow since the stock bushings are smaller. The SE-R bracket has a wiser groove to fit the thicker stock SE-R and Nismo bushings.
I had the stock gxe bracket being used with the stock SE-R bushings with my Nismo FSB (I bought mine used without nismo bushings).
That being said, the bushings would fit fit but not 100% properly hence creating all of this popping and squeaky sound in my suspension
As a temporary remedy, I placed 2 washers under each bracket bolt to "raise" the bracket and allow the SE-R bushings to fit in a little more properly. I have ordered the SE-R brackets so it'll be a matter of time until I can have a proper install on my fsb.![]()
2006 Sentra 1.8 SE
Well, just a follow up. I replaced my old SE-r bushings for a new set plus installed the proper SE-R brackets. The older 1.8 bracket were damaging the much thicker SE-R ones I had therefore it made an unpleasant gap in the bushings.....resulting in squeaky noises everytime I went over a bump lol.
2006 Sentra 1.8 SE
one of he vendors on here sells replacement bushing for the eibach fsb, they are eibach fsb bushings but they may work.
do you have the bracket part number by any chance for the ser and did you have to use new bolts, etc?
Energy Suspension Parts: Sentra, Nissan Sentra 2006
check this out
