Background:
Few years ago I found out that sometime before I had bought my car, the brakes had been changed. Found this not to be a good thing because whomever had changed the brakes stripped the bleeder valves. This became a problem for me when I needed to change my brakes. I ended up having to use a mill, insert threads to the closest match bleeder screws I could find....not fun. This worked, to an extent, not the best holding under high temps. Well I just found out on the way home I'm soon to need new front brakes, again.
So anyways, from my memory most aftermarket brake sets are for non-brembo equipped spec-v's. idk if this is true for the z32 or g45/j30 swapped specs. But was kinda looking to find out what options I have. I dont really wanna spend $1500 on a new brake set. But if there's any good options please lemme know any parts I would need and approx price. I'd appreciate it
Just do Karl's under 500 z32 upgrade.
http://www.b15u.com/sentra-specific-...nder-$500.html
