Results 1 to 20 of 27
    Corey Vamp2RLR is offline
    Sep 2009
    PA
    Default Lowering questions
    Is lowering a spec the same as a honda and you have to get new bolts for the bottom because they break? and if im just using lowering springs will a 17x8 rim rub?
    Vamp2RLR
    2 Redlights Racing
    http://www.cardomain.com/ride/3861070
    Default Re: Lowering questions
    No you don't need new bolts
    Sep 2009
    PA
    ok what about the rim size? any idea on that?
    Vamp2RLR
    2 Redlights Racing
    Quote Originally Posted by Vamp2RLR View Post
    It depends, some springs drop much lower than others.
    Sep 2009
    PA
    ive got megan racing springs
    Vamp2RLR
    2 Redlights Racing
    Discussed a bunch of times...quick search for 17x8 would answer your question
    [ame="http://www.b15u.com/showthread.php?t=8351"]Flush Status - B15U.com - Nissan Sentra Forum[/ame]
    Sep 2009
    PA
    thanks ash and i am eventually going to get ksports but my gf got me the megan springs for christmas so i have to use em so she dont get hurt fealings but im not to very knowledable on the offsets and all that good stuff but the wheels i want are rota p45r 17x8 and like they were saying in that thread about the "flush" look idk how to go about checking and making the spacers and tire sizes
    Vamp2RLR
    2 Redlights Racing
    the rim wont rub..but the tire might
    by 8 if u go 235/40 its a very close revs/mile which means same overall circumference so it will be very close to a stock size...offset of the wheel will depend as well
    05 spec - silver
    Sep 2009
    PA
    Quote Originally Posted by tweb14 View Post
    does the revs/mile matter other than making the speedo off? and i actually just check and that rim only comes in a 17x9 with +25 offset doesnt come in a 17x8 so now im confused on if they will even work with stock suspension being lowered or if id have to get the ksports b4 i get them or if id just have to get a different set of rims
    Vamp2RLR
    2 Redlights Racing
    You will run into a lot of issues trying to fit a 9" wide rim with a +25 offset without a lot of serious fender modification.
    I'd look into different rims.
    yes cuz your abs uses a speed sensore. u cant have it too off, but less than 5% circumference differnce wont matter much
    05 spec - silver
    Sep 2009
    PA
    what kind of modification are you talking about?
    Vamp2RLR
    2 Redlights Racing
    Sep 2009
    PA
    what will happen if its to far off?
    Vamp2RLR
    2 Redlights Racing
    abs wont work properly, and speedo will be off
    05 spec - silver
    Sep 2009
    PA
    speedo isnt an issue with me ive delt with a speedo that never worked in the winter before lol but the abs would be an issue
    Vamp2RLR
    2 Redlights Racing
    your brakes will still work the same, just the abs system will be messedup
    05 spec - silver
    Sep 2009
    PA
    will it like over time mess the entire system up or just as long as the wrong size tires are on?
    Vamp2RLR
    2 Redlights Racing
    cant really be sure...if anyone has done this before, chime in here. usually as long as there the wrong size tis messed up and nothing physically breaks so it should go back to normal when u fix it
    05 spec - silver
    Sep 2009
    PA
    thats good then any any idea why everybody has been splattered? its kinda annoying
    Vamp2RLR
    2 Redlights Racing
    Muahahaha, you see the egg under our names? Give it a go.
    Sent from my T-Mobile G1 using Tapatalk
  1. Internet Questions
    By Scrapin in forum Open Bar
    Last Post: 12-06-2009, 09:58 PM
  2. Questions
    By shaun11423 in forum Naturally Aspirated (NA)
    Last Post: 10-12-2009, 01:34 PM
  3. JL questions...
    By deadforever629 in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 08-11-2009, 01:01 PM
  4. new B15... few questions
    By dapcwiz in forum B15 Sentra (2000 - 2006)
    Last Post: 06-20-2008, 01:12 AM
  5. Safc II questions
    By b15nyc in forum B15 Sentra (2000 - 2006)
    Last Post: 02-17-2007, 01:37 PM
