Anyone know how to wire a shift light w/o the tach driver OR wire the MSD Tach Driver then my shift light on it. And Anyone got good ideas where to hook my shift light, i dont want anyone to see it, maybe behind a duck vent...... good idea ?!?!
MSD tells me that:
Red: Input, connects to the ignition 12 volt supply coming from the ignition switch.
Red/Green : Output, connects to the coil positive wire.
Black: Connects to engine ground.
Gray: Tach output signal wire. Connects to the Tach trigger wire or other rpm
operated component.
so where do i connect the Red/Green wire, only on 1 coil wire? on all 4 wire?
MSD tells me that:
operated component.
