P0171 and slow-fill gas tank, 2000 SE
Results 1 to 12 of 12
  1. #1
    Jun 2010
    Likes Received
    0
    Default P0171 and slow-fill gas tank, 2000 SE
    2000 Sentra SE, 2.0
    Hello, I'm new.
    I can't get an inspection sticker until I solve the code problem. I'm getting a P0171. Its been a problem for a few years. I have paid mechanics about $600 to replace one O2 sensor, installed a new fuel pump, cleaned the MAF. But the engine light remains on.
    I don't know if this symptom is related or not. The gas tank fills very slowly - at about 1/4 speed, tops. Is the Evap system connected to the P0171?
    While looking for vacuum leak in the engine compartment I found one hose coming from the crank case with an open end. I don't know if it is venting something. The hose running parallel with it, goes to the MAF box.
    I am at wits end trying to find this problem and am considering a MIL eliminator splice.
    I heard that 2000 Sentra SE 2.0 are noted for bad MAFs. I have heard that aftermarket MAF cause problems. Is that true? A OEM Mass Air Flow from Napa runs $900.
    And ideas for this newbie would be appreciated.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Apprentice Chris
    Aug 2006
    Holtsville, Long Island
    Drives
    2004 Spec V Turbo
    Likes Received
    Default Re: PO171 and slow-fill gas tank, 2000 SE
    sounds like a bad ecu to me
  4. #3
    Jun 2010
    Likes Received
    0
    The problem with many forums is the constant tech-speak and acronyms. I am trying to find the meaning of "ECU".
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Apprentice Chris
    Aug 2006
    Drives
    2004 Spec V Turbo
    Likes Received
    If you don't know what ecu means you should stay at least 10ft away fro cars at all times.
  7. #5
    Jun 2010
    Likes Received
    0
    I see you are an 'apprentice'.
    I came here because I wanted to learn. You could have told me what "ECU" stood for, rather than mock my ignorance.
    So I went to the acronym dictionary and found about a dozen different abbreviations and acronyms for "ECU" so I took a good guess.
    There are also just under a million other acronyms and abbreviations. I'm sure that nobody knows most of them. Thats why they print dictionaries.
    You can mock people for their ignorance or help them to learn. But mocking somebody's ignorance makes you feel superior, I guess thats the way you are. I'm sorry for you.
    I'll find my answers elsewhere.
  8. #6
    Member Ashwin
    Dec 2005
    NYC
    Drives
    '03 QR25DE-T
    Likes Received
    645
    Take a look at this thread and let us know if anything works
    Sentra SE (2L), 2001, P0171 (Syst. too lean-bank 1) - Nissanhelp.com Forums
  9. #7
    Supporting Vendor Peter
    Oct 2009
    Meriden, CT
    Drives
    '03 Spec-V
    Likes Received
    414
    Here you go straight from Nissan ASSIST, hopefully you'll be able to read it, basically check for leaks first before anything
  10. #8
    Newbie Josh LaPointe
    Jun 2010
    Eastern CT
    Drives
    2001 Sentra SE w/PP
    Likes Received
    0
    Heres the pages outta nissans FSM for that code.
    2001 Nissan Sentra SE w/PP
    http://www.cardomain.com/ride/3830451
    2005 Nissan 350Z Roadster
    http://www.cardomain.com/ride/391521...ng-roadster-2d
    1995 Nissan 200SX SE-R *SOLD*
  11. #9
    Oct 2009
    Meriden, CT
    Drives
    '03 Spec-V
    Likes Received
    414
    Quote Originally Posted by Nismo4life11 View Post
    There you go even better, ASSIST at my dealer doesn't allow me to save pdf files, cuz all we have is the reader
  12. #10
    May 2010
    Likes Received
    0
    the loose hose on the crankcase- thats probably your 171. unmetered air = lean condition.
    As for the slow filling of the gas tank, i would blow the vent tube out with compressed air. sounds like its maybe not venting and the fuel your putting in is not displacing air. but technicaly, you should have a cannister vent control valve code if this were happening. who knows, try blowing the vent tube out anyway.
    I'll go ahead and tell you now, the lean condition and the slow filling of the tank are two seperate unrelated issues.
  13. #11
    Jun 2010
    Likes Received
    0
    Default Re: P0171 and slow-fill gas tank, 2000 SE
    Knowing that the slow-fill gas tank and the 171 are separate conditions is a big help. Thanks.
    I spray-cleaned the MAF tonight and will bench test it tomorrow. Acronyms are killing me, lol. I'm looking for definition of 'GAF".
    I downloaded the service manual - Engine Control, but it seems to be written in tech-speak, not for nimrods like me.
  14. #12
    Jun 2010
    Likes Received
    0
    I cleaned the MAF and then did the DTC procedure called for in EC306. The manual didn't say so, but I guess that procedure allows the computer to re-learn to codes (?)
    It said that the engine might be hard to start and that might indicate fuel injection problems. Not only is it hard to start but barely runs, sounds like its starving for gas, has no power, will only do about 40mph. With all the engine code problems, the Sentra has NEVER run bad in 10 years, until now.
    The good news, is that I have no codes. The bad news is the car feels like its running on 2 cyls.
    What did I do wrong??????????
  1. Aluminum Coolant Overflow Fill Tank
    By jdm-spec in forum B15 Sentra (2000 - 2006)
    Last Post: 05-19-2010, 12:12 PM
  2. FS: Metal Gas Tank
    By maxtrodriguez in forum Parts for Sale
    Last Post: 05-16-2010, 12:42 PM
  3. Gas Tank
    By OGlaughzalotzz in forum Troubleshooting and Support
    Last Post: 02-19-2010, 07:28 AM
  4. WTB: 2000+ windshield wash fluid tank
    By boog in forum Parts for Sale
    Last Post: 11-25-2008, 04:37 PM
  5. need new gas tank
    By dawhitespecv in forum Parts for Sale
    Last Post: 02-27-2008, 12:16 PM
