Koni yellow's and Eibach sportline springs question
Results 1 to 10 of 10
  1. #1
    Mar 2010
    Likes Received
    0
    Default Koni yellow's and Eibach sportline springs question
    hello to everyone who reads this!!!!
    I was lucky enough to get Koni yellow shocks for the front and back. I read up that Koni yellow work grate with Eibach Springs and I got them too. The question is, does anyone else has this setup and could tell me which is the best stiffness setting for the shocks? its just pain to take them rear shocks out in order to adjust them...
    well, thanks a ton
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Jeremy
    Jul 2009
    calipornia
    Drives
    04 spec
    Likes Received
    48
    somewhere in the middle will be ok for the street depending on the springs rates you got. if they are the pro kits.. stick with the middle as a general rule of thumb.
  4. #3
    Mar 2010
    Likes Received
    0
    thanks, but how to know to which settings to set the shocks if I know what spring rate I have?
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    BDSF Karl
    Feb 2010
    Oakland, CA
    Drives
    Audi B8 S4, FF Turbo SpecV
    Likes Received
    1906
    You can adjust the rear shocks without taking them out, you just have to pull back some of the trunk liner to get access to them. I would set them at the stiffest setting, then go back until the ride gets bouncy.
  7. #5
    Mar 2010
    Likes Received
    0
    actually you cant, they are ajusted only when you compress them all the way down. Otherwise you ill just turn the knob with out any results.
  8. #6
    Jul 2010
    Honolulu, HI
    Drives
    2002 SER
    Likes Received
    0
    ^^^ well, i know for a fact you do not need to compress the rears for dampening adjustment; however, the fronts do need to be compressed. I had this set up on my b14 paired w/ 450/400 spring rates. Like the man said, turn them to the stiffest setting and go from there as far as tuning the dampener.
  9. #7
    Mar 2010
    Likes Received
    0
    k I will do so, thanks much
  10. #8
    Apprentice Chris
    Feb 2010
    Coppell
    Drives
    06 SpecV
    Likes Received
    28
    Quote Originally Posted by diabolichippo View Post
    no fronts don't need to be compressed rears do. fronts can be adjusted on the fly where as the rears have to be taken apart. unless you have some new version that are different than mine...
  11. #9
    Jul 2010
    Honolulu, HI
    Drives
    2002 SER
    Likes Received
    0
    Quote Originally Posted by veeeeee View Post
    ^^^ lol, my bad, I just re-read what i wrote.
  12. #10
    Newbie Adam
    Sep 2009
    Little Rock, AR
    Drives
    03 Spec V
    Likes Received
    8
    I have the rears set half way stiff, and the fronts on full soft for driving around still a little rough and i have pro-kits...
    Built HQR25DET running on a MS2 and a whole lot of other goodies
  1. WTB: Eibach prokit rear springs only
    By black06spec-v in forum Parts Wanted
    Last Post: 07-28-2010, 10:50 PM
  2. F/S:EiBach Prosport Lowering Springs & KYB Struts
    By Blackout_03SpecV in forum Parts for Sale
    Last Post: 03-22-2010, 09:35 AM
  3. WTB: Eibach Sportline Springs
    By evil_twin in forum Parts Wanted
    Last Post: 03-09-2010, 12:36 PM
  4. FS: Eibach Pro-Kit springs + More!
    By 04specvnj in forum Parts for Sale
    Last Post: 09-29-2009, 10:52 PM
