Written By: RedDragonV09
Remove the A-pillar cover if this is where you are mounting the light. Route the cable down the pillar into the hole next to the small vent. The cable will come out right above the fuse box.
Disconnect negative battery terminal. Remove the top steering column cover (3 screws on bottom).
Remove the trim ring around the gauge cluster (2 screws on top). Pull out the gauge cluster (3 screws, 1 top 2 bottom). The gauge cluster will not pull out very far.
Remove the cover under the steering wheel. (2 screws, 1 on fuse block, 1 to the right of the wheel). Splice the Red (+12V) wire into the green wire on the fuse block harness (1).
Splice the Green (tach) wire into the blue/orange stripe wire on the white harness behind the gauge cluster (2). Attach the Black (ground) to the chassis (3). Mount one of the brackets to the A-pillar cover with a short screw.
