FS: Kicker ZX1000.1 Amp and 2 Kicker 06S12L72 Solo-Baric L7's
Results 1 to 9 of 9
  1. #1
    Senior Member Fred
    Nov 2010
    San Diego
    Drives
    2003 SER Spec V
    Likes Received
    89
    Thumbs up FS: Kicker ZX1000.1 Amp and 2 Kicker 06S12L72 Solo-Baric L7's
    Like the title says. I am selling my audio set up. Up for grabs are a Kicker ZX1000.1 Amp and 2 12" L7's. I bought these brand new and they still work flawless! I am selling because I need the trunk space. My loss is your gain. I'm asking $500 plus shipping. I paid over $500 alone for the Amp brand new, so I think this is a fair deal. PM if interested.
    Here are the specs:
    Kicker ZX1000.1 Amplifier Features:
    • ZX Series Class D Monoblock Car Amplifier
    • RMS Power Rating:
      • 4 ohms: 500 watts x 1 chan.
      • 2 ohms: 1000 watts x 1 chan.
    • Max power output: 1000 watts x 1 chan.
    • MOSFET power supply
    • Wired remote bass level control included
    • LED power and protection indicators
    • Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
    • Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
    • Eliminates unwanted noise in a system
    • Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
    • Bridgeable operation
    • Speaker-level inputs compatible (switchable) through RCA connection
    • Preamp RCA outputs
    • Automatic turn on modes: remote, DC offset, or signal sense
    • Thermal, voltage, and short circuit protection circuitry
    • Variable low-pass filter (50-200 Hz, 24 dB/octave)
    • Subsonic Filter (24 dB at 25 Hz)
    • CEA-2006 compliant amplifier
    • Frequency response: 25-200 Hz
    • Dimensions: 16-3/4"L x 9-5/8"W x 2-1/8"H
    Kicker 06S12L72 Solo-Baric L7 Series:
    • 12" Dual 2 Ohms DVC L7 Series Subwoofer
    • Power Handling:
      • Peak: 1500 watts
      • RMS: 750 watts
    • Impedance: Dual 2 ohms
    • Aluminum deposit cone -- a beautiful look with less cone flex and less distortion
    • Santoprene rubber surround
    • Rear-cone brace for added strength to reduce cone flex under stress
    • Massive surround radius provides increased excursion for low bass output and higher SPL
    • BAM (Basket and Motor) Enhanced Assembly: new for 2004 -- cast aluminum basket featuring low profile/open design that provides a solid anti-resonant foundation for the motor assembly
    • Perimeter venting which relieves pressure for a more linear response and aids in keeping the voice coils cool
    • Patent Pending Stitched Surround that aids in preventing cone/surround separation at high excursions
    • Sleeved high-power tinsel lead wires to resist lead breakage
    • Spring-loaded nickel plated terminals for solid connections with large gauge speaker wire
    Manual for Amp:
    http://kicker.com/sites/default/files/2008 ZX 1000 1500 2500-1 e01 web.pdf
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Aug 2010
    East Chicago, IN
    Drives
    02 Spec V
    Likes Received
    How much just for the L7's!?!?!!!!
  4. #3
    Senior Member Fred
    Nov 2010
    San Diego
    Drives
    2003 SER Spec V
    Likes Received
    89
    Quote Originally Posted by AztecSpecV View Post
    $225 + Shipping.
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Aug 2010
    East Chicago, IN
    Drives
    02 Spec V
    Likes Received
    Do they come with a box? And how much do they weigh? Becuase idk how much shipping would be to 46312(Indiana)
  7. #5
    Senior Member Fred
    Nov 2010
    San Diego
    Drives
    2003 SER Spec V
    Likes Received
    89
    I have to find a box for them. They weigh 25lbs each according to the net. Ill try to get you a rough qoute in a few, and will confirm tomorrow.
  8. #6
    Senior Member Fred
    Nov 2010
    San Diego
    Drives
    2003 SER Spec V
    Likes Received
    89
    ^^ PM Sent!
  9. #7
    Senior Member Fred
    Nov 2010
    San Diego
    Drives
    2003 SER Spec V
    Likes Received
    89
    Bump for some Bumps!
  10. #8
    Senior Member Cornelio
    Sep 2010
    Mesa, AZ
    Drives
    02 Spec V
    Likes Received
    484
    the amp shipped to 85204 AZ
  11. #9
    Senior Member Fred
    Nov 2010
    San Diego
    Drives
    2003 SER Spec V
    Likes Received
    89
    PM sent.
  1. Kicker ZX350.4 amp with 4 gauge wiring
    By xbrandonx in forum Miscellaneous Classifieds
    Last Post: 11-04-2010, 07:48 PM
  2. 10" Kicker L5, Alpine amp
    By bigalex827 in forum Miscellaneous Classifieds
    Last Post: 09-28-2010, 12:33 PM
  3. FS: 10" Kicker Sub/Amp/Box Combo
    By 04mojogt in forum Parts for Sale
    Last Post: 08-30-2010, 01:00 PM
  4. Kicker ZX300.1 Amp
    By b15duh in forum Parts for Sale
    Last Post: 06-02-2010, 01:18 PM
  5. Kicker Wire...4awg & 16awg
    By mavster in forum Parts for Sale
    Last Post: 01-15-2008, 01:09 AM
