Keep your rotors from rusting
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
  1. #1
    Newbie Cody
    Oct 2010
    NH
    Drives
    2002 Spec V
    Likes Received
    0
    Default Keep your rotors from rusting
    Im sure it has been done. This is a simple how-to, i just got great results and wanted to share with all of you guys.
    First brake clean your rotors and clean all the debris off.
    Then cover the entire rotor with Caliper paint i used black.
    Once installed the paint the touches the brake pad will rub off. The unused part of the rotor will still be painted, which prevents rust and make your rotors look nice.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Member Ashwin
    Dec 2005
    NYC
    Drives
    '03 QR25DE-T
    Likes Received
    645
    how long have you had them painted for? I tried this before, lasted about a couple months before going back to crap lol
  4. #3
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    hes had it for a couple months now and it still looks new. no peeling or anything. he got pretty generous with it on the "hat" part of it and in the slots
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Red '02 - Because I'm crazy
    Blue '94 Miata - for the ladies
    Gray '07 Prius - Dat eco doe..
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Senior Member Matt
    Feb 2011
    Palmetto, FL
    Drives
    2004 SE-R Spec V
    Likes Received
    389
    Omg I want! I know what my next weekend project it lol that and repainting the door/window molding :-)
    Sent via Tapatalk with my HTC Evo 3D... Android ftmfw!
    2004 Cloud White Spec V -
    Performance - 2JR Parts: 11.5:1 CR Pistons, H-Beam Rods, Race Header, Ported Head, Intake Manifold & 1 Piece CAI, Side Exit Exhaust (race version), Solid motor mounts, Crossmember Bushings, Bump Steer & Roll Center Kit, Wilwood 4-Piston Dynalites w/12.2'' Rotors in Front & 12.3'' Rear Brakes, BC 10k (F&R) Coilovers, 15mm (F) & 20mm (R) Spacers, Powder Coated Gloss White Nismo Wheels, Turcite X Shifter Bushings & Short Throw Shifter, 2JR Shift Knob, LCAs w/SuperPro Bushings, Solid Rear Trailing Arm Bushings, Rear Sway Bar, Crank & PS Pully, 10mm ALK, JWT BSR Kit, Radiator Cap, Innovate MTX-L Wideband, UpRev Tuned.
    Visual - B16 SER Seat Swap, Black LED tails, Black Faux Suede headliner & dyed remaining plastic black to match, matching suede shift boot & arm rests, 8k HID's for Fogs & Headlights, Fog Light always on mod, Angel Eye Gauges.
    Audio - Sony Xplod 1000watt sub amp and 12'' Xplod sub in a custom spare tire well box, Kicker mid's n highs running off JVC Bluetooth Deck.
  7. #5
    Jun 2011
    Drives
    02 Altima
    Likes Received
    5
    cool...and the pads don't have trouble grabbing later?
    [12-14-2011 03:11 PM] formerHonda: degreaser shouldn't hurt a maf should it? as far as cleaning I mean
  8. #6
    Senior Member MIKE
    Nov 2009
    STATEN ISLAND
    Drives
    02 maxima
    Likes Received
    17
    i used rustoleum paint..i forgot the exact name cuz it was like maple syrup thick and its been good as hell for 2 years on my brakes and rotors... also painted my rear beam control arms and many many other things with this paint and holds up amazing
    02 6speed fully bolted maxima SOlD
    08 6SPEED BMW E90 M3 - NEW BABY
  9. #7
    Member Ashwin
    Dec 2005
    NYC
    Drives
    '03 QR25DE-T
    Likes Received
    645
    Damn I used rustoleum too...I guess I failed lol
  10. #8
    Newbie Cody
    Oct 2010
    NH
    Drives
    2002 Spec V
    Likes Received
    0
    Quote Originally Posted by Unclear_Motives View Post
    The paint wears off during the break in process. My hawk hps+ works wonders.
  11. #9
    Jun 2011
    massachusetts
    Likes Received
    24
    i had a set of powder coated rotors, those didnt last long before they started peeling after the fist winter. they did look really nice tho
    Aztec 02 Nissan Sentra SE-R Spec V, 292k miles
    -blown head gasket @153k, original clutch!
    Black 02 old vq swap, 150k miles
  12. #10
    Jul 2011
    Likes Received
    0
    I wonder if high heat enamel would work. It's pretty durable so I'm guessing it would last longer than regular caliper paint.
    Tapatalk is gay. AtleastIdidntpayforthis.
  13. #11
    Senior Member Erick
    Feb 2010
    East Los Angeles CA
    Drives
    2002 I/H/E Spec V
    Likes Received
    400
    i bought some rotors from craigslist that were manufactured in Germany and until this day they dont rust at all it remains grey looking like new except for the part where it makes contact with the pads. I had the rotors on for about a year now still no rust!
  14. #12
    Newbie Cody
    Oct 2010
    NH
    Drives
    2002 Spec V
    Likes Received
    0
    Quote Originally Posted by GK1707 View Post
    Why would you need it to with stand more heat? Caliper paint is high heat and it worked fine for me.
  15. #13
    Jul 2011
    Likes Received
    0
    Doesn't really have anything to do with heat. I'm just sayin that high heat enamel would most likely last longer than caliper paint.
  16. #14
    Newbie Cody
    Oct 2010
    NH
    Drives
    2002 Spec V
    Likes Received
    0
    Maybe it will, if you do end up doing it that way let me know.
  17. #15
    Newbie Cody
    Oct 2010
    NH
    Drives
    2002 Spec V
    Likes Received
    0
    Quote Originally Posted by E.L.A.SpecV02 View Post
    Damn you know what brand?
  18. #16
    Jun 2011
    massachusetts
    Likes Received
    24
    after rereading this, for those confused. you take yout wheel off to paint, obviously, and you paint your rotors and calipers this way. if you spray where the pad rubs the rotor, just spin the rotor while the caliper is on and it will move some of the paint from the braking surface. if you were painting caliper as well, just spray the paint off the pads with brake cleaner before you paint the caliper. the remaining paint will rub off the braking surface of the rotor during braking. dont forget, after this all drys, to clean your greasy prints off the rotors before reassembly
  19. #17
    Senior Member Pete
    Jan 2011
    Anoka, MN
    Drives
    1991 SE-R QR-T
    Likes Received
    798
    Quote Originally Posted by i68k View Post
    how bout you just spray the whole rotor, let it dry, and go drive it lol... just sayin
    "I think we need to do a little street racing 101 and understand that, you know... as a general courtesy you should, uh, floor your car an additional 100mph over the speed in which you start. It's just like the, uh, '100mph courtesy'... You start at 60, you don't let off 'til 160. You start at 30, you AT LEAST go to 130. And attempting to, uh, run like Houston interstates with traffic directly in front of you... These 60 to 80 pulls; these 60 to 95mph pulls... What the fuck is that shit about?" -IMV Films
  20. #18
    Jun 2011
    massachusetts
    Likes Received
    24
    if you slapped on multiple layers of paint and let it dry, it might be a long while before it wears off, if you can even get the caliper back on it. spinning the rotor wet just moves 'some' or most of the paint off the brake surface so itll be easy to wear off/clean off after, esp when you can see where the pad contacts the rotor.
  21. #19
    Senior Member Pete
    Jan 2011
    Anoka, MN
    Drives
    1991 SE-R QR-T
    Likes Received
    798
    if you slapped on multiple layers of paint and let it dry, it might be a long while before it wears off, if you can even get the caliper back on it. spinning the rotor wet just moves 'some' or most of the paint off the brake surface so itll be easy to wear off/clean off after.
    i doubt it would be long before its off... slowing a car down from 100mph to 40mph a couple times during pad breakin would probly do the trick
  22. #20
    Jun 2011
    massachusetts
    Likes Received
    24
    lol, i didnt think about using new pads, was thinking about getting paint on the old pads before i replace them, that way you get new pads, and clean the brake surface of the rotor that you can see from the rotating pad marks with gas or brake cleaner before it completely dries, but if you didnt clean the rotors, then youd have to just let it rub off. i mean really, are we painting under the hat too? inside the groves?
  1. anyone using or know about these rotors ?
    By sash in forum Suspension, Chassis & Braking
    Last Post: 07-08-2011, 06:58 AM
  2. slotted rotors
    By sikiller15 in forum Suspension, Chassis & Braking
    Last Post: 03-15-2011, 10:37 AM
  3. Need ur used brembo rotors
    By xxrjk22xx in forum Parts Wanted
    Last Post: 02-21-2011, 12:32 AM
  4. Brembo rotors
    By NotNormal85 in forum Suspension, Chassis & Braking
    Last Post: 11-17-2009, 05:18 PM
  5. I need rotors
    By B15NewYork in forum Naturally Aspirated (NA)
    Last Post: 03-08-2006, 10:35 AM
