se-r vs spec v ecm?
Results 1 to 14 of 14
  1. #1
    Aug 2010
    Hackensack NJ
    Drives
    02 Spec V
    Likes Received
    Default se-r vs spec v ecm?
    I just fried my ecm & im looking for a replacement so just out of curiosity. Is there A difference between ser and spec v ecm?
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    03 spec V, 02 specv,Passat,f150,Kawasaki Vulcan,Fleetwood Flair, also drives neighbors crazy!
    Likes Received
    219
    Curious also how can you tell it is fried? I am sending mine out for test and rebuild.Wat were your symptoms?
  4. #3
    Aug 2010
    Hackensack NJ
    Drives
    02 Spec V
    Likes Received
    I have code p1111 and the car wont start. followed the procedure and ended up with that conclision.
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    Likes Received
    219
    I am sending mine to these guys
    http://www.aesmodules.com/
  7. #5
    Nov 2010
    HI
    Drives
    '03 Spec V/ '08 GSXR 750/ '07 RS4
    Likes Received
    403
    yes there is a difference, spec had 10 more hp(flywheel) and the only had manuel trannies. thats it as far as I know
    The Vagabond
    "Be polite, be professional, but have a plan to kill everybody you meet." General James Mattis
  8. #6
    Senior Member Jeremy
    Jul 2009
    calipornia
    Drives
    04 spec
    Likes Received
    48
    that difference came from the exhaust mostly and those are "claimed" numbers. marketing hype
  9. #7
    Senior Member Lenny
    Nov 2010
    The Salty D, CA (619)
    Drives
    05 SE-R + 2010 Genesis 3.8 sedan
    Likes Received
    167
    Quote Originally Posted by jeremy View Post
    I thought it was due to the se-r's auto tranny robbing power? and yes that is a "claimed" # but i heard it was actually around a 5hp difference after further research & testing (Se-R owners, not Nissan's R&D team)
    ~05 Sentra SE-R~/03 Front End retrofit/Nismo CAI/Koyo radiator/Mishimoto Dual Fan shroud/2jR BRS/2jR Medusa header/2jR 2.5in midpipe w/Magnaflow Hi Flow cat/2jRacing Medusa 3in catback/JimWolfTech BSR kit/ES MMI's/2jR lightweight pulley/+2 timing advance via Consult II/D2 coilovers/2jR LCA's /16in Avid1 AV-12/Goodridge SS brakelines/ R1 Concepts Cross Drilled rotors/ceramic pads/215/45/16 Falken Azenis/SpecV front seats/Depo tailights(tinted red)/2jR 03 Yellow fog lights+fog light mod/Sony MEX BT4100P Bluetooth deck/840 watt DHD amp/Kicker Comp 12 sub+ ported box/Cobra radar detector...more to be installed
  10. #8
    Senior Member Lenny
    Nov 2010
    Drives
    Likes Received
    167
    There's also a guy on here w/ na VQ swap still using a regular se-r ecm, so it should be ok...I think???
  11. #9
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Eh....huh? How is a 4 cylinder ecu working for a 6 cylinder engine?
  12. #10
    Senior Member Lenny
    Nov 2010
    Drives
    Likes Received
    167
  13. #11
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Well that doesn't say automatic QR ECU. That just says automatic, assuming it's an automatic VQ ECU.
  14. #12
    Senior Member Lenny
    Nov 2010
    Drives
    Likes Received
    167
    Quote Originally Posted by snoopSER View Post
    I wasn't saying I was 100% sure
  15. #13
    Aug 2010
    Hackensack NJ
    Drives
    02 Spec V
    Likes Received
    So as long as the ecm is not for an automatic the ser ecm should b ok? ser only come with a 5 speed not 6 like the spec v right?
  16. #14
    BDSF Karl
    Feb 2010
    Oakland, CA
    Drives
    Audi B8 S4, FF Turbo SpecV
    Likes Received
    1921
    Quote Originally Posted by redline_spec_v View Post
    02 SE-R's came with either a 5-speed or auto. Not sure if the 5-speed will work, but I don't see why not.
  1. need help ecm problem?
    By SE-R Kid in forum Troubleshooting and Support
    Last Post: 12-21-2010, 08:55 AM
  2. QR25DE ECM need
    By Geoman03v in forum Parts Wanted
    Last Post: 09-23-2010, 12:36 AM
  3. ecm
    By htzfrmthebong420 in forum Parts Wanted
    Last Post: 07-24-2010, 01:55 PM
  4. Swap 5P and 5L ECM
    By ash in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 06-07-2010, 04:55 PM
  5. WTB 2004 spec ecm wire harness
    By xheislegendx05 in forum Parts Wanted
    Last Post: 01-16-2010, 02:05 PM
