Valor sd 900w dvd player question
Results 1 to 10 of 10
  1. #1
    Newbie Streetz
    Sep 2011
    Suffolk, VA
    Drives
    03 SE-R Spec V
    Likes Received
    Default Valor sd 900w dvd player question
    Ok So I recently purchased a dvd player for the spec. I forgot when it was installed to have the adaptor cord plugged in to be able to plug in my phone and play music. Now my question. I want to pull it out and plug that cord in simple enough. My question is can I connect a ps2 into the dvd player as well? I have been looking online since I bought it off craigslist I didnt get the owners manual. heres there specs I have found on it...
    Expandability Options:
    2 Sets of 2V preamp outputs (front and rear) + 1 mono subwoofer output
    Front-panel auxiliary input: 3.5mm (headphone jack) allows connection to portable media devices such as MP3 players, etc.
    Rear auxiliary input: RCA Audio input
    Includes RCA to 3.5mm adapter cables
    Rear video output: 2 Rear video RCA composite outputs
    Steering wheel remote ready with the universal PAC SWI-X
    Hoping someone will know this. I would rather pull every thing apart once and dont want to but the system if its a no go.
    I have uploaded two pics. one is a stock pic of back and one kind of shows wiring diagram roughly. Thanks for any help.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    BDSF Karl
    Feb 2010
    Oakland, CA
    Drives
    Audi B8 S4, FF Turbo SpecV
    Likes Received
    1921
    The specs you listed doesn't show an RCA video input, but the rear looks like it does. If it has one, you can hook the PS2 up no problem.
  4. #3
    Newbie Streetz
    Sep 2011
    Suffolk, VA
    Drives
    03 SE-R Spec V
    Likes Received
    I'll check rest of specs an see thanks
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Newbie Chris
    Feb 2010
    North Texas
    Drives
    04 spec v
    Likes Received
    37
    Yes you can. I used to have one of these in my X-terra and I had a gamecube hooked up.
  7. #5
    Newbie Streetz
    Sep 2011
    Suffolk, VA
    Drives
    03 SE-R Spec V
    Likes Received
    Sweet thanks for info. Well I guess now I just need power converter n I can hook up ph cord n ps2 tomorrow after work.
  8. #6
    Newbie Streetz
    Sep 2011
    Suffolk, VA
    Drives
    03 SE-R Spec V
    Likes Received
    Ok question. I hookined up aux cables to play ph through car. Now if I hook up ps2 would I have to plug it in the same aux cables as the cable to plug in phone? If so does anyone know if theres a way to "expand" the lenght of the aux cables to be able to quick connect right under the glove box so if i wanna play ps2 i can connect or if i wanna listen to the ph i can connect it up. If that makes sense. Or are there a second set of aux cables that the ps2 can hook up to?
  9. #7
    Newbie Streetz
    Sep 2011
    Suffolk, VA
    Drives
    03 SE-R Spec V
    Likes Received
    Ok could use some knowledge or advice. I have connected aux an video cable turn on ps2 hear everything see nothing. So is that because it shows the two yellow video output not input? An is there a way to make it input?Thanks.
  10. #8
    Newbie Chris
    Feb 2010
    North Texas
    Drives
    04 spec v
    Likes Received
    37
    Do you have any video inputs? I had a valor dvd player and it had two inputs and two outputs. If there are no video inputs then I guess you cant use the ps2.
  11. #9
    Newbie Chris
    Feb 2010
    North Texas
    Drives
    04 spec v
    Likes Received
    37
    I looked up your model number and it looks like it is different from the one I had. Yours is made with two outputs for auxilary monitors in the backseat. It has no video inputs only audio inputs. If you really want your ps2 in your car then your gonna have to upgrade. I will tell you from experience that having a gaming console in your car is more about looks than actually using it.
  12. #10
    Newbie Streetz
    Sep 2011
    Suffolk, VA
    Drives
    03 SE-R Spec V
    Likes Received
    Yeah figured it all out. Oh well it was just a do because I had the items so no sweat. Thats for the info. An one idea down so many more to go in its place.
  1. FS/FT: TV, PS1, dvd player
    By printerdanny in forum Miscellaneous Classifieds
    Last Post: 03-07-2011, 12:33 AM
  2. HU to a univeral dvd player
    By HeartTaeyeon in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 05-04-2010, 09:29 AM
  3. fs: overhead dvd player
    By jsk8r57 in forum Parts for Sale
    Last Post: 09-06-2009, 12:54 PM
  4. FS: Flipout dvd player
    By atomicguy7 in forum Parts for Sale
    Last Post: 05-16-2009, 11:01 PM
  5. FS: LCD TV/DVD PLAYER
    By b15nyc in forum Parts for Sale
    Last Post: 02-06-2007, 01:05 AM
