Crank pulley bolt size?
Results 1 to 20 of 20
  1. #1
    Dec 2009
    Likes Received
    135
    Default Crank pulley bolt size?
    What size is the crank pulley bolt just wondering so I can buy all the shit I need at once thanks for any help
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Dec 2010
    Likes Received
    30
    U dont need to buy another one brother, ur suppost to usee the stock bolt
    Sent from my Dell Streak using Tapatalk
  4. #3
    Dec 2009
    Likes Received
    135
    Ok lemme rephrase that what is the socket size that I need to get that bolt off and what are the torque specs?
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    Here's some torque info, as for socks size, if you have a socket set you should be fine. I want to say 20mm? Sorry I did mine a month ago.
    7. To torque the pulley down we used these two steps:
    a) Wedge a ratchet extension through the one of the holes in the UR pulley and one of the grooves in the engine cover. This will prevent the crankshaft from moving. With a torque wrench tighten the crankshaft bolt to 30-34 ft-lbs of torque.
    b) The head of the crankshaft pulley bolt has six lines, each representing 60 degrees of rotation. Choose one of the lines then place a mark on the UR pulley at that line (red mark pictured). Then mark the line on the bolt (we used a red mark) 60 degrees counterclockwise away from the mark on the pulley. Now torque the pulley bolt until both red marks meet. We were not able to get the red marks to meet, so we got them as close to each other as possible.
    2J Racing high power cold air intake, Nismo header, Nismo lower tie bar(not installed yet), Nismo rear sway bar,Nismo short shifter, 2J midpipe,stromung exhaust, Ksport coilovers, 2-J racing 10mm anti lift kit,2-J lightweight crank and power steering pulley, FI-R shifter bushings, Rob's air diversion panel, Rob's LTB wheel hop aid, More to come!
    Bsr, j30 front calipers yet to be installed…
  7. #5
    Dec 2009
    Likes Received
    135
    is this something i should be putting loctite on when reinstalling the bolt/nut whatevr?
  8. #6
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    I didn't, but you could if you wanted to.
  9. #7
    Senior Member Bob
    Jun 2011
    Des Plaines
    Drives
    2003 Spec-v
    Likes Received
    275
    don't locktite it. it will be a pain in the ass to get off in the future. i believe its a 17mm
  10. #8
    Apprentice Robzilla (robert)
    Sep 2010
    Bay Area Ca.
    Drives
    white 04 spec-v
    Likes Received
    13
    Quote Originally Posted by dragonfire2002 View Post
    when torquing the crank bolt after install is the second step necessary or can you just torque the bolt to 30-34 lbs and call it a day?
  11. #9
    Sep 2010
    Bay Area Ca.
    Drives
    white 04 spec-v
    Likes Received
    13
    *cough cough*
  12. #10
    Senior Member John
    Mar 2011
    Erin, Tennessee, United States
    Drives
    2003 Spec V, 2007 Expedition
    Likes Received
    131
    19 mm
    Go Tarheels! Go Panthers!
  13. #11
    Apprentice Jeff
    Aug 2009
    SD, CA
    Drives
    2005 Spec V
    Likes Received
    3
    I coulda sworn it was 20 as well, but i could be mistaken, did it almost a month ago. And no, you want a lot more than 30-34lbs of torque. I just used a breaker bar and tightened it as much as i could. IIRC it was stated that the OEM torque of the bolt is almost 150 lbs
    Just get a kit that includes between 17-22mm (as they seem to be of most use) and a breaker bar, 18" or so is what i used.
  14. #12
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    its a 21
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Red '02 - Because I'm crazy
    Blue '94 Miata - for the ladies
    Gray '07 Prius - Dat eco doe..
  15. #13
    Sep 2012
    Likes Received
    0
    The crankshaft pulley bolt size for my Nissan Sentra 2005 1.8s is 27mm. pretty weird because when i was doing the head gasket job, all the nuts and bolts i had taken off when i was tearing down the engine were even numbers: 10mm, 12mm and 14mm...
  16. #14
    Newbie Christian
    Nov 2010
    Tempe, AZ
    Drives
    2004 Nissan Sentra SE-R Spec V
    Likes Received
    21
    Quote Originally Posted by jaymov33 View Post
    The 1.8 and the 2.5 have different crank pulley bolt sizes.
    w/ some goodies
    more goodies to come
  17. #15
    Senior Member Christian
    Jun 2011
    Conroe, TX
    Drives
    black specV
    Likes Received
    96
    thread bump. when your doing the install which way do you turn right or left?
    If it ain't a type R it ain't a tight car
    Ebay Intake, Srs Headers 4-1, Stock down pipe, 2.5 exhaust pipe, tsudo axle back, 2J Ps & Crank pulley, Bc racing 8k coilovers, Honda accord lip, HD Quick release front bumper, Qt adjustable link, BSR chain cut, IMM with cocking in between lol. Thats all for this year. Next year fully bulit motor top to bottom.
  18. #16
    Senior Member Bob
    Jun 2011
    Des Plaines
    Drives
    2003 Spec-v
    Likes Received
    275
    Lefty loosy
  19. #17
    Jun 2011
    Conroe, TX
    Drives
    black specV
    Likes Received
    96
    ok thanks got it off
  20. #18
    Senior Member reggie
    Dec 2011
    new york
    Drives
    spec v aka sharice
    Likes Received
    38
    the crank pully bolt on my car was a 19 i just changed my pulley last week
    Reggie reg SO
    SER ious
    turned up to the max
  21. #19
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    The MIGHTY AUTO 04 SE-R & Others
    Likes Received
    3425
    Quote Originally Posted by 936B15 View Post
    What socket size was it?
    Cross......... Angry........ Miserable.........
    SoundEfx up in here causing trouble......
    "I'm a BAD man... BAD man doh dance..." ...... " That bam-bam is ..MINE..!! "
  22. #20
    Senior Member adam
    Feb 2010
    Baytown, TX
    Drives
    2002 spec v
    Likes Received
    1794
    Default Re: Crank pulley bolt size?
    Quote Originally Posted by SoundEfx View Post
    Should be 19mm.
    Quote Originally Posted by WifesCar View Post
    Nitrous is like a hot girl with STDs, you know you want to hit it, but you're afraid of the consequences...
    Quote Originally Posted by skwirl View Post
    That's because its impossible to be pretentious when you're driving a sentra. Being an elitist sentra owner is like thinking you're the smartest kid in the special ed class.
  1. QR25DE Crank pulley
    By 06spec-v in forum B15 Sentra (2000 - 2006)
    Last Post: 10-11-2011, 06:03 PM
  2. UR crank pulley
    By pandaspec in forum Forced Induction & Supporting Modifications
    Last Post: 09-14-2011, 11:52 AM
  3. Anyone know the front caliper bolt size? The 19mm bolt size?
    By Specvay in forum Suspension, Chassis & Braking
    Last Post: 08-26-2011, 03:41 PM
  4. Need help on bolt size
    By Fl1pSde 101 in forum Troubleshooting and Support
    Last Post: 06-01-2011, 01:52 PM
  5. Crank pulley
    By Murderedspecv. in forum Naturally Aspirated (NA)
    Last Post: 05-18-2011, 10:23 PM
