P2137 and P2138 App Sensor Help
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
  1. #1
    Oct 2011
    Likes Received
    0
    Default P2137 and P2138 App Sensor Help
    Hi,
    When I start my car it starts in limp mode 60% of the time. Codes being thrown are P2127 and P2138 APP Sensor.
    I have replaced the Pedal/sensor assembly already. Cleared codes and the problem has come back within a day.
    What should I look at next?
    From reading the different forums I have seen that there is a way to test the ECM module/wiring harness. I have the service manual but can not find these procedures in it. Should I start here? If so Can someone point me to the right section in the service manual to start testing?
    If I am not thinking correctly here, can you point me in the right direction with my next troubleshooting steps?
    Thanks
    Derek
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    02 Nissan Sentra Se R spec v
    Likes Received
    Quote Originally Posted by ddsvi View Post
    Hi,
    Thanks
    Derek
    what car you have?
  4. #3
    Oct 2011
    Likes Received
    0
    Sorry it is a 02 Sentra SE R SpecV
  5. #4
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    Same car same problems, your throttle body shouldnt have any problem! Its the plug on the sensor of TB unplug it ang clean it the 6 socket... mine was greased up! and make sure its not loose because everytime u rev the engine it tends to get loose! But first unlug your negative battery for 5-10 before doing that... After that when u see the SES/MIL light on do the Idle relearn/pedal dance search for it in forum.
  6. #5
    Oct 2011
    Likes Received
    0
    So I disconnected the cable to the tb. Checked the pins on the sensor and the harness itself. Both were clean. Blew them out anyway. Then connected it back. Did the pedal relearn, then throttle relearn, then idle air volume relearn.
    Cleared the codes. Then the problem is back this morning. Throwing code 2138 only.
    P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
    What should I check next?
  7. #6
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    03 spec V, 02 specv,Passat,f150,Kawasaki Vulcan,Fleetwood Flair, also drives neighbors crazy!
    Likes Received
    212
    Did you go through the troubleshooting sequence in the service manual yet?
  8. #7
    Oct 2011
    Likes Received
    0
    No I have the service manual but not sure which section the procedure is in.
  9. #8
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    Make sure do the relearn properly...if u have anything running electrical other than the power fuse for sound system, remove it...it may affect the tps to retard. Once again check the plug in sensor if loose, if there is grease remove it! monitor it everytime...if it does "limp mode" again just remove car key for 10 secs then start it. Mine went on few times! Just be patient those probs go away as time past! It is probably adjusting from all your upgrades. Sometimes bumps, or lil car shake can trigger the sensor...not too sure though!
  10. #9
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    If u have bad motor mount i suggest have it replace, just for the safe side for your engine...u wouldnt want your motor to jump and choke whenever u hit a big bump.
  11. #10
    Oct 2011
    Likes Received
    0
    I made sure I had everything turned off. Radio was off, AC was off, unplugged radar detector, etc..
    Connector didnt have any grease on the connector. As far as I can tell it is making a good connection and is not loose. Pretty sure I did the relearns correct. The car idols much better than it did before.But I will try doing the relearns again.
    You dont think the TB or TB sensor could be going bad?
  12. #11
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    i meant that anything that is hooked on(positive or negative)on battery.
    maybe, maybe not! But it is still best to wait and be patient because it may just be for a while to come back to normal...other than that as long as it runs,starts, not stalling. Your TB/TPS(sensor) is fine! If the MIL/SES light is on that's the only time you can do the Relearn. Just try not to worry too much and drive it,monitor it, again if it does "LIMP mode" again just pull aside remove key for 10 secs. then start car again!
  13. #12
    Oct 2011
    Likes Received
    0
    Sounds good. I will give it a couple of days and see what happens. It has been trying to stall when I first start it in the morning and goes right into limp mode for the last couple of days. Then I turn the car off and start it up into normal mode. While driving within the first 15 miles or so it will go into limp mode a couple more times. Then turn the car off and on a couple of times and it drives fine the rest of the trip.
    I drive about 60 miles each way to work. So after the first 15 miles or so its fine the rest of the way to work. Then after work it has been starting and driving fine all the way home. Then the next morning we have the same issue.
    This has been happening for about a week. Before I replaced the pedal it would do this in the morning and also when I was leaving work. Pretty much every time I left the car sitting for a couple of hours.
  14. #13
    Oct 2010
    Bay Area, CA
    Likes Received
    691
    So you have the service manual? The actual PDF FSM? If you do, check out under EC.pdf and find your code. It'll tell you the wiring diagram and how to troubleshoot it.
  15. #14
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    replaced what pedal?
  16. #15
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    Have you red this forum? it might help! you didnt totalled your car yet right?
    Accelerator Pedal Position (APP) Sensor - Nissan Forums : Nissan Forum
  17. #16
    Oct 2011
    Likes Received
    0
    LOL no I didnt have an accident. I havent found any broken or worn wires yet. Guess I need to try and trace them a little further and check that.
    I replaced the Accelerator Pedal/Sensor Assembly. (Gas Pedal)
    I do have the service manual. I just double checked the EC.pdf and my code is not there
    The highest code in that section is 1760. My code is 2138.
  18. #17
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    why did u change the gas pedal? that's probably the reason y u have the code..it maybe a bad one u just put on,have u tried to put the old one back without any code?
  19. #18
    Oct 2011
    Likes Received
    0
    I put the new one on because I was throwing codes:
    P2127 - Accelerator Pedal Position Sensor 2 Circuit Low Input
    The sensor for this is on the gas pedal. So I replaced the whole pedal assembly. Looks exactly the same as the original one, but is brand new. Not to worried about that one being bad. Pretty sure its good.
    Derek
  20. #19
    Newbie M.p.
    Mar 2010
    los angeles
    Drives
    Likes Received
    Derek
    i hope so! as long as you bought it in nissan i guess is good!
  21. #20
    Oct 2011
    Likes Received
    0
    I replaced the Throttle Body last night. Did the 3 relearns and so far so good. Drove it for about 4 miles last night to test, then drove an hour to work this morning. Going to wait a week or so and see if I have any more issues.
  1. P2138, oil in ECU
    By podman in forum B15 Sentra (2000 - 2006)
    Last Post: 07-18-2011, 08:45 PM
  2. OBD2 Android App - Torque
    By un33dit in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 02-23-2011, 11:15 PM
  3. Help... Car loses power - P2122 & p2138
    By redline_spec_v in forum Troubleshooting and Support
    Last Post: 12-20-2010, 08:52 PM
