random misfire, no check engine light
Results 1 to 12 of 12
  1. #1
    Newbie Drew
    Sep 2010
    Frederick, MD
    Drives
    '04 Spec V
    Likes Received
    0
    Default random misfire, no check engine light
    i've got an '04 spec v and it randomly misfires but isn't throwing a check engine light. i've noticed it happens after the engines up to temp and completey warm, it also only happends under 3000rpm. i can baby it up to 3K rpm's and then hammer it all the way to redline and she won't miss. i replaced all the coils, plugs 10K miles ago. i checked out live data on a scan tool and the B1S2 wasn't switching, so i replaced it. i pulled the plugs yesterday and they're white (indicating a lean mixture) i assumed it was a fuel/air volume issue because at high rpm's she runs great. ideas anyone?????
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    hmmm
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Red '02 - Because I'm crazy
    Blue '94 Miata - for the ladies
    Gray '07 Prius - Dat eco doe..
  4. #3
    Senior Member Tom Tom
    Jan 2010
    Douglasville, Ga
    Drives
    05 Volcanic spec
    Likes Received
    66
    crank/cam sensor would be my guess
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Nov 2010
    germantown md
    Drives
    people crazy
    Likes Received
    71
    i am with tstaubly /\/\/\/\
  7. #5
    Jun 2011
    massachusetts
    Likes Received
    24
    your b1s2, is referring to your o2 sensor? do you have a catless header? if you spaced out the lower o2, the readings will be different. if anything the first o2 would be controlling the a/f ratio. you could make sure it isnt caked up with white shite either. also i wouldnt rule out cam and crank sensors if you havent changed those yet, you will notice an intermittent rough idle when they are failing. the last thing i can think of is the alternator not outputting at lower rpm, check the battery voltage with the motor on and off.
    Aztec 02 Nissan Sentra SE-R Spec V, 292k miles
    -blown head gasket @153k, original clutch!
    Black 02 old vq swap, 150k miles
  8. #6
    May 2011
    Likes Received
    0
    I used to have the same issue last month with my '04 sentra Specv. I changed the spark plug, coils and wire initially and used the seafoam treatment after it.
    One battle to clean up fuel injector and another to clear carbon build up. It seems to be working fine for me
  9. #7
    Newbie Drew
    Sep 2010
    Frederick, MD
    Drives
    '04 Spec V
    Likes Received
    0
    thanks for the input guys, my car has 106,XXX miles on it and the crank and cam sensors are the original ones. i also do have a some what rough idle so i think i'll give that a try
  10. #8
    Jun 2011
    massachusetts
    Likes Received
    24
    after you changed your sensors, do the 3 relearn procedures, hopefully it will correct your idle.
  11. #9
    Newbie Drew
    Sep 2010
    Frederick, MD
    Drives
    '04 Spec V
    Likes Received
    0
    i replaced the crank sensor last night, drove the car for about 20min and now it misses at around 4000rpm's (at full throttle) but never missed at low rpm's like before... note my idle did seem more steady although i didn't do the 3 relearns??? i've never heard of these
  12. #10
    Newbie Drew
    Sep 2010
    Frederick, MD
    Drives
    '04 Spec V
    Likes Received
    0
    i drove it some more and it seems that changing the crank sensor didn't change anything. could this be a fuel problem. i pulled the plugs recently and they were pretty white indicating it's running lean already...
  13. #11
    Jun 2011
    massachusetts
    Likes Received
    24
    if you changed the crank sensor, you should also change the cam sensor, its the same part.
    have you checked your primary o2 sensor? have you cleaned your maf using only cnc maf cleaner?
    using search ive uncovered the 3 relearn procedures here:
    http://www.b15u.com/sentra-specific-...hlight=relearn
  14. #12
    Newbie Drew
    Sep 2010
    Frederick, MD
    Drives
    '04 Spec V
    Likes Received
    0
    i feel like a complete n00b right now but the misfire was caused by a coil going bad. actually it was 2 coils. i was swapping out coils to see if one was bad and one of the ones i was using to swap out with was also bad. thanks for all the info though. it's greatly appreciated
  1. Spec check engine light on and off???
    By Greengolfball in forum Troubleshooting and Support
    Last Post: 07-26-2011, 02:22 PM
  2. QR25DE Check Engine Light
    By jt0wn in forum Troubleshooting and Support
    Last Post: 02-28-2011, 12:46 PM
  3. check engine light.
    By cweigle9 in forum Troubleshooting and Support
    Last Post: 10-13-2010, 01:20 PM
  4. B13 CHeck engine light on
    By B13se in forum B13 (1991-1994)
    Last Post: 07-31-2010, 12:24 AM
  5. check engine light on for cat
    By streetracer1 in forum B15 Sentra (2000 - 2006)
    Last Post: 03-11-2010, 08:46 PM
