Howd you replace the shift console light?
Results 1 to 13 of 13
  1. #1
    Newbie You Guessed It
    Jun 2011
    Cydonia
    Drives
    Z32, B15, BF, C1
    Likes Received
    Default Howd you replace the shift console light?
    My shift console light on my '04 1.8s automatic went out. Any quick how to's to replace that light? Pls Dont tell me i have to goto the dealer and buy a $40 proprietary bulb.
    Thanks All,
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    The search button is your friend lol!
    http://www.b15u.com/transmissions-cl...b-shifter.html
    2J Racing high power cold air intake, Nismo header, Nismo lower tie bar(not installed yet), Nismo rear sway bar,Nismo short shifter, 2J midpipe,stromung exhaust, Ksport coilovers, 2-J racing 10mm anti lift kit,2-J lightweight crank and power steering pulley, FI-R shifter bushings, Rob's air diversion panel, Rob's LTB wheel hop aid, More to come!
    Bsr, j30 front calipers yet to be installed…
  4. #3
    Jun 2011
    Cydonia
    Drives
    Z32, B15, BF, C1
    Likes Received
    Tried that.
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    And you couldn't find the bulb? Hmm, idk the bulb should be there on the shifter assembly. If ya can't find it then idk. The answer is out there I'm sure, just don't remember where I read it. Sorry man wasn't trying to be a dick, normally people mention if they have searched or not there's a lot of search nazi's on here lol!
  7. #5
    Jun 2011
    Cydonia
    Drives
    Z32, B15, BF, C1
    Likes Received
    Ok I'll try to get in there and repl it myself (like I already did w/ a HVAC console bulb) Then I'll post the 411 for future Sentra owners.
    I'm hoping the shifter console "PRND32" is lit and actually has a bulb.
  8. #6
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    Sorry I'm not much help, don't need lights for a 6 speed lol. But seriously see if you can pop that trim piece up and see it.
  9. #7
    Senior Member Send me an EMAIL!
    Dec 2005
    Likes Received
    781
    Quote Originally Posted by quikz View Post
    It is lit and there should be a bulb in there somewhere.
    DO NOT PM ME! EMAIL ONLY!
    email: jonathans123@gmail.com
  10. #8
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    Try this thread from another site post #8 this is what I was suggestion you try.
    http://www.b15sentra.net/forums/showthread.php?t=118789
    Or here's another Write up from the Internet:
    How do you replace the illumination light on the gear shift of a 2005 Nissan sentra?
    Answer:
    Just did this to our 2005 Sentra. You have to remove the entire center console: 2 screws up front (one on driver's side and one on pass side), 1 top middle (under small cover just in front of brake handle), and 2 in the rear (you have to remove the drink holder "cover" to get at them). Disconnect the 2 electrical connections for the cigarette lighters and remove the console. Now, the gear shift indicator "box" can be snapped off its locator posts, and underneath you will find the bulb holder. The shift indicator "box" can be lifted just enough to be able to twist and remove the bulb holder. The lamp can then be pulled straight out of the bulb holder.
    Repeat the process in reverse order to put it back together.
  11. #9
    Apprentice Cliff
    Aug 2010
    Whitehall, Ohio, United States
    Drives
    05 Sentra1.8
    Likes Received
    7
    iv done this already. the bulb socket should be in the little black box under the PRND21.... pretty simple.. i just removed the shifter surround aka the cup holders and bam pulled the silver piece up(shift indicator box? lol), black box was clipped to the bottom of it found the wire for the bulb took the bulb out put new one in buttoned everything back up and done.
    Fujita CAI, TDMI Coilovers, 2JR Lightweight Pully, ebay header/downpipe 2.5" ebay catback exhaust........to be continued.
  12. #10
    Thanks been meaning to do this also.
    Standard Bulb 194, thanks for the link.
  13. #11
    Jan 2011
    Ohio
    Drives
    2003 Ser Spec-V
    Likes Received
    182
    Glad it helped, I do my best to help all
  14. #12
    Jun 2013
    Dallas, TX
    Drives
    2001 Nissan Sentra GXE
    Likes Received
    0
    Sorry to continue a 2 year old thread, but my light went out as well. I was wondering if an LED bulb could be put in instead of the 194 LL bulb?
  15. #13
    Senior Member Christian
    Jun 2011
    Conroe, TX
    Drives
    black specV
    Likes Received
    96
    Id say yes
    If it ain't a type R it ain't a tight car
    Ebay Intake, Srs Headers 4-1, Stock down pipe, 2.5 exhaust pipe, tsudo axle back, 2J Ps & Crank pulley, Bc racing 8k coilovers, Honda accord lip, HD Quick release front bumper, Qt adjustable link, BSR chain cut, IMM with cocking in between lol. Thats all for this year. Next year fully bulit motor top to bottom.
  1. Raptor Shift Light Installation
    By ash in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 12-10-2011, 11:51 AM
  2. FS: Raptor shift light, ECM, seats
    By specBOOST in forum Parts for Sale
    Last Post: 07-28-2011, 12:58 PM
  3. All B15 Models Changing Dash Lights + Shift Light ... With a Twist?
    By QR25DE_SpecV in forum Interior Modifications
    Last Post: 08-27-2010, 01:41 AM
  4. 04-06 Shift light wiring and MSD Tach Driver
    By thedark69 in forum B15 Sentra (2000 - 2006)
    Last Post: 04-01-2010, 02:23 AM
  5. FS: shift light, 5mm spacers, "I <3 Haters"
    By atomicguy7 in forum Parts for Sale
    Last Post: 07-01-2009, 09:47 PM
