2002 sentra SER specV.2.5L.problem
Results 1 to 8 of 8
  1. #1
    Apr 2012
    Likes Received
    0
    Default 2002 sentra SER specV.2.5L.problem
    this is a 6speed transmission 2.5L sentra specv.the idling was a bit high and i check for vac leak,did not find any.cleaned throttle body and problem started, idling started to move from 1200 to 1700 RPM,sometimes stay steady at 1200.i did many times the learning thing with the keys turn and accelerator with no luck,also did the disconnect electric plug from throttle body and plug back and still the same.erased code P0507 with by obdII scanner and same.i think it may be the throttle body,but i want to make sure before i start to spend money on part with no benefit. if any one has suggestion please let me know.is there a way to test the throttle body electric part?
    one thing i noticed is the the throttle door do not move when i turn the ignition switch on,and it does open and closed when i turn the switch off.
    thanks for any suggestion.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Feb 2009
    Las Cruces NM
    Drives
    Sierra
    Likes Received
    176
    sounds like the throttle body
  4. #3
    Apr 2012
    Likes Received
    0
    thanks for reply....i found an A-1 cardone at rockauto for 79.00 returning the core.is this a good one.? and is there a way to test to make sure?
  5. #4
    Feb 2009
    Las Cruces NM
    Drives
    Sierra
    Likes Received
    176
    Cel (check engine light) is it on?
    Do this...
    Warm the car up
    Shut car off
    Unplug electrical connection to the throttle body
    Turn car back on and itlf it runs the same way its for sure.
    But when you did unplug the TB before did you make.sure to unplug the battery before hand?
  6. #5
    Apr 2012
    Likes Received
    0
    i did as the instruction says from a old post in this forum.warm the car,then unplug with car running,wait 3 sec then plug back.did not unplug battery
    will do as u says sunday and see what comes..thanks.will pot result
  7. #6
    Apr 2012
    Likes Received
    0
    ok,got a new throttle body.installed.warm the car did the relearning.still RPM is high.at first was moving from 1200 to1800rpm.no code showing.any suggestion
  8. #7
    Feb 2009
    Las Cruces NM
    Drives
    Sierra
    Likes Received
    176
    You got to make sure to disconnect the battery with anything electrical. It resets your ecu ..
    Since your idle.is still high, it maybe a vacuum leak, so you hear any air whistling or sucking?
  9. #8
    Apr 2012
    Likes Received
    0
    thanks for the suggestions.the problems were,the PVC valve and my son buddy own a car shop and has one of those professional snap on diagnostic machine and was able to do the 3 relearning with his machine.car now run very fine.some how we could not do the relearn manually. thanks much
  1. FS: 2002 Nissan Sentra Se-r SpecV
    By dontony in forum Vehicles for Sale
    Last Post: 05-18-2011, 05:39 PM
  2. Replies: 2
    Last Post: 05-11-2011, 02:02 PM
  3. 2002 nissan sentra turbo specv
    By boost2002 in forum Vehicles for Sale
    Last Post: 01-26-2011, 07:49 AM
  4. 02-03 2002 ser spec v problem
    By dganic23 in forum B15 Sentra (2000 - 2006)
    Last Post: 05-03-2010, 06:07 PM
  5. SpecV Rider /montemorelos Nuevo leon/Sentra Se-R Specv 2005
    By SpecV Rider in forum Member Rides and Project Cars
    Last Post: 02-23-2010, 01:23 PM
