After disconnecting negative terminal on battery, car won't start
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
  1. #1
    Dec 2012
    New Jersey
    Drives
    04 Sentra 1.8s 5 Speed
    Likes Received
    433
    Default After disconnecting negative terminal on battery, car won't start
    Worked near the alternator area on my 1.8S today, so I disconnected the negative terminal to be safe. Was off for 10 minutes. Now when the key is turned to ON after reconnecting, the dash lights (oil, fuel, CEL) won't turn on. The headlights, radio all still work. Fuel pump doesn't prime, and the car cranks but still won't start. Already disconnected pos and neg terminals for 10 mins, no luck. Need the car running to drive to school, any ideas?
    2004 Radium Sentra 1.8S 5 Speed: PhantomEagle454's 1.8s Daily/Autocross car
    233,000+ miles and counting on factory clutch, headgasket, coil packs, CVs, etc etc.
    HellaBeat Car Crew #69
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member James Kaminski
    Oct 2012
    Houston, TX
    Drives
    '06 silver spec
    Likes Received
    329
    jump start your carr
  4. #3
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    The MIGHTY AUTO 04 SE-R & Others
    Likes Received
    3307
    Try getting a jump and see what the car does.
    Cross......... Angry........ Miserable.........
    SoundEfx up in here causing trouble......
    "I'm a BAD man... BAD man doh dance..." ...... " That bam-bam is ..MINE..!! "
  5. #4
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    Would that even work if the fuel pump doesn't prime?
  6. #5
    Oct 2012
    Houston, TX
    Drives
    '06 silver spec
    Likes Received
    329
    could be a weak battery if not than you need to test your fuse box
    To be honest with you since its getting late start looking at fuses...
  7. #6
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3307
    We are diagnosing blindly.
    Try getting a jump and that would rule out some things that might be wrong.
    Then we will go from there.
  8. #7
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    Quote Originally Posted by SoundEfx View Post
    will do, i'll let you know when i can how it goes
  9. #8
    Senior Member Rob
    Mar 2011
    BC, Canada
    Drives
    03 Spec-V
    Likes Received
    709
    you blew the main fusible link by the sounds of it. its in the under hood fuse box by the battery. iirc the qg uses a 100amp link and should be the one closest to the firewall end of the fuse box. it should have a clear plastic window so you can see if its blown or might be all black and burnt like mine was. i was able to pop off the clear window and bend the metal strips back together so i could run down to buy a new one.
    Check out the random stuff i'm making
    Air diversion panels
    Gauge mounts and vent deletes
    The classic wheel hop aid
    Aluminum power steering reservoir covers
    Aluminum Relay box covers
    13.57@104.25 -baby loves the bottle!-
    It's not a low budget build...just slow budget.
  10. #9
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    If it helps, the windows dont get power but the headlights, taillights, and audio work
  11. #10
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    Jump start failed, car just cranked but didn't fire up.
  12. #11
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3307
    Looks like Rob has it solved.
    Do what Rob suggested...
  13. #12
    Senior Member Rob
    Mar 2011
    BC, Canada
    Drives
    03 Spec-V
    Likes Received
    709
    yup, sounds like one of the fusible links.
  14. #13
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    Gonna run to WalMart and try it out..it sits in the battery-side fuse box?
  15. #14
    Senior Member Rob
    Mar 2011
    BC, Canada
    Drives
    03 Spec-V
    Likes Received
    709
    yup battery side, pop the cover off and take a look, mine was obviously blown just by looking at it
  16. #15
    Senior Member Rob
    Mar 2011
    BC, Canada
    Drives
    03 Spec-V
    Likes Received
    709
    twas this little $25 bastard that did it to me.
  17. #16
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    Thanks for the pic, I have to go to Advance Auto tomorrow, Wally world didn't have it. I appreciate you helping me out man, I'll post here tomorrow on how it goes.
  18. #17
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    I saw the fusible that you pointed out, through the clear window i could see two small metal tabs, with ~ 1mm gap between them. Sorry for my inexperience, but will this be blown? It doesn't look burnt
  19. #18
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3307
    Yes. If you see a gap in the fuse, that means that it is blown and you need a new one.
  20. #19
    Dec 2012
    New Jersey
    Drives
    Likes Received
    433
    It pretty much looked like this. Looks like I'm buying a fuse, I'll let you know how it turns out
  21. #20
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3307
    Lets hope that you didn't drain the battery too much trying to start it.
  1. Negative review on prothane motor mounts
    By yogi b in forum Part Reviews and Feedback
    Last Post: 02-19-2013, 04:26 AM
  2. car wont start even after a new battery . HELP!!! (SOLVED!)
    By surpze_buttzekz in forum Troubleshooting and Support
    Last Post: 10-26-2012, 09:00 PM
  3. disconnecting A/T relay
    By b15nyc in forum B15 Sentra (2000 - 2006)
    Last Post: 03-10-2012, 04:17 AM
  4. Battery terminal ? !!!!
    By blueis300 in forum Troubleshooting and Support
    Last Post: 12-11-2010, 01:33 PM
