Metallic rattle when decelerating
Results 1 to 12 of 12
  1. #1
    Default Metallic rattle when decelerating
    Recording does not show up. I noticed a metallic rattling sound when in gear, coasting and/or while decelerating.
    It does not make this sound if the engine is under load, or not in gear.
    It does not sound like something loose from the interior. More like the engine bay.
    2002 203K miles.
    Any ides?
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    The MIGHTY AUTO 04 SE-R & Others
    Likes Received
    3367
    We need more info.
    Right, left side, at a specific rpm.....?
    Cross......... Angry........ Miserable.........
    SoundEfx up in here causing trouble......
    "I'm a BAD man... BAD man doh dance..." ...... " That bam-bam is ..MINE..!! "
  4. #3
    Sorry. In all gears. AC on and off. Under 2500 rpm (because that's when it's not that loud so I can hear it). At all speeds from 60 to 10. I can't tell if it's left or right, other than front. I want to say center.
    So I pay more attention today. The noise goes away after 15 miles of driving. I live in warm (hot) weather Arizona. Oil level is fine. Car has been serviced by Nissan dealer by the prior owner. I owned the car for 2 months. I/H/E, no cats.
    Let me throw the butterfly screw question out too. I asked about that. It was "done" according to Nissan when they installed the remanufactured long block in 2011. I don't know what "done" means. Loctite, washer added? Don't know. Does every Nissan tech knows about this?
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Mar 2013
    LONG ISLAND, N.Y.
    Drives
    2003 SE-R SPEC V
    Likes Received
    30
    Exhaust heat shields?
    03 SPEC V - Mishimoto rad & hoses, Place Racing MM, Twm SS, UR pully, Nismo header, 2J Side Exit, JWT BSR, 2J 15mm ALK, 2J ACB, 2J PS pully, 2J Flywheel, 2J Stage I Clutch, 2J SPEC V Plenum, 2J Midpipe, 2J CMB, 2J BLUE Cai, 04 SPEC V Wheels, Toyo Proxes 4's 225/45/ZR17, Stop Tech rotors, Hawk HPS pads, Goodrich hoses, AEM gauges
  7. #5
    The Wheel Ninja Jef
    Jan 2006
    Jersey
    Drives
    02 boosted spec v
    Likes Received
    243
    Or cheap Megan mid pipe that the resonators spot welds broke on/in
    Forum Wheel Ninja
    stock 02's/gxe's/04+ stocks/02 G20 sports/18" VOLK TE37's/17" Silver Nismo's/16" Gold Advan sa3r's/16x8" xxr 521/17" OZ Superleggera
  8. #6
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3367
    Just to be safe, you should loctite the screws. That way you know that you're safe.
  9. #7
    Quote Originally Posted by Bacon View Post
    DC Sports race header so I would think it's of good quality, no?
    Quote Originally Posted by SoundEfx View Post
    I was hoping to not have to do this. Yes, I should just for the peace of mind. I guess I'll now read the DIY thread on that.
  10. #8
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3367
    It's not hard to do. Just take your time and everything should go without any issues.
  11. #9
    So I was looking under the hood and noticed this tube rubbing against the hood. What is it? AC line? Is it suppose to rub like this?
  12. #10
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    Likes Received
    3367
    Yes, I believe that line is the a/c line and no, it should NOT be rubbing against anything.
  13. #11
    Senior Member Christian
    Jun 2011
    Conroe, TX
    Drives
    black specV
    Likes Received
    96
    Just push it down. itll bend
    If it ain't a type R it ain't a tight car
    Ebay Intake, Srs Headers 4-1, Stock down pipe, 2.5 exhaust pipe, tsudo axle back, 2J Ps & Crank pulley, Bc racing 8k coilovers, Honda accord lip, HD Quick release front bumper, Qt adjustable link, BSR chain cut, IMM with cocking in between lol. Thats all for this year. Next year fully bulit motor top to bottom.
  14. #12
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    03 spec V, 02 specv,Passat,f150,Kawasaki Vulcan,Fleetwood Flair, also drives neighbors crazy!
    Likes Received
    212
    Quote Originally Posted by YipMan_Style View Post
    That does look like where the noise came from. Probably happened when they installed the long block. Check your moter mounts front and rear for wear and cracks in the rubber portion. The engine shifting due to torque will rock the engine significantly causing the noise to go away and reapear.
  1. Replies: 8
    Last Post: 04-22-2013, 02:38 PM
  2. Project Dark Grey Metallic 61K
    By WifesCar in forum Exterior Modifications, Paint and Bodywork
    Last Post: 02-15-2012, 03:19 PM
  3. Replies: 12
    Last Post: 09-26-2011, 10:20 PM
  4. Ser DaNNy/05 Tangerine Metallic Spec-V/ dirty jersey 2011 UPDATE!!!
    By Ser Danny in forum Member Rides and Project Cars
    Last Post: 06-21-2011, 10:29 AM
  5. shake, rattle and RATTLE
    By SpecBEE in forum B15 Sentra (2000 - 2006)
    Last Post: 04-27-2007, 12:58 PM
