Dipstick Tube Replacement....
Results 1 to 13 of 13
  1. #1
    Newbie Tanner
    Nov 2012
    Cedar Rapids, IA
    Drives
    03 Spec V
    Likes Received
    16
    Default Dipstick Tube Replacement....
    Call me an idiot but my dipstick tube is broke, i ordered a new one but i cant even get the old one out... Is there a trick to this or what? i feel like im over thinking this one..
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Christian
    Jun 2011
    Conroe, TX
    Drives
    black specV
    Likes Received
    96
    There is one bolt that holds it in the middle spot after that yank it out
    If it ain't a type R it ain't a tight car
    Ebay Intake, Srs Headers 4-1, Stock down pipe, 2.5 exhaust pipe, tsudo axle back, 2J Ps & Crank pulley, Bc racing 8k coilovers, Honda accord lip, HD Quick release front bumper, Qt adjustable link, BSR chain cut, IMM with cocking in between lol. Thats all for this year. Next year fully bulit motor top to bottom.
  4. #3
    Newbie Tanner
    Nov 2012
    Cedar Rapids, IA
    Drives
    03 Spec V
    Likes Received
    16
    Quote Originally Posted by 936B15 View Post
    ok cause thats where it broke right at that bolt. and just shove the new one in??? realhardlike? lolz
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Jun 2011
    Conroe, TX
    Drives
    black specV
    Likes Received
    96
    Yes dont let it gasp for air
  7. #5
    Senior Member Jeff
    May 2010
    Beltsville, MD
    Drives
    2001 Sentra SE
    Likes Received
    574
    Ya'll crazy. freeze the new dipstick overnight and put some oil on the end before you install. stick a screwdriver in the top hole and tap it in that way.Will go in easily.
  8. #6
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Splash45 has some sort of how to write up on changing the dip stick tube
    HOW TO USE THE B15U.COM SEARCH!
    THERE HAS NEVER BEEN ANYTHING MADE THAT DID NOT HAVE A PURPOSE
    Performance: QR25DE-T 308whp and 314wtq at 9.5psi
    Suspension: Nismo R-tune bushing kit/Nismo RSB/FSB/4pt lower brace/4pt trunk bar/9k BC Racing Coilovers/ALK/15mm spacers/prothane mounts/ 17x7 O.Z Ultraleggeras with 225/45/17 P960 AS Pole Positions
    More to come...
  9. #7
    Senior Member Rey's my Bitch.
    Oct 2010
    Allen, TX
    Likes Received
    436
    @shift_03specv Rey IS a PRO when it comes to changing these bad boys out. And has experience putting small things in holes as well so I would wait for his expert opinion.
  10. #8
    Aug 2010
    Likes Received
    484
    Dude is super easy , literally unbolt the other one , and just pull with ur hand hard and the oil dipstick will pop out , for the new one lube the o ring at the bottom of the dip stick and u can push it in by hand as long as the o ring is oiled , always lube o rings for stuff like that .
  11. #9
    Senior Member Parker
    Sep 2011
    Houston, TX
    Drives
    03 Spec
    Likes Received
    467
    can we have one thread about lubing dip sticks without people snickering like children....
    There's no class in America. Look around this bitch. You see anyone with class?
  12. #10
    Oct 2010
    Allen, TX
    Likes Received
    436
    LOL, You are aware this is a sentra forum right?
  13. #11
    Aug 2010
    Likes Received
    484
    That what makes this forum fun
  14. #12
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    2004 spec v hybrid 2jr turbo qr
    Likes Received
    3578
    here you can see the o ring properly placed
    this is important or oil goes everywhere
  15. #13
    Senior Member Rey
    May 2010
    Fxburg VA
    Drives
    03 Spec
    Likes Received
    2756
    That stupid fkn dipstick
    http://www.b15u.com/troubleshooting-...ck-fkn-me.html
    Change the angle you're pulling on it from and yank that fucker hard as shit. Order a new ring from Nissan.
    FK YA!
  1. How to: Aluminum/metal dipstick handle
    By Splash45 in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 11-06-2016, 12:35 PM
  2. Oil Dipstick fkn with me
    By shift_03specv in forum Troubleshooting and Support
    Last Post: 10-17-2013, 12:05 AM
  3. Replies: 0
    Last Post: 03-19-2012, 05:17 PM
  4. Leaking OIl Dipstick tube
    By Nperez1986 in forum Forced Induction & Supporting Modifications
    Last Post: 01-11-2012, 07:46 PM
  5. So I broke my dipstick.. with pics
    By njord in forum B15 Sentra (2000 - 2006)
    Last Post: 03-18-2011, 06:52 PM
