Warped Cylinder Head But Never Overheated
14K views 2 replies 2 participants last post by  maximus1555
#1 ·
I began to note hard starting on my B15 2005 QG18DE with 60k miles and in about 1 week misfire at idle. Did a compression test with the following results: 158psi - 90psi - 90psi - 152psi. Also noticed water consumption and grim at the radiator fill neck. With these symptoms it was obvious the head gasket had blown so I replaced it. This is how I found the head gasket when the head was removed
It was blown between cylinder 2 and 3. The engine has never overheated and Ive had it for over a year so I just replaced the head gasket. Once I put everything together again and started the engine the engine sounded good. After 3 hours driving, same symptoms appeared and the compression test gave the same results, same compression leak, same cylinders. I am guessing my cylinder head is warped? How can it warp if it has never overheated? Will a blocked cat create enough backpressure and cause this?
#2 ·
how much coolant was your engine drinking ? I had a bad head gasket on SE-R with no overheat condition that i was aware of. I used a less expensive scantool than what the dealer had and when they read it they said it had a overheat code stored in the ECU.
The picture you posted above is that a chip in the block ?
#3 ·
It was drinking about 1 liter per 50 miles. The circle in the image shows the blown head gasket. I had to resurface the head, it was not warped but did have a hole between cylinder 2-3. Its running good now.
