QR25DE 2JR Medusa Street Header
Page 1 of 79 123451151 ... LastLast
Results 1 to 20 of 1565
  1. #1
    Mar 2012
    FL
    Drives
    2002 Sentra SE R Spec V
    Likes Received
    807
    Cool 2JR Medusa Street Header
    @Joe@2J-Racing
    Info?
    Will this come with a mid pipe?
    Gains?
    http://www.2j-racing.com/hyper-black...ader-qr25.html
    Placed order on Nov 28th, 2014:
    Name:  2J Racing Street Header Order.PNG
    Medusa arrived on Jan 29th, 2016:
    Installed on Jan 30th, 2016:
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Nov 2014
    Likes Received
    35
    Looks sexy. I like it
  4. #3
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Yeah looks sick!
    I'm ordering for sure, would just like more info.
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Senior Member Common Outlier
    Jan 2010
    LV-426
    Drives
    2006 SE-R Spec V
    Likes Received
    411
    Great price. But I'd like to know what power it makes as well.
  7. #5
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    2004 spec v hybrid 2jr turbo qr
    Likes Received
    3509
    fits stock and joe's mid pipe iirc
    i saw the wrapped one
    very different looking
    very cool
    power is less than the race header
    i think this is more about sound harmonics,
    fitment and quality construction
    this should last , lose that tinny sound
    and make a good bit more power than the Chinese knock offs
    the equal length runners can't hurt
    remember this is not available till spring
    you are pre-ordering now
  8. #6
    Mar 2012
    FL
    Drives
    Likes Received
    807
    I currently have DC 4-2-1 sports header and mid pipe that came with it and a Greddy Evo 2. So this header would not function with the DC mid pipe?
    Website does say "Will bolt to your factory or aftermarket exhaust." Which leads me to believe mid pipe is included.
  9. #7
    Nov 2009
    Drives
    2003 SE-R SPEC V
    Likes Received
    13
    I wonder if this header would yield better gains compared to a HOTSHOT or Nismo header? And will we see any gains with stock cams, or is this designed specifically for bigger cams and high RPMs? Would this header work better with a B15 intake manifold or a 2J manifold? Any dyno numbers available yet? These are the questions.
  10. #8
    May 2013
    Northern VA
    Drives
    2004 SER Specv
    Likes Received
    574
    Man what the fuck. I JUST bought a header!!
    ~~~ 2004 Molten Silver SpecV ~~~ 2J CAI ~ 2J Plenum ~ 2J Madusa Header ~ 2J 2.5" Midpipe ~ 2.5" Stromung Catback ~ Uprev Tuned ~ BC Coils on 7k Springs ~ 2J Superpro and RCK Lower Control Arms ~ 2J 15mm ALK ~ 2J Delrin Motor Mounts and Crossmember Bushings ~ 2J Crank Pulley ~ 300zx Front Brakes, Hawk Pads/Slotted Rotors ~ Rear StopTech Pads/Slotted Rotors ~ XXR 962's on Continental DS's ~ 2J Rear Sway Bar ~ 2J Trailing Arm Bushings ~ Nismo Shift Knob ~ 2J Turcite Shifter Bushings ~ 6.5" Polk Audio's ~ Plastidip ~ Miscellaneous Goodies ~
    ~~ In The Works ~~ OEM Carbon Fiber Hood ~ Rota P45f's ~ Fully Built with Boost Project Motor in Progress ~ A Dream Come True... ~
  11. #9
    Jun 2014
    Oregon
    Drives
    Loud '06 Black Spec V
    Likes Received
    260
    Damn nice price and it looks sick!
    Time to replace the ol ebay header i think
    06 Black Spec V- 2jr UpRev flashed ECU, 2jr CAI, 2jr Plenum w/2jr 76mm spacer, 2jr Medusa header, 2jr Mid-pipe w/cat, 2jr V2 3'' Side Exit exhaust, Eibach Pro kit on KYB struts and mounts, 17x7.5 Rota Grids on 215/45 Conti dws tires, 2jr stage 2 clutch w/14lb aluminum flywheel, Mishimoto Aluminum Rad w/ Mishi dual fan shroud Brembo calipers w/drilled and slotted disks, 2jr Crank and PS pulley, 2jr 15mm ALK, B/S chain cut, 2jr Steering rack bushing, Rob's crossmember bushings, A/F ratio volt and water temp gauges, solid stainless weighted shift knob, 6.5'' Alpines all around with Alpine sub, amp and headunit
  12. #10
    Nov 2014
    Likes Received
    35
    Quote Originally Posted by 2k2SpecV View Post
    Yeah looks sick!
    I wanna order one bad but Ive only had my Megan 4-1 for a little over a year... so its hard to justify buying that one now haha
  13. #11
    Nov 2010
    HI
    Drives
    '03 Spec V/ '08 GSXR 750/ '07 RS4
    Likes Received
    398
    Doesn't include mid-pipe, would mean it would bolt to your stock mid pipe or OEM style aftermarket replacement mid pipe so either you can dig up your old OEM pipe or buy a new one with that header. Not sure how that doesn't make sense.
    The Vagabond
    "Be polite, be professional, but have a plan to kill everybody you meet." General James Mattis
  14. #12
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Quote Originally Posted by CrickiKaze View Post
    I understand now, Thanks CrickiKaze! I'll probably order 2Js mid pipe also. Guess it was just me trying to avoid wasting more cash now on a mid pipe, will be worth it tho.
  15. #13
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    Likes Received
    3509
    Quote Originally Posted by AUTOBOT_SPECV View Post
    the street header is for street lol
    no cams or other wild mods required
    i have not seen the dyno, but if you remember this design
    was also in the run to be the race header
    i think the hp will be good bit more than hotshot or dc
    [none of which are equal length nor is the nismo]
    the plenum tends to produce more low and midrange too
    and imo would be a good street match for this header
    but not required to see good gains
  16. #14
    Apr 2014
    Tennessee
    Drives
    Turbo 04 SpecV, VQ 04 SpecV, 1975 Datsun b210 Sedan "Sunny", 2015 Titan SV King Cab
    Likes Received
    1877
    Man I just missed this yesterday. I checked the 2j site too early in the day I guess. I want one I want one.
    Is there a thread on the 2j cams???? You guys saw the cams right???
    Quote Originally Posted by SoundEfx View Post
    Were you talking about total cars or total value/cost/price?
    Either way, I can give anyone a good run for their money......
    BOOSTEDFebruary 2016 @108k miles
    SUSPENSION/CHASSIS: BC 7k coilovers 27f 28r, 2j rear sway, 2j 10mm ALK, 2j Delrin crossmember bushings, 2j LCAs with MOOG ball joints and Super Pro bushings, MMIs, MOOG tie rod and sway bar end links. New OEM sway bar bracket bushings. Worth every penny!!!!!!
    TURBO/TUNE: Precision 5431, Precision 3" Intercooler, Tial 38mm wastegate open dump 8.7 spring, HKS BOV, DIY 2.5" hot side, 3" DIY to 2j CAI cold side. Uprev on 04 ECU tuned by Joe via email and datalogs until I can make it to a dyno tune. INNOVATE wideband, Auto Meter boost gauge, Deca 633s, 2j Fuel Pump
    Motor/Transmission: STOCK Motor lol. I mean stock. Yes it has an intact balance shaft and butterflies lol. Big Balls or Just Dumb? We'll see lol. 2j Stage 3 clutch and F1 Flywheel
    EXHAUST: Treadstone SS Turbo Manifold , 3" v-band Downpipe, 38mm open dump pipe, 3" custom v-band midpipe, random short resonator, 2j 3" dual tip cat back with deleted resonator.
    Brakes/Wheels/Tires: Wilwood 6 piston front brakes & Brembo option rear setup. NISMO Wheels. Bridgestone RE-71r tires in 225/45/17
    Miscellaneous: 2j short shift and Turcite shifter bushings. Wow!!!!! Buy Them NOW!!!!!!!!
    2j 1.3bar radiator cap (just some incognito bling). Prosport dual steering column pod. Had a 2j ACB and recommend them, but removed when I went turbo
    Next?????
    Original owner. Experienced isuues: Crank Angle Sensor & Rear Hubs. All stock 10yrs 95k. No longer stock. Crossed 100k early 2015
    My '75 Datsun b210! Currently being swapped!!! http://www.b15u.com/threads/50401-Da...j-CA18det-Swap
    CA18det by 2j-r
    Quote Originally Posted by funguy26 View Post
    welcome back. i'm miss spelling things and driving the car harder.
  17. #15
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Yes saw the cams, no thread on that yet. Going for the 2JR Street header, and 2JR mid pipe. Hopefully he can hold off on shipping the mid pipe together with the header on May 2015 once released.
  18. #16
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1877
    I wish I hadn't just replaced my entire exhaust this past summer. You can get header, mid, side exit for $650!!!! What a steal. Damn.
    @yogi b good job keepin this hush hush. I'm surprised we didn't know about this header already. Ahhh I want one so bad!!!!! Anyway...good job yogi. We'll be crying about where these are until the day they arrive next year, so the later we knew, the better
    Next?????
    CA18det by 2j-r
  19. #17
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1877
    Also let's point out you need the ACB. Don't forget to order that. I assume this, because there is one in the pictures. MAYBE you don't have to have it, but I bet you do and you should get one anyway.
    Next?????
    CA18det by 2j-r
  20. #18
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1877
    I would "ASSUME" this header makes At Least comparable power to those. If this wasn't the best "new" header you could buy (other than the race header), I doubt Joe would make it. We're cheap ass bastards. We wouldn't buy it if it wasn't significantly better than our other cheaper options or if it wasn't at least equal to our used (no longer manufactured) options. Its definitely gonna dramatically out perform all EBaY style headers. Way way better quality too and made in the USA
    Next?????
    CA18det by 2j-r
  21. #19
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Dave now you got me thinking,
    How much of a difference will the 2JR Street header make when compared to my current DC 4-2-1.
  22. #20
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1877
    Unfortunately only Joe knows at the moment and we can't ask him on Thanksgiving. We'll have to wait and see. But I would think at least equal. It definitely will sound good and it looks cool. Can only guess about power until dyno #s are posted. I'm "Guessing" better power than every header other than the 2j race header. Of course that's a guess and without dyno results its hard to say ditch your 4-2-1, but its pretty obviously gonna be better than any Megan style header. I would think better than a 4-2-1 as well, but that isn't based on anything really. Just my assumption Joe wouldn't manufacture it if it wasn't.
    Also......this header should be compared With A Midpipe if comparing it to a 4-2-1 for an honest comparison. And in that instance I think the 2j header will win hands down. The 2j header with a stock mid pipe will still very possibly out perform a 4-2-1. Just for an honest comparison there should be no stock mid pipes involved since a 4-2-1 replaces the stock midpipe
    Next?????
    CA18det by 2j-r
  1. 02-06 QR25DE Header Installation
    By ash in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 07-18-2014, 09:24 PM
  2. qr25de bogging after header install
    By CokeZero in forum Troubleshooting and Support
    Last Post: 05-23-2014, 02:32 PM
  3. WTB: QR25DE header
    By Hugoboss in forum Parts Wanted
    Last Post: 06-29-2013, 12:57 AM
  4. QR25DE which header is more hp in QR25DE???
    By MUCA89 in forum B15 Sentra (2000 - 2006)
    Last Post: 10-19-2012, 01:34 AM
  5. - SOLD - Fs/ft: Obx 4-2-1 header for qr25de
    By edo747 in forum Parts for Sale
    Last Post: 05-24-2011, 01:43 AM
Tags for this Thread
