Spec V Boosted on bone stock internals - Page 11
Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Results 201 to 220 of 267
  1. #201
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Sentra Turbo daily driver
    Likes Received
    27
    Garrett journal bearing turbo
    Treadstone TR8 intercooler
    Tial Q blowoff valve
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing 10mm antilift
    2J Racing rear antisway
    2J Racing pullies
    2J Racing high power plenum
    Magnaflow exhaust
    Clutch Masters Lightened flywheel
    TDMi subframe collars
    TDMi battery tie down
    Metal dipstick
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #202
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  4. #203
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #204
    Mar 2012
    FL
    Drives
    2002 Sentra SE R Spec V
    Likes Received
    807
    Default Spec V Boosted on bone stock internals
    Just read about it in your other post,
    Sorry man!
    You ain't the only one with problems though, I'm still chasing a boost leak of some short.
  7. #205
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    how do you know its a boost leak?
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  8. #206
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Quote Originally Posted by aargh View Post
    Boost dropping off at a high RPM.
  9. #207
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    a clamp needs tightening i think. the ones that always gave me trouble were the two attached to the 2" - 2.5" silicone hose coming off the turbo and the one directly before the MAF pipe.
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  10. #208
    Mar 2012
    FL
    Drives
    Likes Received
    807
    I had issues with the one on the Turbo inlet, was leaking there. Fixed it.
    Went out for a drive, still loosing boost.
    Going to get the car properly pressure tested this weekend, so let's see.
  11. #209
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    update for those watching this thread....Boost lab said I had to either repair or replace my turbo. I opted for a garrett journal bearing center piece instead of repair. Difference of $100.
    Any way - my car now is fixed (again) and pocket book is empty (again). happy trails peeps!
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  12. #210
    Apr 2014
    Tennessee
    Drives
    Turbo 04 SpecV, VQ 04 SpecV, 1975 Datsun b210 Sedan "Sunny", 2015 Titan SV King Cab
    Likes Received
    1907
    update for those watching this thread....Boost lab said I had to either repair or replace my Chinese e-bay journal bearing turbo. I opted for a garrett journal bearing center piece instead of repair. Difference of $100. Boost lab said this turbo is as inexpensive as they can be built and asked where I got it from. I mentioned the shop where it was purchased but they never heard of them.
    They said that your supposedly Precision center section was Chinese garbage huh????
    Quote Originally Posted by SoundEfx View Post
    Were you talking about total cars or total value/cost/price?
    Either way, I can give anyone a good run for their money......
    BOOSTEDFebruary 2016 @108k miles
    SUSPENSION/CHASSIS: BC 7k coilovers 27f 28r, 2j rear sway, 2j 10mm ALK, 2j Delrin crossmember bushings, 2j LCAs with MOOG ball joints and Super Pro bushings, MMIs, MOOG tie rod and sway bar end links. New OEM sway bar bracket bushings. Worth every penny!!!!!!
    TURBO/TUNE: Precision 5431, Precision 3" Intercooler, Tial 38mm wastegate open dump 8.7 spring, HKS BOV, DIY 2.5" hot side, 3" DIY to 2j CAI cold side. Uprev on 04 ECU tuned by Joe via email and datalogs until I can make it to a dyno tune. INNOVATE wideband, Auto Meter boost gauge, Deca 633s, 2j Fuel Pump
    Motor/Transmission: STOCK Motor lol. I mean stock. Yes it has an intact balance shaft and butterflies lol. Big Balls or Just Dumb? We'll see lol. 2j Stage 3 clutch and F1 Flywheel
    EXHAUST: Treadstone SS Turbo Manifold , 3" v-band Downpipe, 38mm open dump pipe, 3" custom v-band midpipe, random short resonator, 2j 3" dual tip cat back with deleted resonator.
    Brakes/Wheels/Tires: Wilwood 6 piston front brakes & Brembo option rear setup. NISMO Wheels. Bridgestone RE-71r tires in 225/45/17
    Miscellaneous: 2j short shift and Turcite shifter bushings. Wow!!!!! Buy Them NOW!!!!!!!!
    2j 1.3bar radiator cap (just some incognito bling). Prosport dual steering column pod. Had a 2j ACB and recommend them, but removed when I went turbo
    Next?????
    Original owner. Experienced isuues: Crank Angle Sensor & Rear Hubs. All stock 10yrs 95k. No longer stock. Crossed 100k early 2015
    My '75 Datsun b210! Currently being swapped!!! http://www.b15u.com/threads/50401-Da...j-CA18det-Swap
    CA18det by 2j-r
    Quote Originally Posted by funguy26 View Post
    welcome back. i'm miss spelling things and driving the car harder.
  13. #211
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    they showed me the markings smj something or other.... and I paid $300 xtra for a race ball bearing turbo.
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  14. #212
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Sorry to hear that aargh!
    But very very interesting...
    Just to add, I've been warned against Turbos sold from that shop, actually did not take it seriously; refused to believe it..
    But this proves them right!
  15. #213
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    - - - Updated - - -
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  16. #214
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Likes Received
    27
    yea well the dude lied straight to my face and when I picked the vehicle up he was nowhere around. And they didnt lift it or show me a thing. Here's the keys and have fun was their last words as they shoved me out the door.
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing pullies
    Magnaflow exhaust
    Metal dipstick
  17. #215
    Mar 2012
    FL
    Drives
    Likes Received
    807
    Well you can always go back, show them your findings, and request what you actually paid for because that is unacceptable.
  18. #216
    Apprentice Steven
    Aug 2013
    Elyria, Ohio, United States
    Drives
    02 Spec V
    Likes Received
    77
    Quote Originally Posted by 2k2SpecV View Post
    Where was this Turbo bought from?
    Didn't OP have a 2J installed Turbo?
    Sent From My HTC 10 via Tapatalk
    02 Spec V-T
    2J 57 trim
    12psi
    2J Treadstone Kit
    2J Plenum,RSB,Pullies,ETC ETC
    Check Out my store : QuikNightsMotorsports.com
    Saikou and UltraRacing Vendor
  19. #217
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1907
    Quote Originally Posted by CloudSpecV View Post
    Yes
    Next?????
    CA18det by 2j-r
  20. #218
    Mar 2012
    FL
    Drives
    Likes Received
    807
    I think so..
  21. #219
    Apprentice Steven
    Aug 2013
    Drives
    02 Spec V
    Likes Received
    77
    Quote Originally Posted by DaveSpecB15 View Post
    Yes
    How lovely..
    Wonder how long my 2J 57 trim will hold then
    02 Spec V-T
    2J 57 trim
    12psi
    2J Treadstone Kit
  22. #220
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1907
    How lovely..
    Mine is precision. Says it on the compressor housing. I imagine 2k2's is the same.
    Idk about the supposed hybrids.
    If the #s are somewhere easy to see then 2k2 or I could compare ours.
    Next?????
    CA18det by 2j-r
  1. Tune on bone stock QR?
    By NekoTaks in forum Tuning & Engine Management
    Last Post: 05-25-2014, 07:25 AM
  2. New here. Bone stock 2002 Se-r 108k.
    By Papamateo2002 in forum Member Rides and Project Cars
    Last Post: 03-13-2014, 03:58 PM
  3. 14 lbs on Stock Internals?
    By yellowblast827 in forum Forced Induction & Supporting Modifications
    Last Post: 09-28-2010, 12:03 PM
  4. 385whp.... on stock internals!
    By ash in forum B15 Sentra (2000 - 2006)
    Last Post: 06-10-2008, 06:38 PM
