Reverse lockout/ getting into reverse
Results 1 to 9 of 9
  1. #1
    Oct 2007
    kings park
    Likes Received
    0
    Default Reverse lockout/ getting into reverse
    im having problems getting into reverse. i have to hold up the reverse lockout trigger go into 5th then go down in order to get it into reverse. i drove johns spec today so he can hear his exhaust and i went into reverse in his car with no problem pull up the trigger and it goes right into reverse. did anybody ever have this problem? im probably going to take it to smithtown nissan bc i have a 100,000 mi warranty but i figured id ask first...
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Sebastian
    Nov 2006
    Likes Received
    53
    u need to loosen your shift knob.. u have it on too tight.. same problem happened to me...ur 100k warranty is not for the shifter..lol its only powertrain... they are really not gonna do anything for you, but loosen the knob...
  4. #3
    Senior Member Send me an EMAIL!
    Dec 2005
    Likes Received
    781
    Loosen the knob slightly, and if you still continue to have this problem try putting it inot 1st the going for reverse, works every time on the non reverse lockout cars at least.
    DO NOT PM ME! EMAIL ONLY!
    email: jonathans123@gmail.com
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Apprentice Daniel
    Jul 2009
    Brooklyn, NY USA
    Drives
    2004 Turboed Nissan Sentra SE-R Spec V
    Likes Received
    You mean put it into second...
    Herniated Disc - Having back problems? Learn about treatment options.
    Good things do come to those who wait, but only the things that are left behind by those who hustle. - Abraham Lincoln
  7. #5
    Dec 2005
    Likes Received
    781
    Quote Originally Posted by SupraFast View Post
    NOPE.... I mean 1st.
  8. #6
    Senior Member Jamil
    Jul 2009
    Staten Island NY
    Drives
    qr25det
    Likes Received
    139
    i guess it wont hurt to check your shifter clips under your hood, make sure there cliped in good.
  9. #7
    Nov 2006
    Likes Received
    53
    its an 06, how bad did you fuck up the reverse Tom , lol sometimes i have a hard time getting into reversem but its because i let the car sit in first gear for like a week haha
  10. #8
    Oct 2007
    kings park
    Likes Received
    0
    it was like that when i bought the car in april but i didnt feel like taking it back to the dealer but now its just being such a pain im tired of it. i tried to loosin up my shift knob and it works fine that way but then every time i shift it twists because its so loose and its not supposed to be that way. and its annoying to tighten it after eevery time i go back in gear.
  11. #9
    Feb 2008
    Likes Received
    0
    use loctite bro take it off loctite the threads check gettin into reverse then let it set and it no longer will spin around on u
    2005 code red spec v with K&n typhoon intake, mmi, xs power header race package magnaflow high flow cat magnaflow catback wit 2 14" resonators axxition sts gen 2 24mm stillen front sway bar tein s-techs 03seat swap, tuned afc neo....if only u new what was comming
  1. No reverse gear
    By dawhitespecv in forum B15 Sentra (2000 - 2006)
    Last Post: 10-28-2012, 05:54 PM
