02-06 nismo Graham lights for sale.
Results 1 to 18 of 18
  1. #1
    Default nismo Graham lights for sale.
    Up for sale is a sEt of nismo Graham lights 57
    One is cracked
    I'm willing to sell 1 ,2 ,3 or the set.
    These are off the wheel and ready to ship. I live in Miami Florida, zipcode 33142 for shipping.
    The weight is about 17 lbs each plus box and packing I'll say 20 lbs per unit.
    If you are interested drop a message. 175$ each or $500 budle price shipped.
    I also have a turbo kit for sale ?
    305-720-11forty $evenName:  IMG_20160206_094218.jpg
Size:  191.5 KBName:  IMG_20160322_211928.jpg
    Attached Images Attached Images
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member J
    Apr 2010
    Redmond, WA
    Drives
    The MIGHTY AUTO 04 SE-R & Others
    Likes Received
    3411
    Good luck with the sale.
    But I have to ask, what's up with the phone and hello kitty pic.?
    Cross......... Angry........ Miserable.........
    SoundEfx up in here causing trouble......
    "I'm a BAD man... BAD man doh dance..." ...... " That bam-bam is ..MINE..!! "
  4. #3
    Quote Originally Posted by SoundEfx View Post
    sorry man that pic was a mistake but i don't know how to edit the add to remove
    the phone is cause sometimes people need to talk and not write the idea
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Oct 2009
    518, NY
    Likes Received
    149
    How much? And picture of the crack?
    2001.5 S4 APR Stage 3 + more 487 AWHP & 509 AWTQ - Sold
    2004 Blackout Spec V bolted - Totaled
    2002 2JZ-GTE/GETRAG swapped IS300- Project - Sold
    2004 Cloud White Spec V - Bolted/Tuned/Brembo'd/Nismo Lipped - DD
    2006 Evo IX MR
    2014 Audi S4
  7. #5
    Senior Member Kris
    Mar 2015
    Pine Island Florida
    Drives
    Qr20det 2002 spec v
    Likes Received
    1147
    Looks like some pretty nasty curb rash on two of the other ones too.. Mite want to drop your price a bit on these! Just a suggestion
  8. #6
    Senior Member Kris
    Mar 2015
    Pine Island Florida
    Drives
    Qr20det 2002 spec v
    Likes Received
    1147
    Quote Originally Posted by 2k4 SE-R Spec V View Post
    $700 from what it looks like to me. It's rite after his pn#...
    Or that's his pn#??? Not sure. Not sure how this got approved with no price
  9. #7
    Oct 2010
    Bay Area, CA
    Likes Received
    696
    Quote Originally Posted by kjg819 View Post
    There is a partial price of 200/pc. @Rolando Hernandez, please put the price for the bundle as well.
  10. #8
    Quote Originally Posted by MoltenNismo View Post
    Updated
  11. #9
  12. #10
    Newbie Derek
    Apr 2014
    SW Missouri
    Drives
    2003 SpecV 03 Frontier CC 4X4 SC 64 Impala 2dr hardtop
    Likes Received
    27
    Id go 200 shipped for all 4. They are pretty rough plus Im not sure if that cracked one is even repairable.
    If its not its probably going to be a pretty good hassle to find someone else willing to break up a set.
    2003 Sunburst Yellow Spec V. Original owner.
    Eibach sportlines,AEM C.A.I. ,Nismo Header,2J midpipe & side exit V2, JWT bsr, TWM short throw Shifter, FI-R Solid motor mounts and crossmember bushings,UR crank pulley, 2J rad.supports, NX 50 shot.
    04 Rear Bumper/Tail light swap.
    Next Mods:Got a pile of parts sitting in the garage.
    2J plenum,2J ps pulley and belt,2J 10lb flywheel (stg 2 clutch still tbd.)
  13. #11
    Apr 2014
    Tennessee
    Drives
    Turbo 04 SpecV, VQ 04 SpecV, 1975 Datsun b210 Sedan "Sunny", 2015 Titan SV King Cab
    Likes Received
    1878
    Quote Originally Posted by The_SprayinSpecV View Post
    Well hell...on the off chance that's even a possibility I'll outbid you by offering $210 for the 3 that AREN'T cracked shipped. Only have to ship 3, cheaper shipping.
    Were you talking about total cars or total value/cost/price?
    Either way, I can give anyone a good run for their money......
    BOOSTEDFebruary 2016 @108k miles
    SUSPENSION/CHASSIS: BC 7k coilovers 27f 28r, 2j rear sway, 2j 10mm ALK, 2j Delrin crossmember bushings, 2j LCAs with MOOG ball joints and Super Pro bushings, MMIs, MOOG tie rod and sway bar end links. New OEM sway bar bracket bushings. Worth every penny!!!!!!
    TURBO/TUNE: Precision 5431, Precision 3" Intercooler, Tial 38mm wastegate open dump 8.7 spring, HKS BOV, DIY 2.5" hot side, 3" DIY to 2j CAI cold side. Uprev on 04 ECU tuned by Joe via email and datalogs until I can make it to a dyno tune. INNOVATE wideband, Auto Meter boost gauge, Deca 633s, 2j Fuel Pump
    Motor/Transmission: STOCK Motor lol. I mean stock. Yes it has an intact balance shaft and butterflies lol. Big Balls or Just Dumb? We'll see lol. 2j Stage 3 clutch and F1 Flywheel
    EXHAUST: Treadstone SS Turbo Manifold , 3" v-band Downpipe, 38mm open dump pipe, 3" custom v-band midpipe, random short resonator, 2j 3" dual tip cat back with deleted resonator.
    Brakes/Wheels/Tires: Wilwood 6 piston front brakes & Brembo option rear setup. NISMO Wheels. Bridgestone RE-71r tires in 225/45/17
    Miscellaneous: 2j short shift and Turcite shifter bushings. Wow!!!!! Buy Them NOW!!!!!!!!
    2j 1.3bar radiator cap (just some incognito bling). Prosport dual steering column pod. Had a 2j ACB and recommend them, but removed when I went turbo
    Next?????
    Original owner. Experienced isuues: Crank Angle Sensor & Rear Hubs. All stock 10yrs 95k. No longer stock. Crossed 100k early 2015
    My '75 Datsun b210! Currently being swapped!!! http://www.b15u.com/threads/50401-Da...j-CA18det-Swap
    CA18det by 2j-r
    Quote Originally Posted by funguy26 View Post
    welcome back. i'm miss spelling things and driving the car harder.
  14. #12
    Senior Member Kris
    Mar 2015
    Pine Island Florida
    Drives
    Qr20det 2002 spec v
    Likes Received
    1147
    Quote Originally Posted by DaveSpecB15 View Post
    Yes, even Tapatalk is fcked up with this site rite now!
    But I deal with it and move on!
  15. #13
    Apr 2014
    Tennessee
    Drives
    Likes Received
    1878
    Wrong thread?
    Next?????
    CA18det by 2j-r
  16. #14
    Senior Member Kris
    Mar 2015
    Pine Island Florida
    Drives
    Qr20det 2002 spec v
    Likes Received
    1147
    Wrong thread?
    Yup! hahahaha
    Good catch Dave!!
    Was just reading multiple threads at once ...
  17. #15
    Newbie Derek
    Apr 2014
    SW Missouri
    Drives
    Likes Received
    27
    Go for it. I was up half the night with anxiety for offering 100 more than I would have offered in person.
    Now I dont have to feel guilty about backing out of that offer.
  18. #16
    Apprentice Armando
    Aug 2009
    Orlando,FL
    Drives
    06 Spec V
    Likes Received
    192
    $100/ea for 2 wheels picked up?
    I'd like to remind us all that for the most part, internet forums are where people that dont know how to do something tell other people that dont know how to do something what they read about how to do it.
  19. #17
    TOMA !!
  20. #18
    all the way ?
  1. 02-06 04 Sentra Nismo lip/Nismo strut bar/ manual transmission for sale
    By richierich411 in forum Parts for Sale
    Last Post: 11-03-2015, 10:57 AM
  2. Replies: 75
    Last Post: 02-22-2015, 03:39 PM
  3. Replies: 13
    Last Post: 10-04-2014, 09:01 PM
  4. Replies: 53
    Last Post: 08-05-2013, 08:23 PM
  5. nismo gram lights
    By pablo1989 in forum Parts Wanted
    Last Post: 10-20-2011, 10:27 PM
Tags for this Thread
