02-06 clunk noise when clutch is dumped
Results 1 to 7 of 7
  1. #1
    Default clunk noise when clutch is dumped
    I drive and 02 se-r spec v. A couple days ago i dumped the clutch and heard a loud clunk noise coming from the engine bay. I drove it today and it made the noise again when i dumped it from a standstill. Car is still running perfectly but the noise is scarring me and im afraid it'll turn into something bad. Any ideas on what it could be?
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Kris
    Mar 2015
    Pine Island Florida
    Drives
    Qr20det 2002 spec v
    Likes Received
    1210
    Check your motor mounts...
  4. #3
    Newbie lucito bandigan
    Jan 2017
    united arab emirates
    Drives
    kia sephia
    Likes Received
    0
    MAYBE your mountings are damaged ,check also clutch bearing
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Senior Member Bob
    Jun 2011
    Des Plaines
    Drives
    2003 Spec-v
    Likes Received
    275
    motor mounts or cv axle
  7. #5
    Jan 2013
    Likes Received
    93
    As stated check your motor mounts. But first check your crossmember. I can almost guarantee you that the crossmember bushings are shot. Great replacement is definitely the delrin ones from 2J. They're pretty easy to install and cheap but if you can't swing it right now then at least retorque the bolts.
  8. #6
    How do I check these? What should I be looking for?
  9. #7
    Jan 2013
    Likes Received
    93
    You check them by unbolting the crossmember under the engine and chuckling at the chintzy deteriorated rubber "bushings". Chances are your using the crossmember as a point to jack up the front of the car, that's any easy way to locate it. It's almost a for sure thing that they're no good anymore and it would certainly be a big contributor to your engine clunking around. I'd recommend this first before messing with motor mount inserts.
    https://www.2j-racing.com/bushings/2...hings-150.html
    It's super easy, you can do it in less than a half hour with limited skill, a floor jack, and I think a 14mm socket or wrench. It's a crossmember that's underneath the engine.
    Once you do these you can decide if you want to move to the next level or not, which is motor mount inserts.
  1. Clutch noise
    By Dannyblade in forum B15 Sentra (2000 - 2006)
    Last Post: 04-13-2014, 09:48 AM
  2. Clunk noise
    Last Post: 09-02-2013, 03:09 AM
  3. Weird clunk noise
    By Josh kills spec v's in forum Suspension, Chassis & Braking
    Last Post: 08-30-2013, 10:55 AM
  4. QR25DE clutch tapping noise
    By Specyalater in forum Troubleshooting and Support
    Last Post: 04-06-2012, 08:45 PM
Tags for this Thread
