Originally Limited2.5
Results 1 to 10 of 10
  1. #1
    Default Originally Limited2.5
    Hows it going everyone. Its been a while. Couldnt get the password reset to work properly so i just ended up making a new account.
    Anyway my name is Chris & i own an
    03 B15 & a 97 U13.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Mar 2012
    FL
    Drives
    2002 Sentra SE R Spec V
    Likes Received
    807
    Welcome back,
    both your rides are beautiful!
  4. #3
    Apr 2016
    Likes Received
    281
    Welcome back
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Senior Member Kaz
    Dec 2014
    scranton pa
    Drives
    04 spec v
    Likes Received
    795
    Welcome back both rides very nice
    Motor - low compression pistons, K1 rods, B16 crank, Bc stage 2 cams, bc valves and titanium retainers, Bsr kit, lower temp thermostats, and a 2j Ps pulley 2j rad and heater hoses
    Transmission- 03 spec v transmission, spec stage 3 clutch, 2j 14lb flywheel, 2j sts and bushings, 2j v2 shift knob
    Suspension- raceland coilovers putting Bc 9k coilovers soon, Nismo fsb, rsb, and strut bar, 4pt trunk bar, 4pt tanabe front brace, 2j 15mm alks, 2j crossmember bushings, weapon r torque damper, tdmi qt link needs to be installed, tdmi hard race control arm bushings, 2j solid motor mounts
    Intake- Nismo cold air intake but using as a short ram intake
    Exhaust- Nismo header, stock midpipe, 2.25 piping to a DC muffler, no rez
    Misc.- greddy ad panel, 2j rad cap, 2j dress up caps, complete 02 spec v interor, 2j 20mm spacers all around,2j 82mm studs. Grounding kit, 2j yellow fogs, 02 spec rims custom painted
  7. #5
    Apr 2016
    Likes Received
    281
    There is a lot of welcome back going around. They must have heard about me @SoundEfx.
  8. #6
    Apr 2016
    Likes Received
    281
    So what are you up to in August?
  9. #7
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    2004 spec v hybrid 2jr turbo qr
    Likes Received
    3509
    looking good
    are you riding on air
  10. #8
    Apr 2016
    Likes Received
    281
    Quote Originally Posted by AMG8191d View Post
  11. #9
    Thanks everyone for the welcome back.
    @AMG8191d am not sure what ill be doing in August
    but whats up?
    Quote Originally Posted by yogi b View Post
    looking good
    An Yogi yea the B15 is on Air Ride suspension.
  12. #10
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    Likes Received
    3509
    THE DRAGONS TAIL
    an aniverserery tale
    8/19
    a run for fun
  1. Limited2.5/Boosted 03/PA *Update pg5*
    By Limited2.5 in forum Member Rides and Project Cars
    Last Post: 05-14-2015, 04:29 PM
  2. Limited2.5/97' Bluebird Altima/PA Pg.2 Update
    Last Post: 08-04-2014, 05:57 PM
  3. limited2.5 A+++ seller
    By SpecBEE in forum Member Feedback
    Last Post: 04-22-2013, 02:15 PM
