Missing at wot
Results 1 to 5 of 5
Thread: Missing at wot
  1. #1
    Default Missing at wot
    I have a 02 sentra turbo built 04-06 ecu for uprev and haven't had luck with it, getting it running good. First it was a idle problem now that's manageable now started missing around 3k or wot. pls help have spent so much money on this car and still cant even drive it!!!
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Mar 2012
    FL
    Drives
    2002 Sentra SE R Spec V
    Likes Received
    776
    My experience with misfires under WOT boosted has been either coil packs, or ignition coil connectors and wires.
    Replaced all those and solved my misfires.
    But it could be a number of things in your case,
    I'd start by checking your spark plugs.
  4. #3
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    2004 spec v hybrid 2jr turbo qr
    Likes Received
    3460
    turbos can be a bear
    but so nice when they run
    for me
    if coil pacs, plugs and ecu are good
    i decrease my plug gap
    i'm running .038 on ngk coppers
    one heat range colder than oem
    also i find these cars run better if kept around 3000 rpm [2600-3200]
    don't lug it
    no boost down low in the rpm range
    imo
    maintenance on these is similar to the George Washington bridge
    once they get thru painting ,replacing and tightening
    working from one end of the bridge to the other
    they start again on the other side
    yeah constant
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Newbie Thomas
    Sep 2016
    Tampa
    Drives
    Sentra Turbo daily driver
    Likes Received
    18
    Cool
    Quote Originally Posted by yogi b View Post
    for me
    don't lug it
    imo
    yeah constant
    LOL
    - - - Updated - - -
    mine was plug gap as well. listen to yogi...
    Garrett journal bearing turbo
    Treadstone TR8 intercooler
    Tial Q blowoff valve
    Tial 38mm wastegate
    Nismo coilovers
    Whiteline STB
    2J Racing 10mm antilift
    2J Racing rear antisway
    2J Racing pullies
    2J Racing high power plenum
    Magnaflow exhaust
    Clutch Masters Lightened flywheel
    TDMi subframe collars
    TDMi battery tie down
    Metal dipstick
  7. #5
    Thanks guys hope mine is something simple but from past experience i have the worst luck with this car. I'll get a set of new coils and plugs and go from there.
  1. Wot Box
    By Crumbs96 in forum Parts for Sale
    Last Post: 09-01-2015, 09:34 PM
  2. misfires at wot
    By tavix in forum Forced Induction & Supporting Modifications
    Last Post: 08-12-2012, 06:40 PM
  3. Manifold pressure at WOT?
    By Bullet001 in forum Naturally Aspirated (NA)
    Last Post: 05-21-2011, 09:49 PM
  4. WOT reflash?
    By Joe S in forum Tuning & Engine Management
    Last Post: 05-16-2011, 09:41 AM
  5. WOT question
    By EL STi in forum B15 Sentra (2000 - 2006)
    Last Post: 09-13-2006, 11:40 AM
