Tires, your favorite
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1
    Default Tires, your favorite
    Getting some Bridgestone re760s put on today. Bridgestone and Michelin spend millions on racing tire blend development where others don't. This is why these tires are way better and last much longer and ride better. One thing to never cheap out on is tires. What's your favorite tire?
    I'm just getting started!
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Steve
    Feb 2011
    Anderson. SC
    Drives
    Black 05 Spec V-T
    Likes Received
    2099
    @yogi b
    Here's another chance for you for tire and wheel advice!!!
    the Potenzas were fine for me, until I got a turbo. then they were very inadequate, NA, they were great!!! Not so much with double the power output of stock!
    edit to add, so far, I have not found a favorite, but I have adequate!
    work in progress...
    [03-03-2016 05:36 PM] DaveSpecB15 : My Sentra has a QR25taf swap. It's the turbo as fuck engine. I coulda got a DE for cheap though. But my muffler bearings couldn't handle the torque. You gotta tune that shit on hopes and dreams.
  4. #3
    Senior Member Kaz
    Dec 2014
    scranton pa
    Drives
    04 spec v
    Likes Received
    747
    I ran the re760s for summer last 2 years and there not bad at all. If your Na
    Motor - low compression pistons, K1 rods, B16 crank, Bc stage 2 cams, bc valves and titanium retainers, Bsr kit, lower temp thermostats, and a 2j Ps pulley 2j rad and heater hoses
    Transmission- 03 spec v transmission, spec stage 3 clutch, 2j 14lb flywheel, 2j sts and bushings, 2j v2 shift knob
    Suspension- raceland coilovers putting Bc 9k coilovers soon, Nismo fsb, rsb, and strut bar, 4pt trunk bar, 4pt tanabe front brace, 2j 15mm alks, 2j crossmember bushings, weapon r torque damper, tdmi qt link needs to be installed, tdmi hard race control arm bushings, 2j solid motor mounts
    Intake- Nismo cold air intake but using as a short ram intake
    Exhaust- Nismo header, stock midpipe, 2.25 piping to a DC muffler, no rez
    Misc.- greddy ad panel, 2j rad cap, 2j dress up caps, complete 02 spec v interor, 2j 20mm spacers all around,2j 82mm studs. Grounding kit, 2j yellow fogs, 02 spec rims custom painted
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Aug 2010
    spring hill,tn
    Drives
    2002 black spec-v, 2015 titanium Sentra sv
    Likes Received
    665
    Quote Originally Posted by Kazspec04 View Post
    coming from the guy that is still n/a
    just throwing this out there, being as i have tried lots of bridgestone tires since i get a discount there. u could have gotten a better tires for around the same price
    2002 vq swap
    Engine- 05 se-r altima vq. Nwp thermal spacers, 3" intake, 2j crank pulley, tloof wiringing harness, 350z ecu swap, 2j uprev tuned, aluminum radiator, 3 slim fans, obx headers, full 3" exhaust, and go go juice.
    Transmission- 2j stage 3 clutch, 2j shifter bushings, poly trans mount, 03 trans, 2j steel braided clutch line
    Suspension- 10k bc coilovers, 2j 15mm alk, 2j bump steer, 2j rck, 4 point Jimmy bar, rear strut bar
    Brakes- 6 piston wilwoods, brembos rear brake setup
    Interior- boost gauge, wideband, oil temp and oil pressure, water temp, egt, fuel pressure gauge, harness bar, 4 point harness, 350z driver seat, soon gutted back seat back, tinted windows and windshield, saaaaawwwwwweeeeeeet 2j air freshener
  7. #5
    Better than Bridgestone? Doubt that.
  8. #6
    Aug 2010
    spring hill,tn
    Drives
    Likes Received
    665
    man, i have been threw alot of tires, hell i even worked for firestone. i know tires lol. i push mine on a daily and push mine to there limits. look my car up if u want to see.
    2002 vq swap
  9. #7
    Aug 2010
    spring hill,tn
    Drives
    Likes Received
    665
    plus i have had the 760's, they r such an out dated tire, i had them over 5 years ago. i didnt put a 1000 miles on them before i sold them for something better
    2002 vq swap
  10. #8
    No thanks, if you have a favorite tire list it here.
  11. #9
    Senior Member Kaz
    Dec 2014
    scranton pa
    Drives
    04 spec v
    Likes Received
    747
    Quote Originally Posted by 2002blackspec_v View Post
    Hahaha
  12. #10
    Oct 2010
    Bay Area, CA
    Likes Received
    695
    So far I've gone through about 6 sets. Stock Contis (crap), Continental Extreme Contact (very good), Falken Ziex 512 (ehh), Kumho SPT (So-so), Hankook Ventus V12 (Very good...until it wears down). Depending on price and available funds, I might try the Michellin PSS or if I'm feeling ballsy, the Federal RSRR.
  13. #11
    Aug 2010
    spring hill,tn
    Drives
    Likes Received
    665
    BFG rivals $130 each.
    Toyo r888 $180 each
    2002 vq swap
  14. #12
    Aug 2010
    spring hill,tn
    Drives
    Likes Received
    665
    255/40/17 rivals mounted on 17x9's
    2002 vq swap
  15. #13
    Aug 2010
    spring hill,tn
    Drives
    Likes Received
    665
    Quote Originally Posted by MoltenNismo View Post
    @MoltenNismo what does that slow n/a know about sticky tires, u have no need for them
    2002 vq swap
  16. #14
    Just ripped through some toyos. Their just toys yo.
  17. #15
    Mar 2012
    FL
    Drives
    2002 Sentra SE R Spec V
    Likes Received
    777
    Currently on Michelin Pilot Sport A/S 3 Plus. Amazing tire, grip is amazing for an all season tire. Also IIRC we are talking about a 45,000mile tire!
    I really recommend Michelin and there Pilot Sport series to anyone. Once you try them you'll be impressed. Worth the price tag, IMO.
  18. #16
    Aug 2010
    spring hill,tn
    Drives
    Likes Received
    665
    Quote Originally Posted by 2k2SpecV View Post
    Hey I really recommend Michelin and there Pilot Sport series to anyone. Once you try them you'll be impressed. Worth the price tag, IMO.
    never could find my way to spend that for tires that dont do what i want since my car only really gets driven on weekends now and i go threw tires in about 5k miles lol
    2002 vq swap
  19. #17
    Yeah I've had pilot sports, they are definitely up there with some of the best
  20. #18
    Senior Member Steve
    Feb 2011
    Anderson. SC
    Drives
    Black 05 Spec V-T
    Likes Received
    2099
    asking this crew to name their favorite tire, will get approximately as many brand/models, as there are reply's to your thread! Everyone has their own cost/performance/type of driving style and most are not limited to a brand/model as much as what works for them. or what was on sale when they needed tires. for pure track purposes, 2002 and yogi can give you great advice, for track and racing tires, but remember both of their cars have been highly modified to accept a wider, taller tire without rubbing. while all seasons will work for some people, others will find them absolutely junk for their type of driving. as I said, I had the potenzas when I had my turbo build done, they went from about 75% tread to 25% within a month, my fault, but still.. the Toyo Extensa HP's I have now, are almost 2 years old, on a turbo car, and are still at ~70%, stick well in the wet, very adequate dry traction, and ride well, BUT, they are noisy! I dont track my car, tho, and really have no need for a super sticky tire.
    work in progress...
  21. #19
    Senior Member Kaz
    Dec 2014
    scranton pa
    Drives
    04 spec v
    Likes Received
    747
    Toyo r888s ftw lol
    Loved them at autox and up the mountains
  22. #20
    Oct 2010
    Bay Area, CA
    Likes Received
    695
    It's smog season so yea it's NA.
  1. Favorite pic of your car!
    By atomicguy7 in forum Member Rides and Project Cars
    Last Post: 12-22-2016, 09:52 AM
