Usual hard start issues back
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
  1. #1
    May 2017
    Likes Received
    Default Usual hard start issues back
    I replaced the entire fuel pump assembly with one from a1 auto part number 1AFPU00373. After installing, it seemed like it fixed the hard starting/extended crank issues for about a week. Now it's back to its old ways and I'm losing my mind. I guess next step is changing the crank/cam sensors? It's a 2006 1.8 with 75k miles. No check engine lights and no active codes being thrown. HELP.
    Sent from my SM-G930T using Tapatalk
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Do you let the fuel pump prime before starting or do you jump in, turn the key all the way to start? Try leaving the key in the "on" position (1 position before start) for a few seconds then start it.
  4. #3
    May 2017
    Likes Received
    Definitely been doing that...which I've incorporated into my everyday driving. I turn to the "on" position and leave it until the 5th chime. Turn to off and do the same again except crank after the 4th or 5th chime. When it actually runs on its own, it takes about 3-4 seconds of actual starting. I can hear the pump prime every time (well, at least start humming) and it runs great after started. Im averaging 30.4 MPG. New fuel pump assembly, plugs and hi test gas. Have recently seafoam sprayed the intake (kit they sell).
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    May 2017
    Likes Received
    I'm ordering the crank and camshaft sensors to see what that will do. Isn't there some way to tell by the tach while starting if the sensor is bad? Like if the RPM doesn't Increase?
  7. #5
    Senior Member Alex
    Jan 2015
    Chicago
    Drives
    2004 Sentra SpecV, Molten Silver
    Likes Received
    157
    Quote Originally Posted by ryjay7887 View Post
    When the camshaft sensor went bad on me this weekend the car wouldn't start and there was a code for it. When my crankshaft sensor went bad a few some time ago the car was misfiring as I was driving and a code came up for the sensor.
    04 Molten SpecV
    Intake: 2J CAI, 2J full plenum kit
    Cooling: Mishimoto rad, shroud with fans, thermostats, & hoses, Nismo rad cap
    Engine: 2J crank and ps pulleys, crossmember bushings, solid motor mounts
    Exhaust: Gold Medusa header, 2J 3" wrapped catless midpipe, 2J 2.5" Side Exit v2
    Suspension: 10k Inverted BCs, 2J rear sway bar, Eibach front sway bar, 2J LCAs with race ball joints and BSK, 2J 15mm ALK
    Electrical: 2J 90 Amp race alternator, yellow 2J fogs, 2J ground kit
    Transmission: 2J short throw with turcite bushings, 2J weighted shift knob
    Aero: CF Evo hood, Nismo spoiler, front WRX lip
    Brakes: 13" Brembo 2 piece front slotted, slotted and cross drilled rear, Goodrich SS brake lines
    Wheels & Tire: 2J burned Ti lugs, Rays versus Tourismo with 235 40/18 Kuhmo XS (summer), Bronze Nismo with 215 45/17 Continental DWS (winter), Bronze Rays Daytona 707 w/ slicks
  8. #6
    May 2017
    Likes Received
    Also with the 1.8, isn't there a fuel check valve near the fuel rail on top of the engine? Any better luck with replacing that too?
  9. #7
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    2004 spec v hybrid 2jr turbo qr
    Likes Received
    3578
    calling all 1.8 experts
    time to chime
    odd the canister replacement helped at 1st
    what changed?
    sock fell off the pump?
  10. #8
    May 2017
    Likes Received
    Not really sure what changed. I guess I could pull the canister and inspect. I found it very weird that it fixed the problem for a week.
    Maybe it's a little warmer than it was a week ago but it still has problems starting first thing in the morning when it's cold too.
    I'm going to see if there are any stored codes. No check engine light though. Hopefully someone with a better reader than my basic ODB2 can see more than me.
  11. #9
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    03 spec V, 02 specv,Passat,f150,Kawasaki Vulcan,Fleetwood Flair, also drives neighbors crazy!
    Likes Received
    219
    What plugs are you using and how old are they? How old is battery?
    A poor spark can cause hard starting. A old battery can lack the amperage to crank AND supply proper voltage at the same time. Do a battery load test and replace plugs with quality plugs.
  12. #10
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    Likes Received
    3578
    Quote Originally Posted by Jon View Post
    i run a minimum size battery
    [actually designed for an mx5 ,] 370cca
    for reduced weight up front and track use
    if i have so much as a bad ground
    car will not start
    if i have to crank it 15-20sec
    [time required for the red oil lamp light to go out]
    my battery is pretty much done
    car is kept on a trickle charger and i have to run reduced plug gap
    so yeah, what Jon said is critical
  13. #11
    May 2017
    Likes Received
    The plugs are about 3 weeks old. I don't remember the model number but they are Bosch. Somewhere in the mid-level price at AutoZone. I replaced the plugs before I put in the new fuel pump and it didn't make a difference on starting. The new fuel pump assembly has made the most impact so far until lately.
    The battery is about a month old.
  14. #12
    May 2017
    Likes Received
    I'm honestly thinking now that it must be fuel pressure related. What's throwing me off is that the same issues are back after a week. Once that new fuel pump went it, the car never started so good...and it did multiple times a day wether it's hot, cold, sat all night or recently shut off.
  15. #13
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    Likes Received
    219
    See if you can get somebody else to start it so you can observe the exhaust look for excessive smoke, fuel smell, oil smell or moisture/anti freeze. If you take out a few plugs after a no start and see if you observe anything on plug or inside cylinders. I hope it's not a head gasket.
  16. #14
    May 2017
    Likes Received
    Would a pressure test/leakdown test tell me anything about that?
  17. #15
    May 2017
    Likes Received
    I've noticed no loss in coolant or oil. Also no notable smoke when starting. When I replaced the old spark plugs, they were fairly clean (minimal carbon) and dry.
    Thank you to everyone who has chimed in on my issue. The brainstorming is really helping out with diagnosing this. Hopefully I can get this taken care of. I might return the fuel pump and try out a different one...maybe the new one has a faulty check valve? Really reaching there.
  18. #16
    May 2017
    Likes Received
    Update
    Called 1A auto and they shipped out a new pump for me under warranty...apparently the one I bought has a lifetime warranty on it. When it gets here next week and I install it, hopefully it will solve my issue.
    I should be recieveing the crank and cam sensors today. If they get here, I'll throw those in too. I'll basically have a brand new engine after all of this.
  19. #17
    May 2017
    Likes Received
    Replaced the cam sensor yesterday...since it was the easiest to get to. There is no difference in starting.
  20. #18
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    Likes Received
    219
    Where are you located? Perhaps a local member can take a look.
  21. #19
    May 2017
    Likes Received
    I'm outside of tampa.
    To add to everything else, I finally threw a code P0171 bank 1 too lean. I'm not sure if it has anything to do with hard starting but I'm thinking MAF sensor. In the process of all these (tune up items) I sprayed MAF cleaner on the sensor to clean it off. A few days after that is when I got that code. I'm also getting reduced MPG's.
  22. #20
    Senior Member Jon
    Jul 2011
    Tilton, NH
    Drives
    Likes Received
    219
    Can you test the primary O2 sensor with that code reader? They should be replaced at 60k miles or close to that. Also check really good for any vacuum line or intake leaks. The cleaner shouldnt hurt it.
  1. 1.8 hard start no start. P0183
    By Jayfella973 in forum Member Rides and Project Cars
    Last Post: 12-02-2016, 04:48 PM
  2. QR25DE Hard start
    By nycbeef1 in forum B15 Sentra (2000 - 2006)
    Last Post: 11-05-2016, 03:36 AM
  3. Hard Starting Issues When Hot
    By fchavez09 in forum B15 Sentra (2000 - 2006)
    Last Post: 06-20-2015, 10:25 AM
  4. Hard Start (Cold Start)
    By anthonyzm in forum Member Rides and Project Cars
    Last Post: 04-07-2011, 10:32 AM
  5. QR25DE hard to start and gear 1 hard to pop into..
    By 02SPEC- in forum Troubleshooting and Support
    Last Post: 02-05-2011, 07:33 PM
