All B15 Models Installing Solid Motor Mounts
Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 191
  1. #1
    Senior Member Jamil
    Jul 2009
    Staten Island NY
    Drives
    qr25det
    Likes Received
    139
    Default Installing Solid Motor Mounts
    They can be purchased at this site http://www.neverenoughauto.com/index...egory_id=15813
    or
    http://www.nissanraceshop.com/produc...5de-999961112g
    Remove 3 or 4 spider clips from this plastic piece
    Remove 14mm bolt holding the front mount
    Remove 14mm bolt holding the rear mount you may need a small extension
    At the Front Remove 2 17mm bolts here
    Remove 2 12mm bolts thats holding the exhaust hanger
    At the Rear remove 2 17mm bolts here
    You can now drop the whole crossmemeber out
    When Reinstalling Make sure you Grease up the Mounts so they can slip right in place.
    It was a pita to get it out on my own so i stopped in the middle of the whole process and took the mount and bracket to a shop and they pressed it out for me for 15 bucks. Took 10mins
    FRONT
    REAR
    Solid Motor Mount VS MMI's (motor mount inserts)
    Soild Motor Mount VS Stock mount
    Quoted from Travis " to get the old mounts out, you can press them out, or, do what I do, and use a sawzall to cut through the metal band. Once you bust through.. you release the tension by creating a small gap from the saw blade, and the mount slides right out."
    And this is how it will look like when u cut it.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #2
    Senior Member Jamil
    Jul 2009
    Staten Island NY
    Drives
    qr25det
    Likes Received
    139
    not sure if this how tos got transfered from the nycsentra files but if not then here it is again.
  4. #3
    Senior Member Sebastian
    Nov 2006
    Likes Received
    53
    failed to mention that you need to support the engine block when removing the cross member
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #4
    Senior Member Eddie
    Jul 2009
    Newark, NJ
    Drives
    04 Volcanic Spec
    Likes Received
    12
    those solid mounts are great A+++
    04 Volcanic Sentra (Sold)
    02 Midnight Blue Protege5
  7. #5
    Senior Member Jamil
    Jul 2009
    Staten Island NY
    Drives
    qr25det
    Likes Received
    139
    Quote Originally Posted by SpecBEE View Post
    you dont have to since the side mounts are holding it in place but it's a good practice. u right.
  8. #6
    Newbie Chris
    Nov 2010
    Corpus Christi
    Drives
    2003 Spec V
    Likes Received
    I know this is a very old thread but wanted to ask about the second set of instructions. It says you can cut the mount and the old mount will easily slide out. So you do what now, weld it back? Won't that create a weak point?
    Also, where is a good place to go that can press motor mounts? A tranny shop?
  9. #7
    Member Ashwin
    Dec 2005
    NYC
    Drives
    '03 QR25DE-T
    Likes Received
    645
    Yeah, just get them pressed out
  10. #8
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    just light the mounts on fire wait 10 mins (nice beverage break) for it to burn the rubber out and then take a torch and cut the ring and it falls right out
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Red '02 - Because I'm crazy
    Blue '94 Miata - for the ladies
    Gray '07 Prius - Dat eco doe..
  11. #9
    Newbie Chris
    Nov 2010
    Corpus Christi
    Drives
    2003 Spec V
    Likes Received
    Well, I found the mounts on ebay for 72 shipped. I have a 7 ebay buck coupon so now 65. The local shop(I called around to a bunch of shops) wants half an hour of labor so 35 for the job.
    So that would be 100 bucks total for new mounts...not too bad.
  12. #10
    Newbie Chris
    Nov 2010
    Corpus Christi
    Drives
    2003 Spec V
    Likes Received
    Quote Originally Posted by Specv03 View Post
    How would you suggest lighting it on fire?
  13. #11
    Sep 2009
    Queens,NY
    Drives
    02 Nissan SE-R SPEC V!!!!
    Likes Received
    195
    What i did was take an electrical saw and saw at the ring then chiseled it out with a hammer and screwdriver. Most shops should have a press.
  14. #12
    Oct 2010
    Bay Area, CA
    Likes Received
    696
    Did any of you who have it have to force the crossmember back up to reach the bolt holes? I notice that the mount holes are centered as opposed to being offset to a little bit higher like the stock mounts. Also are you still able to do the $4 WHA with that?
  15. #13
    Apprentice Kevin
    Apr 2010
    Denver, CO
    Drives
    04 Spec V/02 Spec V sr20 swap
    Likes Received
    32
    Quote Originally Posted by MoltenNismo View Post
    No and yes. I have it this way. Not wuth these mounts tho. I got old skool place racing mounts.
    Sent from my phone. Who cares what it is, they all do it now-a-days.
  16. #14
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    yeah its a fucking PITA to get it back in, just lub it up. but yeah you can still do the 4$ washer mod to the crossmember works fine just make sure you grab enough washers
  17. #15
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    Quote Originally Posted by theaviatora380 View Post
    the torch you eventually use to cut the ring
  18. #16
    Oct 2010
    Bay Area, CA
    Likes Received
    696
    When you said it's a PITA to get back in, is it because it's fatter? Kinda like having MMI's where the inserts are sandwiched in between the bracket where you have to lube up the sides to slide it up? Or is it because the hole doesn't quite line up with the through-bolt for the engine bracket? Thanks for the help. I'm just trying to see if it's even worth the trouble for a DD.
  19. #17
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    to squeeze it in where it was because of the sandwich effect. but just put heavy grease in there and your all good, and if you have a foot and a half screw driver or crowbar you can slide it around till its in the right place. my cars DD and this was like the first thing i did to my car, cause just feeling the motor shake back n forth goin down the road when im slowing me down or stepping on it drives me nuts, just a warning, these have a lot more vibration then mmis but i like the vibration and the immediate wheel response when you get on it is great. you can find both front and rear mounts i got from here
  20. #18
    Newbie Chris
    Nov 2010
    Corpus Christi
    Drives
    2003 Spec V
    Likes Received
    So is it safe to say that with the right tools this can easily be a parking lot job?
  21. #19
    Senior Member Lucas
    Aug 2010
    NH
    Drives
    yo mother
    Likes Received
    151
    i have an 8 car garage with a lift.. you could, but itd be a really tight fit, and it would be hard to put enough pressure onto the crossmemer to get it in with it at your chest but nothing a lot of heavy grease cant fix!
  22. #20
    Oct 2010
    Bay Area, CA
    Likes Received
    696
    Do what I did when I installed my MMI. Have a jack stand support the engine while the crossmember out and have a jack push the crossmember in.
  1. Solid Motor Mount
    By 02SilverSpecV in forum B15 Sentra (2000 - 2006)
    Last Post: 09-15-2009, 05:58 PM
  2. Solid Prothane Motor Mounts
    By Splash45 in forum B15 Sentra (2000 - 2006)
    Last Post: 06-17-2009, 03:51 PM
  3. motor mounts
    By m&ms in forum B15 Sentra (2000 - 2006)
    Last Post: 09-24-2008, 09:08 PM
  4. Possible solid crossmember mounts...
    By ash in forum B15 Sentra (2000 - 2006)
    Last Post: 07-16-2008, 04:50 PM
