All B15 Models 300ZX Calipers on a B15 - Page 8
Page 8 of 26 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 508
  1. #141
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Here's a pic of a 4x114.3 s14 OEM 15" wheel with z32 brakes. Granted this is on an s14 and he used 15mm spacers, it just shows that it fits.
  2. Remove Advertisements
    B15U.com
    Advertisements
  3. #142
    Senior Member Vay Gin
    Oct 2009
    A, A
    Drives
    02 Spec V 3rd Engine
    Likes Received
    35
    15mm spacer are a lot! Special if u want to go to the drag strips or do auto cross.
  4. #143
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Quote Originally Posted by Jollimon View Post
    That's why I edited it.. I realized I hadn't had my facts checked right and was gonna do that. But you beat me to it. ^_^
    I'm wondering if it'll fit on my wheels..
    Team Dynamics 17" on an '03 Spec-V.
    With the M30 rotors, and no shaving.. just the washers.. yeah, that's sounding good to me.
    Think it'd fit?
    -Jolli
    It's all about the spoke design really, offset plays a roll as well, but even a crappy offset wheel will fit if the spokes are far out enough near the center.
    If I could pull the big rotor thing, I wouldn't need spacers because my spokes come out up top/mid of the rim. There is a pic a page or 2 back trying to explain what I'm talking about.
    HOW TO USE THE B15U.COM SEARCH!
    THERE HAS NEVER BEEN ANYTHING MADE THAT DID NOT HAVE A PURPOSE
    Performance: QR25DE-T 308whp and 314wtq at 9.5psi
    Suspension: Nismo R-tune bushing kit/Nismo RSB/FSB/4pt lower brace/4pt trunk bar/9k BC Racing Coilovers/ALK/15mm spacers/prothane mounts/ 17x7 O.Z Ultraleggeras with 225/45/17 P960 AS Pole Positions
    More to come...
  5. Remove Advertisements
    B15U.com
    Advertisements
  6. #144
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Quote Originally Posted by Specvay View Post
    15mm spacers for autox are actually better, giving you more track width and such. Just put 15mm all around! Woot!
    And how big are the rotors for the s14? I know the 4 lug 240sx rotors are small, like 10.2" so it may not be relevant when using 10.75"
    More to come...
  7. #145
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Quote Originally Posted by thesammythecurse View Post
    Actually, with the z32 calipers, they use the z32 rotors which are 11" , with us being a tad smaller and the caliper moved closer to the center of the hub should give us a bit more space. I remember my s13 had 9" rotors.
  8. #146
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Quote Originally Posted by MoltenNismo View Post
    Actually, they use the with the z32 calipers, they use the z32 rotors which are 11" , with us being a tad smaller and the caliper moved closer to the center of the hub should give us a bit more space. I remember my s13 had 9" rotors.
    Sweet, then a 15 seems possible Barry!
    Next time we meet up somewhere just bring one of your 15" wheels and we'll throw it on my car and see how it sits. I have 15mm spacers up front, so if it clears diameter I think it should fit fine.
    More to come...
  9. #147
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    In theory, all you really need to do is measure from the center of the hub to the farthest part of the caliper, if that clears 7.5" (assuming 15"/ 2 to get the center of the 15" wheel) give or take a few hairs then it should be plausible.
  10. #148
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    2004 spec v hybrid 2jr turbo qr
    Likes Received
    3580
    thanks people
    this thing may auto-x and drag race with a simple coilover reset
    sammy you will have to drive this again it will be a different car
    even rolling it down the driveway [several times lol] felt different
    with the 6 point roll bar tight, the fender bars and trunk bar in, this thing is rigid
    btw
    the new rear brakes now perform emergency stopping functions too
    i could stop it easily with the parking brake and a good hard yank
  11. #149
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    Likes Received
    3580
    but on the drag strip
    the wider the wheel spacing [track] the more leverage each wheel has, as it breaks and makes traction on launch
    leading to erratic, non straight launches, add torque steer
    and oh boy
    thats why dragsters use such a narrow rear track
  12. #150
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    I did not know that.
  13. #151
    Cha ching! 1991 M30 rotor, perfect fit, no mods (except washers)
    Just to be sure as to what you're sayin-with the m30 rotors you don't need to shave them? they bolt on and don't hit the caliper?
  14. #152
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Quote Originally Posted by mannymoeandjack View Post
    Correct, no shaving. They are in 4x114.3, and they fit perfect.
    More to come...
  15. #153
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    The reason we need to shave ours is that our rotor diameter is at 11" and the M30 is at 10.78". We're required to shave the 11" by 1/4" making it 10.75" to clear it, but 10.78" clears it just fine.
    Sammy, have you found any performance rotors for the m30?
  16. #154
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Not yet, haven't really looked. Not much extra money right now. Lol. I'm kinda pushing to try my idea at the 12.75" upgrade now though, I have a few leads and people interested in helping make it happen. My autozone rotors will work until then unless the bbk idea fails miserably.
    More to come...
  17. #155
    Senior Member Barry
    Oct 2010
    North Ga
    Drives
    Likes Received
    3580
    when i searched on auto zone
    i found this loaded for 197 with semi metallic pads
    Morse/Brake Caliper Loaded Pair - Front (P1397) | 1990 Nissan/Datsun 300ZX 6 Cylinders R 3.0L SFI DOHC | AutoZone.com
    part number P1397
    are these the 26mm calipers?
  18. #156
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Wow for a pair? Damn that's cheap.
    Yea Barry, you're looking for a 90 non-turbo car.
    http://importnut.net/300zxbrakeswap.htm#frontbrake
    EDIT: Barry, I just checked out the part number and it shows under 91 TT as well, so I don't know if that's the same since 91 TT uses the 30mm.
  19. #157
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    Ok, just did more reading.
    P1399 are the 30mm (just don't know if they're the aluminum or iron)
    P1397 are the 26mm
  20. #158
    Senior Member Sammy
    May 2010
    Canton, GA
    Drives
    2006 SER Spec V
    Likes Received
    887
    Autzone can't tell the difference between aluminum, iron, 30mm or 26mm. So every time you order it's a hit or miss. For the most part, when you order 91+ you get 30mm and it could be either iron or aluminum, wont know till you get it. and 50% chance when you order 90 NA you get 26mm lol.
    I can get semi loaded 30mm calipers reman. for $110 (after returning core). Coems with hardware, but no pads.
    If you have 5 lug, you can do the 30mm swap for about $250 (calipers, pads, lines), and get some 300zx rotors and mill them down and your set. With the 12.75" upgrade I'm working on, I'm hoping for $550 all said and done. It's in the works...
    More to come...
  21. #159
    Oct 2010
    Bay Area, CA
    Likes Received
    700
    The only thing is that I can't seem to find a decent company that has the adapters. I can't find anybody selling JSK, R1Wurks or the Punk Racing ones. All I found are ebay stuff and I'm kinda iffy on the quality. I might just say screw it and get 13" wilwoods from 2j.
  22. #160
    Apprentice reinierjames
    Feb 2010
    San francisco/ pittsburg CA
    Drives
    black 02 spec
    Likes Received
    95
    bro why would you shave down the 300zx rotor, it should fit already right?
  1. 300zx big brake's fs
    By swiftman in forum Parts for Sale
    Last Post: 12-29-2009, 06:49 PM
  2. SE 2.0 Rear Calipers?
    By power_shift in forum Suspension, Chassis & Braking
    Last Post: 10-27-2009, 11:10 AM
  3. j30 calipers
    By grambo420 in forum Suspension, Chassis & Braking
    Last Post: 08-14-2009, 11:41 AM
  4. WTB: Rear calipers
    By ash in forum Parts Wanted
    Last Post: 07-29-2009, 12:44 PM
  5. 300zx Brake Upgrade
    By ash in forum Suspension, Chassis & Braking
    Last Post: 05-21-2008, 08:44 PM
Tags for this Thread
