Results 1 to 2 of 2
    Default soft clutch pedal
    Lately ive noticed my clutch pedal has had more play then usual. i can push it down probibly half way before i feel an resistance in the pedal. fluid level is perfict and i didnt c any leaks that ony leaves the master or slave cylinder. any idea witch it might be?
    Jared nosliwmj is offline
    Texas
    My clutch was starting to do that and I ended up replacing all the fluid in the system. Took a while to bleed out the air but no problems now.
  1. Soft pedal after upgrade?
    By Animlauk86 in forum Transmissions, Clutches, etc.
    Last Post: 02-02-2011, 05:00 PM
  2. Clutch pedal sticking
    By SD_Phantom_29 in forum Transmissions, Clutches, etc.
    Last Post: 08-24-2010, 09:28 PM
  3. clutch pedal failing
    By steven_s in forum Troubleshooting and Support
    Last Post: 06-02-2010, 12:08 PM
  4. Clutch pedal falling
    By CnyQR25det in forum Troubleshooting and Support
    Last Post: 05-13-2010, 03:17 AM
  5. my clutch pedal
    By coderedspecv72 in forum Transmissions, Clutches, etc.
    Last Post: 04-16-2008, 12:51 PM
