Page 1 of 8 12345 ... LastLast
Results 1 to 20 of 158
Like Tree7Likes
Thread: GI: Solid Poly Trans Mount Delrin Spacers
    Hamilton,OH
    Default GI: Solid Poly Trans Mount Delrin Spacers
    I can make some of these up if there is solid interest in them.
    Papal- sid_900000@yahoo.com
    All orders will be sent via usps.
    LIST
    MisterNuts-PAID-SHIPPED
    CrickiKaze-PAID-SHIPPED
    Darsondriss-PAID-SHIPPED
    Undelay-PAID
    Specvay
    NissanSpec
    You will need to grind the tabs off of the locating mount to fit these in.
    I am definitely interested if prices are reasonable.
    george undelay is offline
    Jul 2011
    dunbar, wv
    looks good or should i say interest ing
    Hamilton,OH
    I was thinking $15 shipped. These can be made out of a multitude of materials also.
    Here is our stock....
    My Engine Build-http://www.b15u.com/naturally-aspirated-na/18182-n-conservative-build.html" target="_blank">http://www.b15u.com/naturally-aspirated-na/18182-n-conservative-build.html
    Port&Polish Work-http://www.b15u.com/members-services/19127-offering-port-polish-work-%2Apaint-colors-added%2A.html" target="_blank">http://www.b15u.com/members-services/19127-offering-port-polish-work-%2Apaint-colors-added%2A.html
    Rear Strut Bars-http://www.b15u.com/suspension-chassis-braking/17257-rear-strut-bar-2.html" target="_blank">http://www.b15u.com/suspension-chassis-braking/17257-rear-strut-bar-2.html
    So this is a poly mount with delrin spacers? Can you elaborate on the design a bit?
    Hamilton,OH
    One of the other members discovered that this mount would work for our transmission mount, except it a bit too narrow. Instead of stacking up washers you can use this to fill the gap. A lot less hassle and a good bit more sturdy since its one solid piece on each side.
    So you press out the factory mount, which is hydraulic btw, press is the poly mount(not included), then take the bracket off the trans and grind off the little tabs like pictured and then re install everything putting one spacer on each side of the poly mount.
    Gotcha. Is there a way to make a full delrin mount possibly?
    Hamilton,OH
    Yeah, but we don't have enough delrin stock that large. Plus it would be a lot more work to turn it down to proper size.
    Ill take one! paypal?
    Any way i can get the hole ground out a bit more? I cut the stock mount up and got the correct length steel insert out of it to use instead of the one supplied with the mount. But i am worried about the two sides possibly popping out since its not one piece. If not ill take it anyways and grind it out as needed.
    Nov 2010
    Jacksonville, NC
    I'll bite, so the black is the poly and the white is the derlin
    Hamilton,OH
    Quote Originally Posted by darsondriss View Post
    Sure. What size would you need the hole to be?
    Quote Originally Posted by CrickiKaze View Post
    That's correct.
    Hamilton,OH
    Bump. So I need hands in the air. Im sitting on about 12-15 pairs if I cut this delrin down.
    Vay Gin Specvay is offline
    A, A
    Pm
    Hamilton,OH
    List made in first post.
    Pm replied
    Nov 2010
    Jacksonville, NC
    when I said I'll bite meant that I wanted one
    Hamilton,OH
    Updated
    Im in.
    ill get the ID tonight, it will probably be pretty close if not the same as the normal one though.
    Hamilton,OH
    Updated
    A, A
    My stuff was Mail to u today. Let me know when ur done I pay u for everything thanks!!!!
  1. Solid upper passenger engine mount
    By ckyfreak2010 in forum B15 Sentra (2000 - 2006)
    Last Post: 09-23-2011, 05:43 PM
  2. 02 spec v trans. mount
    By undelay in forum B15 Sentra (2000 - 2006)
    Last Post: 08-27-2011, 11:38 PM
  3. 02-06 FI-R Solid motor mount inserts..
    By Trav4011 in forum Forced Induction Racing (FI-R)
    Last Post: 08-23-2011, 08:05 AM
  4. Solid Motor Mount
    By 02SilverSpecV in forum B15 Sentra (2000 - 2006)
    Last Post: 09-15-2009, 05:58 PM
  5. Replies: 2
    Last Post: 03-11-2009, 07:24 AM
