Results 1 to 7 of 7
    Jan 2012
    Default Whining noise at 60-70 mph? (HELP!)
    Hey guys,
    Just thought I'd ask the internet sentra guru's while I'm exploring my options;
    I just recently (last week) bought a 2006 Nissan Sentra 1.8L base trim with manual transmission and only 54000 miles on it as a commuter car to replace my dying 1997 Volkswagen Jetta. Unfortunately however, I've noticed recently that it is making what sounds to me like a transmission related noise when I am travelling at higher speeds.
    It sounds like a high pitched whining, almost a whistling noise. The noise happens when I am driving at about 60 mph, is loudest at about 65 mph and gets almost inaudible after 80 mph. It's most obvious when I am stepping on the gas, but can also be heard when I am still in gear and just coasting. When I clutch in however, the noise dissapears. It makes the noise regardless of whether I am in 5th or 4th gear but only going at that same speed (60-65 mph), although it seems to be louder in 5th gear. It isn't terribly loud, but noticible over the road noise.
    Any ideas on what this could be? I get the impression from similar posts that this could be an input shaft bearing on the transmission going bad... I am at my wits end here, since I bought this car to replace my Jetta which had a failing transmission!
    Bob BeOhSix is offline
    Jun 2011
    Des Plaines
    yup. it's the input shaft bearing. had the samething happen to me so i ordered a bearing/syncro kit and rebuilt my trans. it could also be a throw out bearing tho. change that also while your in there
    Jan 2012
    Quote Originally Posted by BeOhSix View Post
    That would be a great plan if I knew what the hell I was doing in there, unfortunately I'm not a mechanic and I don't want to screw anything up. Seems like I'm gonna need to take it in to get fixed by a professional. I wish I could do it myself (I would if I could), but I guess I'm gonna need to bite the bullet and pay for this one; at least it has a limited powertrain warranty... Any idea what this repair might cost at a transmission shop?
    Jun 2011
    Des Plaines
    I would say about $800. ~$250-$300 for parts and the rest is labor. If the trans was out I would say ~$450. Hopefully it's covered under warranty
    Jan 2012
    Thanks for the advice man, I appreciate it. It sucks that I have to deal with this BS after going through the trouble of buying another car, but stuff happens. I'll post an update on the source of the noise once I get a proper diagnosis from AAMCO.
    LI, NY
    i get same noise, but its not as loud as you make it out. only when im in fifth, guess i got some work ahead of me thx for the info was wondering what it was.
    "Cogito ergo sum"
    "Vi Veri Veniversum Vivus Vici"
    "Si vis pacem, para bellum"
    Jan 2012
    Just a final update, I took it in to AAMCO for an assesment, and they told me that everything was fine. They said that a small amount of noise is normal, and that if it was a bad bearing that the noise would still be audible in neutral with the clutch out. Lately the noise seems to have gotten a lot quieter, so I'm feeling a bit better about things. Thanks for your help guys.
  1. HELP Nissan Sentra 2005 Whining noise/ Burnt smell.
    By salty2980 in forum B15 Sentra (2000 - 2006)
    Last Post: 11-01-2011, 05:49 PM
  2. Whining noise!!!
    By OKIBOY in forum Troubleshooting and Support
    Last Post: 07-07-2011, 12:33 AM
  3. a deep whining noise (not like serv's)
    By 02_white_spec_v in forum B15 Sentra (2000 - 2006)
    Last Post: 10-19-2010, 06:15 PM
  4. Problems starting, whining noise, and a POS sentra.
    By 04specvnj in forum Troubleshooting and Support
    Last Post: 03-21-2010, 03:46 PM
  5. Whining Noise - making me crazy - HELP!!!
    By ratimand in forum Troubleshooting and Support
    Last Post: 03-20-2010, 01:26 AM
