I just recently boosted. 120k on the stock clutch and not surprisingly the clutch cant take the boost above third gear. Im looking into a clutchmaster stage1. Its in my price range and claims 70% better clamping force over stock. Anyone use this? Any other suggestions? Trying to keep the cost under $400...
yes. i posted from a smartphone. woohooo
4xYEA.
BOOOOOOOOOOOOOOOOOOOOOOOOOSTed.
I have the CM stage 3 FX300 clutch 16psi no issues. 10K miles of abuse still spins the wheels at 60mph
So a stage 1 shouod b fine for 7psi. Just making sure before i buy
4xYEA.
stage 1 should work for 7psi check this website out, many of us here buy parts from justin at ICPP
00+ Sentra Clutch/Flywheel SALE
the clutchmaster one is more in my price range. the act is between the stage3 clutchmaster and the stage one, im gunna try the stage one and see how it goes
4xYEA.
bump. gunna buy it tonight, just want a few more opinions.
4xYEA.
I hear plenty of horror stories about people having run any aftermarket throwout bearings so when you do buy, don't buy a kit and use a oem throwout bearing.
Sorry no help for you on the actual clutch. Find several different places that sell it on line and check the reviews.
Sent from my iPhone using Tapatalk
Up to ten current and previously owned Nissan Products....
Current is My 05 Aztec red Spec and My wifes new '12 pearl white sentra SR SE.
My gripe with Clutchmasters Stage 1 kit is that the sprung clutch disc broke apart and let two springs out, basically crapping it out after only 20k miles. I went with an unsprung clutch disc and haven't looked back.
All except oem on that part.
just my $.02 but i believe theyre all like the same price as far as which 'stage' you go with so personally i'd go a little overkill. i have a competition clutch stage 3 and its still COMPLETELY streetable. I'd have no issue in stop n go if i had to. That way it leaves room for more power down the road
the stage1 is 210 cheaper than the stage 2 lol
4xYEA.
ahhh gotcha.. stage uno is the only cheaper one lol the rest are about the same. well, to each their own then
who said anything bout ATC?? the link i provided you has like 6 different clutch brands, IF you would have scrolled lower u would have seen this
:High Performance street system, holding capacity 70% over stock, Heavy-Duty reinforced pressure plate
*FX100 Stage I - #06-058-HD00 - Retail Price - $340.00 - Your Price - $285 shipped CLUTCHMASTERS
Good boy LOL
Me? Stock.
4xYEA.
