no it's not the stock clutch. it won't do it when it's like >40degrees but as soon as it starts hitting the freezing weather it will start to slip sometimes.
CATCH ME IF U CAN
i just googled clutch slip in cold weather and it seems like i'm haveing the same problem as everyone else.
yeah i notice my car needs to be on and moving for at least like 20min before i can do a WOT and not slip in this weather...i was even slipping in 5th gear sometimes![]()
i never had clutch issues in the cold...oreo.
J, im surprised you clutch is still good lol
CATCH ME IF U CAN
well the weather was nice today in the 50's, took it out for a test run 3rd and 4th gear and there was no slipage. i guess it was due to the weather, weird.
yea you might get that one day it slips and another day it doesnt all depends on how hot that stock clutch gets. but id still be on the lookout for a new clutch.
suprafast - have u ever got the problem fixed? i tried putting new clutch fluid and still the same bullshit when the weather is cold. idk y where the only ones having this problem.
ive had this issue. correct me if im wrong but i believe thats due the clutch getting to hot and rapidly cools off as it would in the winter. Its happened to me years ago when i was young and dumb and used to do OD amounts of burn outs in my accord. either that or the teeth on the clutch are wearing that happened to my boy with his act clutch.
My car is doing the same thing, but Im not sure if it is the clutch or the tires spinning, it happens in 1-3 or maybe even 4th dont remember i will have to check, I have not really paid attention whether or not the mph jump with the rpms. it happens at about 4k rpm and about 11psi.
If the clutch was slipping would I not smell it??
never mind, im pretty sure its not my clutch
raise from the dead.
So is this really a cold weather issue? I figured my car was spinning tires because it's been wet outside the past few days and my tires were crappy.
I got new tires, and it's dry tonight, with some 50 degree-ish weather and I was getting the same result of these "spinning tires" Lol
So I figured if it's my tires, they wont spin in 6th gear. But.. Sure enough, same thing happened. I guess this 300zx clutch isn't going to cut it like I thought. Onto something new.
