Results 1 to 3 of 3
    aaron specvt06 is offline
    Lafayette Tn
    Default injector leaking
    Since my Turbo install I've had to remove the intake manifold multiple times to mess with injectors leaking ...bought the injectors used so maybe I should buy new o rings? Its mainly when I first start the car and then right after I turn the car off ...
    any suggestions? Everytime I take this off mess with it and tighten the fuel rail back down it stops then gradually comes back....they're the Ford racing blue giants injectors that used to come with t.n Turbo kit..I have a Wally 255 and no fuel return line if it makes a difference
    Slapped 18 Times in 17 Posts
    Yes, grab some new o-rings and change them asap.
    Lafayette Tn
    Ok thanks I was planning on trying that tomorrow. It wouldn't leak after I turn the car off b/c of pressure or anything would it? I have my intake pipe with a hose going from it to the valve vent. Capped off the intake mani barb and put a catch can with filter to the barb the I.m used to run to on the back bottom left of valve cover
  1. Clutch master leaking?
    By theaviatora380 in forum Troubleshooting and Support
    Last Post: 01-03-2011, 11:04 AM
  2. Leaking coolant
    By CnyQR25det in forum General Maintenance
    Last Post: 09-09-2010, 12:11 PM
  3. Leaking radiator
    By TN specV in forum B15 Sentra (2000 - 2006)
    Last Post: 07-27-2010, 03:35 AM
  4. Tranny fluid leaking?
    Last Post: 02-20-2008, 01:13 PM
  5. Leaking A/C?
    Last Post: 02-02-2007, 03:32 PM
