Page 4 of 4 FirstFirst 1234
Results 61 to 69 of 69
  1. #61
    Lucas Specv03 is offline
    NH
    Slapped 2 Times in 1 Post
    everyone for some reason thinks cipher wont work on early model specs but it works perfectly and has a lot of functions that consult can do and then some
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Quote Originally Posted by JVSpecV View Post
    A twin charged, 6 wheel awd, center steer, sqr powered spec v with n2o is no laughing matter.
  2. #62
    Cornelio CORN DOG is offline
    Mesa, AZ
    i wanna know how he has a 02-03 Spec with NO rev limit
  3. #63
    Rochester, NY
    Tecnosquare forgot to put one on it
    My worry is using cipher with flash it back to stock though.
    Sent from my iPhone using Tapatalk
    Corn Drinking, High Revving, Turbo charged '02 SpecV.
    12.4 ET - Stock Motor and still hunting for 11's.
  4. #64
    Mesa, AZ
    Quote Originally Posted by xxchuncexx View Post
    interesting..... whats the highest you have taken it?
  5. #65
    Rochester, NY
    8k. Not on purpose though. I don't rev it that high usually but it happens at the track. Still going strong on the
    Bottom end.
    It's a long story with TS. I was their test ecu for an 02 way back in 05 I think. They were working on a flash and it ended up getting like 2 whp.
    A few years after I send them an email about the whole situation and asked about a rev limiter raise to 7200 which they did for free because of the hassle from before. Well lo and behold they didn't put one on it.
    I don't want to lose that flash to datalog.
  6. #66
    NH
    cipher doesnt flash so you dont need to worry about it
  7. #67
    Rochester, NY
    You are making my life easy!
    So if I want it to erase the learned fuel trims, it's not a flash? This is great news.
  8. #68
    NH
    the learned fuel trims is the correction that the car is self learning from the primary O2 sensor. you can reset it by leaving the battery off or any of the other tricks but cipher makes it easy and you can up your idle and change the base ign timing map all without losing your tuned ecu
  9. #69
    Rochester, NY
    Win
  1. cut balance shaft
    By punzyspecv in forum B15 Sentra (2000 - 2006)
    Last Post: 10-15-2010, 09:27 AM
  2. FS: 2002 Spec V /hit in the rear/ Codeless VQ swap $5500!!!
    By The Next Episode in forum Vehicles for Sale
    Last Post: 06-06-2010, 02:05 PM
  3. cut bumper?
    By jsk8r57 in forum B15 Sentra (2000 - 2006)
    Last Post: 05-05-2009, 07:47 PM
  4. Who's Done the chain cut?
    By executiV in forum B15 Sentra (2000 - 2006)
    Last Post: 04-15-2009, 04:55 PM
  5. Who cut me off?
    By Sdizzle in forum Sightings - THIS SECTION IS CLOSED - POST IN YOUR REGIONAL SECTION
    Last Post: 04-17-2006, 04:52 PM
