Results 1 to 20 of 21
Thread: Rpm wtf?
    Blake W blake293 is offline
    Fort Wayne, IN
    Default Rpm wtf?
    I am right now cruising downthe interstate and my rpm gauge went spaztic and then just stopped working. I stopped at a gas station and pulled and plugged back in some fuses and started my car back up and it worked. But after cruising for15 miles my engine studdered and it quit working again. I have an apexi afc neo spliced into my edu harness and have no idea where to start so any help will help
    Jason jasonhobbs86 is offline
    Savannah,GA
    check your splices?
    04 Sunburst Spec V Nismo CAI & Cat-Back w/ Brembos + Hawk HPS
    Newest addition: 8000k HIDs - Them SHITS CRUNK!
    $9 STS Mod / Fog Light Mod / Silvia R33 Side Skirts / Painted Valve Cover / Cut BSR Chain! / Gutted Pre-Cat
    Dec 2010
    Probably your crank position sensor whatever thats called
    nismo cai, rs lip kit, vis carbon fiber trunk, vis carbon fiber hood, racing hart c5/c2, hotshot header, megan racing catback, megan racing springs, leather interior,
    Nov 2010
    germantown md
    i am with fyang did u replace your cam and crank sensors with the metal ones?
    Honolulu, Hi.
    sounds like maybe a loose connection? id check all ur splices like mentioned above. could just be one moving around.....but hope u get it figured out!
    2004 SE-R SPEC-V
    NISMO intake
    NISMO suspension
    NISMO short shifter
    NISMO bushings
    NISMO header
    Apexi N1 Exhaust
    PnP IM and PnP TB
    2j-racing Pulley
    clutchmasters stage 2 clutch
    JWT flywheel
    2005 SE-R ALTIMA
    ebay intake with K&N filter
    racingline sturbar
    Racingline y-pipe
    NWP block off plate
    Ferdi Specd4Life is offline
    Mar 2011
    Ontario, Canada
    My car did the same thing a little while ago and it was the crank sensor.. I would start there.
    02 Molten Silver Spec-V - I/H/E , Prothane Mounts, Washer Mod, Brembo Blanks with Hawk HPS Pads, Razo Weighted Shift Knob, Shorty Antenna, Custom "Spec-v" Badged Grill,
    To be installed - Brembo Calipers, GR-2's w/ Lowering Springs, Rear Panhard Bar.
    it's a crank sensor it happen to my friend before
    Fort Wayne, IN
    It seems to come and go it typically works on start up then drops to zero after a while. Then it will bounce all over the place. Work properly for a bit. Then go away. So the sensor is 22 bucks so I will replace it.
    Fort Wayne, IN
    I replaced the sensor it corrected the problem until today. Could the sensor possibly go ousit that fast. Throws a code crank sensor malfunction.
    Was it the newer metal sensor, or was it plastic like the old one? It's a good idea to buy OEM parts when you can, it's only around $30 at the dealer.
    Or you have a short in your wiring somewhere...
    Bob BeOhSix is offline
    Jun 2011
    Des Plaines
    Did you snap the connector back in? Was it a metal sleeve sensor?
    Fort Wayne, IN
    Crankshaft sensor malfunctioning. Actron lookup code.
    Fort Wayne, IN
    I have replaced the sensor twice now. The second time it workeed for about 20 miles then dead rpm. The crankshaft sensor is under a lifetime warranty but i think i have a problem somewhere else. Could boost be an issue with this or is it a possible loose connection?
    You didn't answer my (and Bob's) question... but it sounds like it could also be a wiring issue. Boost won't affect anything.
    Fort Wayne, IN
    It was the metal one from Advanced. I plan on going to the dealership and ordering OEM. I checked my wiring in the ecu and everything checks out. I just cant fiqure out why when i installed the two new metal (advanced auto) sensors they both worked correctly at start up and cruising but didnt last 20 miles down the road.
    The day this started before any problems i was cruising the interstate car spuddered for a split second and dead rpm. After a bit it literally bounced all over the place between 200- 1500rpms than grabbed back to where it needed to be. It continued doing this off and on and finally quit.
    Jun 2011
    massachusetts
    last time i seen a problem like this that wasnt the sensor, and wasnt wiring, it was because someone used the wrong flywheel with incorrect tooth count, but were assuming you havent changed the clutch/flywheel recently?
    but really, your ses light it going on and the ecu is detecting that sensor as a problem. you need to check for continuity, shorts, etc. make sure you clicked the connector on, make sure you clean the surfaces for the bolt as well,, im not sure if thats a grounding bolt! and check other grounds as well, like the ones on the timing cover, and below. there is diag in the fsm for the sensor show which terminals and wires to test. i would also check the voltage with the motor on&off to check output.
    Fort Wayne, IN
    It is definitly wiring then. My audio for my radio quit working and my doors look when ever they please. There is a white box under the dash i think its a door lock control box that has been clicking for God knows how long. I think i am about to run into an electrical nightmare.
    Jun 2011
    massachusetts
    electrical problems you should start by checking the battery terminals for tightness and no corrosion, check the ground has good contact. check the battery voltage with motor on&off. i would def find that clicking relay and replace it, or figure out why it keeps clicking. eventually it could drain your battery, or if its shorting could provide enough load that other sensors loose voltage, which sounds like your case.
    actually shouldve read this more thouroughly, if your tach reading is going above the actual engine rpm, you have electrical issues. if your tach is just dropping to 0 then returning to actual engine speed, then its your sensor or loss of connection to the sensor.
    Feb 2012
    Baltimore, Maryland, United States
    hey i recently got a new clutch kit and my rpms wont go past 4000 every gear but idles smooth runs good lackin torque and hp please help me
    Jun 2011
    Des Plaines
    I can't think of a reason why the clutch would limit your RPMs.
  1. RPM Switch
    By Nerdbot in forum Tutorial Requests
    Last Post: 03-23-2011, 04:54 PM
  2. Rpm Problem
    By ErickB15 in forum Troubleshooting and Support
    Last Post: 02-01-2011, 09:01 PM
  3. SAFC II RPM are way off
    By GTurner598 in forum Tuning & Engine Management
    Last Post: 10-05-2010, 06:36 PM
  4. rpm switch
    By shaun11423 in forum Parts Wanted
    Last Post: 09-23-2009, 08:42 PM
  5. No RPM
    By ash in forum B15 Sentra (2000 - 2006)
    Last Post: 10-28-2008, 05:17 PM
